MLM 57 Report post Posted February 5, 2010 This is my first major project i have undertaken on my car. By starting a thread im hoping it will be a good way to document my progress for myself and others. For a while I have looked at tuning my M42 engine. Im not chasing outright numbers but rather the fun and learning which comes from messing about with engines. As part of this I happened to come across a set of Dbilas throttle bodies for a good price and therefore the start of the project. But for now this arrived yesterday. Making themselfs feel at home. More pics as progress is made. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted February 5, 2010 badass .. should be interesting to see the difference. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted February 5, 2010 Awesome stuff, good luck Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted February 5, 2010 Can't say i've seen photos of your car? Interesting project! Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted February 6, 2010 Dbilas for the right price eh, lucky find! Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted February 6, 2010 Can't say i've seen photos of your car? Interesting project! There are pics about somewhere but not since I put my refurbed wheels on so I wil get some updated ones up.. Dbilas for the right price eh, lucky find! Yep was, Im the 3rd owner so the plenum chamber is a bit molested however i have ideas for a new, possibly carbon one if i can do it for the right price. Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted February 6, 2010 Looks a nice setup But like Carroll Shelby said "There aint no substitute for cubic inch's" Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted February 6, 2010 I don't think Carroll Shelby was au fait with turbo's when he said that Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted February 6, 2010 Looks a nice setup But like Carroll Shelby said "There aint no substitute for cubic inch's" In drag racing maybe... but throw a less powerful better handling car on a B road and lets see how it goes... Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted February 7, 2010 Cool- Are you going to stay with the factory Ecu or change it? Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted February 7, 2010 (edited) Had a wee bit of a look to see how things may fit together today. But first here is the chopped and welded end of the plenum chamber. Im pretty sure its not factory and not particularly impressive from a flow point of view. But then the general design of the plenum is not that great anyway due to packaging constraints. It appears there are a set of water valves on the fire wall which feed the heater unit behind will be in the way. So thats why the plenum has been modded... They dont look to difficult to relocate if need be. Valve block inside yellow box Also on the "I wonder if thats ok/good enough" list is the brake booster vacuum feed from behind a single TB. Is this sufficient? would a vacuum log fed from all four runners be better? Again easy enough to do. Edited February 7, 2010 by MLM Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted February 7, 2010 Cool- Are you going to stay with the factory Ecu or change it? Depending on how carried away i get, and of course bugdet, im am only planning to chip the stock ecu at this point. It would be nice to get rid of the air flow meter though with a link or similar. Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted April 26, 2010 Quick Update: Trial fitting on spare engine. Before With setup Inlet port for interest sake. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted April 26, 2010 That looks the biz Matt. Watching this one with interest Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 26, 2010 Sweet! .. take you your porting and flowing this ? I vote cams too! should be an angry bee when finished! Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted April 30, 2010 The inlet port and gasket mismatch you can see in the above port results in a poor injector spray path. Half the injector port is blocked! All this from factory....? Time for some machine work me thinks. to port match the head/gasket/throttle body. Only thing holding me back is the fact the factory inlet manifold is the same so there might be a reason for it. Maybe the spray patern misses this "blockage" and has no real effect? Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted May 23, 2010 Just a quick update: unfortunatly no photo's as my laptop died this week. This weekend I installed the throttle boddies on to the E36. After a bit of a battle with wiring and the fact im doing it 2 days after tearing the cartilage in my knee and having to hobble everywhere they went on without any dramas, just as advertised. Initial start up went well as good if not better than factory and after allowing it to warm while monitoring everthing I reset the idle to a still slightly fast 800rpm. Initial results are: - Idles really smoothly -Still drivable with very smooth power delivery and awesome throttle responce -Top end pull feels better by the butt dyno. The engine generally feels much free'er reving. Bottom end feels the same,maybe slightly perkier due to throttle responce. -Sound it is utterly amazingly .....quiet!!! The pod fileter was louder! Go figure? So kinda got the opposite to what i was expexting which was lots of noise and less or equal power. The tune is still standard however so it wont get much road time until im more confident all is well there. Photos as soon as i can Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted May 24, 2010 Keen for those photos Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted May 24, 2010 unfortunate about the knee any chance of a video once the laptop is revived Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 24, 2010 headers, exhaust and remap = 1 stage done! nice! .. +1 for photos too! also manditory one tree hill meet up too Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted May 24, 2010 unfortunate about the knee any chance of a video once the laptop is revived Always, though any action shots would be a red E36 whistling past quietly... Pics asap headers, exhaust and remap = 1 stage done! nice! .. +1 for photos too! also manditory one tree hill meet up too Yep thats my thoughts at this point too. Then ecu, cams + head work for stage 2... Will try for the One tree hill meet though clutch usage is a bit hard with a naff knee Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted May 24, 2010 Always, though any action shots would be a red E36 whistling past quietly... Pics asap Will try for the One tree hill meet though clutch usage is a bit hard with a naff knee I am so sure there will be a volunteer to take the car for a spin so saving your knee Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 24, 2010 Those injector holes??? could there be a difference in the m42 and m44? what was the manifold off? Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted May 24, 2010 Those injector holes??? could there be a difference in the m42 and m44? what was the manifold off? The offset you can see is a factory arangement I.E the same mis-match exists between the factory manifold and head also. I initially questioned this but it appears it is as BMW intended. The spray pattern of the injector misses the ledge therefore is is not an issue. Well as far as i can tell anyway. The manifold is designed for a M42 and I am unsure the differences between M44 and M42 heads in that area. As far as i can tell its all as it should be. Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted June 12, 2010 Pics at last Quote Share this post Link to post Share on other sites
