ED1RTY
How much oiL??
Need to know how much oil a E30 medium case diff takes.
Also need to know the tightening tourqes for the bolts on the rear cover on the diff.
Cheers
Chris
Cheers
Chris
fill oil until it just starts coming out of the upper filler plug. Manual says 1.7 litres but I don't know if this is for small or medium case diff.
Torques.. 29-36 lb ft
Edited by will
For E30 medium and small case i've used a bottle (quart / 1L) of Redline MTL and that works fine
torques?... FT man. FT.
Hey, you need to uplift yourself like Gus did and chuck the hammer and get a torque wrench.. :blink:
After all, you know what the FT attitude did to your ball joints.. :D
hah I know - I just figured Gus hadn't been brandishing his hammer and FT talk enough. It needed to get out there.
Guest Denny Crane
Gus and I ruined a Cherokee's interior after Andy's diff leaked everywhere! That is not a smell that will ever leave.
Hahahaha! It's good to see a diehard BMW man using imperial measurements!
add to that Horsepower figures and 15 17 0r 20 inch rims
sh*t it won't long before I've talked all you guys into swapping a "350 cubic inch V8 and 4 speed" into your cars
and us convince you to put a chook motor into your Camaro..
I was thinking about bolting a Holley carb and Mallory twin-point distributor onto my "3 Series 170 Cubic inch" E36 coupe, But the Damm thing aint got anywhere for the Dizzy to go!
A 9 inch with 4 link rear, that requires those coil spring thingys [whats wrong with leaf spring and tramp bars]
Sh*t it sounds like I spend waay tooo long on the Ford Mountain at Puke' yesterday, arguing with some Holden F**kwit about how racing has never been the same since 'Brocky' stopped racing Fords [it was an interesting conversation Hahaha!]
