savvi 0 Report post Posted August 14, 2006 my tappets r noisy on my e30 325is, is this a problem or is it normal 4 this model car has done 285 ks, an can they be tightened to stop the noise with out causing other problems as it is going to the mechanic 2morrow any help would b great Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted August 14, 2006 get them to adjust the valve clearances, is kinda hard to do yourself, esp if your me..mine quieted a lot after having someone prob do it for me. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted August 14, 2006 Hi there, Sure can & should be reset, it is typical for noisy tappets in these engines when they are loose, easy job to reset if you know how - about 1/2 hrs work. Clearences should be 8 or 10 thou - can't remember which offhand. If not sure how - best to get someone who knows. Cheers Quote Share this post Link to post Share on other sites
will 169 Report post Posted August 14, 2006 You should check that the eccentric adjusters are directly over the valve stems. If not, you need to move the rocker shaft to a position so they are. If they are not directly over the valve stems, they will wear unevenly and make adjusting the clearances impossible. These eccentric adjusters also wear flat spots on themselves even if they are directly over the stems after high mileage. This also makes it difficult to set the clearances. I would remove a couple on each bank and check for wear and replace all if you find any flatspotting or uneven wear. I know a few tricks to sort these problems out but they are too difficult to explain here. So if you are ever in Kerikeri, drop in and I'll show you.. Will Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted August 14, 2006 Hi there, Sure can & should be reset, it is typical for noisy tappets in these engines when they are loose, easy job to reset if you know how - about 1/2 hrs work. Clearences should be 8 or 10 thou - can't remember which offhand. If not sure how - best to get someone who knows. Cheers thanks guys how much should i expect to pay Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted August 14, 2006 You should check that the eccentric adjusters are directly over the valve stems. If not, you need to move the rocker shaft to a position so they are. If they are not directly over the valve stems, they will wear unevenly and make adjusting the clearances impossible. These eccentric adjusters also wear flat spots on themselves even if they are directly over the stems after high mileage. This also makes it difficult to set the clearances. I would remove a couple on each bank and check for wear and replace all if you find any flatspotting or uneven wear. I know a few tricks to sort these problems out but they are too difficult to explain here. So if you are ever in Kerikeri, drop in and I'll show you.. Will so a prov mechanic should pic those probs up no worries then, ill print out your comment an take to mechanic just in case, thanks Quote Share this post Link to post Share on other sites
kerrynzl 3 Report post Posted August 14, 2006 Gus the Race-Car Mechanic only charges $15/hour Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted August 14, 2006 Gus the Race-Car Mechanic only charges $15/hour i take it that he is based in chch Quote Share this post Link to post Share on other sites
318is 0 Report post Posted August 14, 2006 If you find yourself doing clearances, and can't remember which is 10 or 8 thou ( or what ever), just think of heat and expansion. Exhaust is always the greater of the two if there is a differance. TIP: If you don't understand, don't lift the bonnet Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted August 14, 2006 If you find yourself doing clearances, and can't remember which is 10 or 8 thou ( or what ever), just think of heat and expansion. Exhaust is always the greater of the two if there is a differance. TIP: If you don't understand, don't lift the bonnet im not doing it my local mechanic will b doing it so they should know once they take the rocker cover off an have a look an c wats going on thanks 4 your input Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted August 14, 2006 (edited) Just make sure they don't over tighten them. It is better to have them noisy and in proper adjustment than quiet and too tight as this will create extra wear on your cams and the problem will soon return, but now with even more wear. PLus over tightening can lead to running issues like uneven idle and flatspots. I know because I've been through the entire process and ended up with a car that ran great and performed as expected, but noisy tappets - whoopie doo. Edited August 14, 2006 by bravomikewhiskey Quote Share this post Link to post Share on other sites
nazistaffcar 0 Report post Posted August 14, 2006 PLus over tightening can lead to running issues like uneven idle and flatspots. I know because I've been through the entire process and ended up with a car that ran great and performed as expected, but noisy tappets - whoopie doo. Not to forget burnt or possibly bent valves after you give your new quiet motor the big rev........Just remember the old saying-a noisy tappet is a happy tappet.....as long as it dont sound like a tractor!!!!! Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted August 15, 2006 Not to forget burnt or possibly bent valves after you give your new quiet motor the big rev........Just remember the old saying-a noisy tappet is a happy tappet.....as long as it dont sound like a tractor!!!!!so then noisy tappets isnt going to creat big problems or get even more loose if i dont get them tightened upcar as good pick up, no missfire or flat spots, just a bit worried that when i give it a kick in the guts its not going to break on me moderately noisy tappets nothing over the top just sounds embarassing. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted August 15, 2006 Just turn the stereo up a few notches otherwise get used to the rather soothing tickety tick tick Quote Share this post Link to post Share on other sites
325GRANT 0 Report post Posted August 15, 2006 (edited) you can get an "additive" that you can add to your oil that will shut them up a bit. sorry i cant remember what its called but ill find out. i do remember its bloody expensive. and remember a slappy tappets a happy tappet ... most E30's have noisy tappets. between my tappet noise and my noisy injectors i can hardly hear my engine at idle. Edited August 15, 2006 by 325GRANT Quote Share this post Link to post Share on other sites
