m2geek 4 Report post Posted May 8, 2012 Hey guys, Looking for some 6x9 adapters for my 320i and I only seem to be able to find em on eBay in the UK - to which I was like Bugger that.. I have replaced the 4in speakers in the rear soundboxes but they still sound like crap (my old car had factory 6x9s and 6x8s so am used to good punchy sound). I dare not go down the road of surface-mounting bigger speakers on the rear tray as it'll a) look nasty and I want it stock looking. I even tried to find some old 6in/6.5in speakers (just for the mounting bracket) from a e36 to replace my boxed 4in. Also, anyone found any really great sounding 5in front/footwell speakers? The ones I got still sound muddy :S Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted May 8, 2012 i have some of the premium audio 5.25" speakers for the rear of the e36 . you could make the adaptor out of 20mm thick mdf or plywood Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 8, 2012 (edited) i have some of the premium audio 5.25" speakers for the rear of the e36 . you could make the adaptor out of 20mm thick mdf or plywood I tend to buy things rather than make em, i'm not very gifted in the making stuff department as it often involves blood and swearing Ooo Just had an Idea... Buying 6.5in speaker rings and mounting them Underside the speaker holes - that would work right, and just use self-drilling screw thingys to hold it in place though the factory screwholes? E.g. http://www.supercheapauto.co.nz/online-sto...403#Description Edited May 8, 2012 by m2geek Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted May 8, 2012 should be easy something like this to replicate these Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 8, 2012 should be easy something like this to replicate these Jeez, make it look easy why don't ya Quote Share this post Link to post Share on other sites
///MPROVD 131 Report post Posted May 8, 2012 Jeez, make it look easy why don't ya dont put 6x9 plates there either do what brent suggested or just by very good 4 inch speakers and if the are going to be run through an amp run only high frequencies through them as for the front with some modifications the foot well can fit 6 or 6.5 which is what ive done in both of my e36 and im very impressed with the sound quality.head unit-sony gt700ui front-6.5inch soundstream sst6.5pro back-soundstream 40 rms fusion am41200 amp fusion 12inch sub amp runs sub and front speakers front speakers are most vital the speakers can handle the full power of the amp in a rms or true wattage level running the rear through amp was not necessary as the stereo provided that power well but to have 6x9 would help but i found that 4inch speakers run well but headunit well need to be set to higher frequency's to pass not low or bass Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 8, 2012 dont put 6x9 plates there either do what brent suggested or just by very good 4 inch speakers and if the are going to be run through an amp run only high frequencies through them as for the front with some modifications the foot well can fit 6 or 6.5 which is what ive done in both of my e36 and im very impressed with the sound quality. head unit-sony gt700ui front-6.5inch soundstream sst6.5pro back-soundstream 40 rms fusion am41200 amp fusion 12inch sub amp runs sub and front speakers front speakers are most vital the speakers can handle the full power of the amp in a rms or true wattage level running the rear through amp was not necessary as the stereo provided that power well but to have 6x9 would help but i found that 4inch speakers run well but headunit well need to be set to higher frequency's to pass not low or bass Hey thanks for the info I've been investigating some "high end" 4in for the rear and some good component speakers for the footwells and just replace the tweeter in the front doors. I have an Amp waiting to put in along with a tasteful sub - i'm not after pure Doof doof. These are the speakers and headunit i'm likely gonna get: 5in front speakers: http://www.parallelimported.co.nz/car-audi...0-speakers.html 4in rear speakers: http://www.parallelimported.co.nz/car-audi...i-speakers.html Headunit: http://www.parallelimported.co.nz/car-audi...-head-deck.html My current JVC headunit has terribad audio configuration and amp/sub control. Quote Share this post Link to post Share on other sites
MD13 526 Report post Posted May 8, 2012 (edited) Bear in mind ibboostn said 'with some modifications'... If you just want to drop better speakers in the front factory mounting position without having to work at making them fit then your better off getting 5 1/4 inch components. Maybe something like this: Link If you don't mind getting the tools out then 6 or 6.5 inch would have a little more range. Edited May 8, 2012 by MD13 Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted May 8, 2012 (edited) they also have these as a factory option in the e36's 5.25" with or without a seperate tweeter mounted to them. also set that have been modified Edited May 8, 2012 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 8, 2012 they also have these as a factory option in the e36's 5.25" with or without a seperate tweeter mounted to them. also set that have been modified These are what I am after - but do you think I can find any for sale? LOL I just really dislike the way 4in speakers sound :S Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted May 9, 2012 These are what I am after - but do you think I can find any for sale? LOL I just really dislike the way 4in speakers sound :S have some for sale021433600 Quote Share this post Link to post Share on other sites
m2geek 4 Report post Posted May 9, 2012 have some for sale 021433600 Just text ya man Quote Share this post Link to post Share on other sites
MilesP 13 Report post Posted July 4, 2012 These are what I am after - but do you think I can find any for sale? LOL I just really dislike the way 4in speakers sound :S Any chance that you have more than one lot? I could be keen as well. Quote Share this post Link to post Share on other sites
