Hartage 0 Report post Posted September 18, 2006 Got a 3.45 : 1 LSd for sale. Good condition, small case. What interest is there out there?? Give you all a few days then its Trade Me! PM Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted September 19, 2006 small case - that's unusual - what's it from? Quote Share this post Link to post Share on other sites
savvi 0 Report post Posted September 19, 2006 would it fit my e30 325i,thanks Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted September 19, 2006 Hi Andy, out of e30 320i Tourist delivery 4 door car. I suspect thats what it is, as it 11/85 reg NZ, with a MPH Speedo. Not sure what the norm was for these cars, or what it may be worth Savini, it will go in any e30 car as far as i know, have had a few of these and not seen any differences in mounting. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted September 19, 2006 would it fit my e30 325i,thanks The half shaft (diff end) is slightly different - it fits - but oil spews out. Easy fix is to use small case half shaft ends. Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted September 19, 2006 Had a look in the e30 resto bible, factory in some 320i's but rare!! Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted September 19, 2006 (edited) The half shaft (diff end) is slightly different - it fits - but oil spews out. Easy fix is to use small case half shaft ends.You sure? I've never seen a difference in mounting between the small and medium case diffs, i've had 3 small and 2 medium diffs in there without any problems at all, you saying the 325's are different?E: Medium Edited September 19, 2006 by Carl Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted September 19, 2006 mounting is the same, but the half shaft splines have a different sort of little shield thing. the med case one is hard up against the place where the allen bolts joint, the small case have it half way. med case shields on small diff= diff oil flying out back Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted September 19, 2006 But as i remember doing the changes, you dont have to swap the splines over???? Have done plenty of swaps in e30 small and medium case never found this problem. Am a bit confused!1 :confused: :confused: Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted September 20, 2006 (edited) The half shaft (diff end) is slightly different - it fits - but oil spews out. Easy fix is to use small case half shaft ends. mounting is the same, but the half shaft splines have a different sort of little shield thing. the med case one is hard up against the place where the allen bolts joint, the small case have it half way. med case shields on small diff= diff oil flying out back I think you guys mean the Stub axles, that go into the diff itself. As Brent say's, you don't need to touch them, other than bolting your axles to them!!! Edited September 20, 2006 by E30-323ti Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted September 20, 2006 I'll buy it. $150 cash right here right now. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted September 20, 2006 I think you guys mean the Stub axles, that go into the diff itself. As Brent say's, you don't need to touch them, other than bolting your axles to them!!! What we are saying is: If you use medium case stub axles in a small case diff - diff fluid leaks. I'll pay higher than what ever smokenbaby offers. Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted September 20, 2006 $3,000,000 and a set of false teeth I found out the back of work and a fire damaged 205x50x13 Bridgestone tyre. [quote name= I'll pay higher than what ever smokenbaby offers. Someone had to start the bidding. Quote Share this post Link to post Share on other sites
Deftones 0 Report post Posted September 20, 2006 (edited) I don't think Ian is stupid..... but how about $151.00 ?? Edited September 20, 2006 by Deftones Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted September 20, 2006 Ha, move the decimal place one place to the right and you'll get a bite Quote Share this post Link to post Share on other sites
smokenbaby 0 Report post Posted September 20, 2006 Ha, move the decimal place one place to the right and you'll get a bite $15.01. Oh sorry, my other right. Ian, how much would you be looking for this. Please advise us of what you want. That way no one insults your intelligence. Thanks Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted September 20, 2006 I like your first offer!! But really, i am open to realistic offers, i paid alot for the one i have at home, medium case. PM me if you prefer, Quote Share this post Link to post Share on other sites
2002 1 Report post Posted September 21, 2006 Any idea what the lockup ratio is? Quote Share this post Link to post Share on other sites
Hartage 0 Report post Posted September 21, 2006 Good question! I have no idea! Am sure that someone on here will be able to answer. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted September 22, 2006 20 to 25% from factory Quote Share this post Link to post Share on other sites
