bimmerbaz 1 Report post Posted May 17, 2007 Has anybody done this to an E30 with good results. Would be keen to see some pics and find out pros and cons. Cheers Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted May 17, 2007 Has anybody done this to an E30 with good results. Would be keen to see some pics and find out pros and cons. Cheers For us people who dont under stand BMW talk (the minority), What engine is it?? Thakns Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted May 17, 2007 the 2.8 L from an e36 or z3 or e39 would be an awesome swap, esp with the alloy block. go in a 328i e36 manual, they go pretty well so in a lighter car it would be super cool...its mainly the torque that makes that difference search e30tech and r3vlimited.com, heaps of US guys have done it Quote Share this post Link to post Share on other sites
m_power 0 Report post Posted May 18, 2007 (edited) I found this write up on the net and it seemed pretty good. Here is the write up, everything you need, good luck. First I would like to give a word of advise to anyone doing this swap. If your main goal is making your E30 fast, do not do a 2.5L swap. Trust me you will be disappointed. In my opinion the smallest engine you should put in your E30 is a 2.8L M52. The simplest and probably most economical engine to swap is a 3.0L S50 engine out of a 95 M3 primarily because it already comes with most of the OBD I hardware you will need for the swap. The only problem with 95 S50 motors is that they are becoming old and it is very hard to find one in good low mileage condition for a reasonable price. You might want to consider an option of building a high compression 2.8L engine that will perform on par with a 3.0L and cost less. One good way of building a low budget high performance 2.8L is purchasing a 2.5L M50 engine out of a 525I (so you can get your oil pan) and stroking it. There are plenty of 2.8L core engines out there for as little as $200. One trick of making it high compression is reusing the 2.5L pistons (only if in great condition with new rings) with 2.8L rods and 2.8L crank. The combination will give you a compression ratio of around 11.25:1 according to my estimates. With M3 cams (ether 3.0L or 3.2L) the engine dynos at around 240-250 crankshaft horsepower with stock injectors. Upgrading injectors would probably make even more power because the engine leans out and stops making power after 6200 rpm. One downside to this high compression is you have to use the best gas money can buy. Sometimes in hot weather the engine will ping even on a 91 gas so if 92 or higher octane gas is not available in your state you probably shouldn’t consider this option. Things that need to be modified: Brake Booster: Use an E21 320I brake booster. Some people use 325IX brake boosters but 320I boosters are cheaper and allow you to use your stock master cylinder. Note how the fins are ground down to clear the brake booster.To make the 320I brake booster work in your E30 you will need to cut the shaft off to the same length as your E30 booster, grind it down to the same thickness and thread it with a 10X1.5mm dye. Be careful here, if you screw it up you will need to go out and get another booster, the shafts are non replaceable. Don’t forget to grind off some of the fins on the back of the intake manifold to clear the brake booster. Transmission: There is a bunch of different transmissions you can use in this swap. Some people keep their E30 Getrag 260s but it requires fabricating a custom transmission mount and your shifter will be offset to the right by about 15-degrees. My favorite transmission to use is S5D320Z out of a 95M3, 96-00 328 E36 E46, 96-99 M3. The reason I like them best is probably the fact that you c+9+an use a 135mm guibo on them and they are rated for 320hp, which should give you plenty of room if you are planning future modifications. S5D320Z transmissions are not the lightest but they are the strongest. You can use your stock 325 or 91 318I IS transmission mount with any E36 transmission. Don’t forget to use E21 320I transmission mounts (they are stronger then e30 or E36 mounts) and weld two cups to the transmission mount to prevent the engine and tranny from moving around too much and hitting the radiator (see pic). Transmission Mount Reinforcement. The shifter arm has to be out of an E36 328 or M3 along with the aluminum arm that connects to the top of the tranny. Drive shaft: If you are using a ZF S5D320Z transmission you will have to use a drive shaft out of an E30 M3, 98 M3 (U-joint type only), 87-88 325E or 96-98 E36 328. Use the E30 center support mounted backwards on E36 drive shafts. Clutch: The ultimate clutch is of course E36 M3 but some people on the budget use an E36 328 clutch (it is the same diameter as M3 clutch). Those who use a 328 clutch can also use a flywheel out of an E46 323I or a 2.8L Z3. It is virtually identical to a 328 flywheel but lighter. Firewall: Cut some of the insulation off the heater blower motor cover. Some people strip it completely but I take a long knife, put it parallel to the firewall and remove some material. Do not get rid of the rubber drain on the passenger side of the firewall that drains the water from the wiper motor compartment or you will end up with water in your spark plug holes every time you wash the car. Bend the heater pipes towards the driver’s side of the car and down about an inch to clear the intake manifold. Engine mounting: The engine can be installed completely assembled with all accessories except the front harmonic balancer, A/C bracket or A/C compressor. I prefer to install the engines completely stripped since it makes it easier to connect the heater hoses . For the aluminum mounts you have to use the E36 arms. The rubber mounts are out of an E24 E28 (part number 11 81 1 132 793). The mounts have to be mounted in the outside mounding holes of the sub frame. Note the aluminum spacer under the engine mount.It is a good idea to reinforce the sub frame if you are using a 3.2L motor. Some times the engine mounting points rip out from a lot of torque. Cooling System: The radiator has to be out of an 88+ 325 E30. Some people use E36 radiators but if you plan on using a mechanical fan E30 radiator will give you more clearance. Speaking of clearance it is very important to reinforce the transmission mounts or the first time you slam on your brakes the fan will end up destroying your radiator. The fan clutch has to be stock E30 with a 9-blade fan. Do not use an 11-blade fan because it will give you less radiator to fan clearance. The overflow tank has to be out of an 88+ E30 as well. Don’t forget to upgrade the thermostat housing and the water pump to the metal kinds on your M50 motor. The bottom radiator hose off the M50 motor will need to be cut down to fit in E30. The top hose you can get from any auto part store. Note how little clearance there is between the fan and the radiator, only about 7mm.Just look for a long radiator hose with a 90-degree bend. The heater hoses connect the same way they were on your E30 (the long hose under the intake manifold goes to the top inlet and the short hose that connects to the cylinder head goes to the bottom inlet), do not eliminate the bypass valves (recall items). Lubrication System: The oil pan has to be out of an M50 powered E34 525I. You will also need to get the pickup tube with a gasket and the oil dipstick. E36 dipstick can be modified to fit but it will not show you the oil level correctly. Do not forget to safety wire the oil pump or at least locktight the sprocket nut. Drill a hole through the oil pump shaft and the bolt, insert a stainless steel wire through the hole and tie it up. M50 engines are known for the oil pump sprocket bots to come loose. Oil coolers are also a good idea for the track. Oil temps get to about 240+ degrees if you drive your car hard enough. A/C: Just about every town has a shop that will fabricate customs A/C hoses. When you get your engine from a junkyard try to get the A/C hoses with it. Custom hose shops will be able to connect the E36 A/C hose connectors to your existing E30 hoses. You can also get some fittings from your local hardware store and clamp the hoses together yourself. Don’t forget to flash out your system to get rid of all R12 oil. Use PAG oil only with your E36 compressor or it will not last you very long. Differential: The best ratio for 3.0L or 3.2L cars is 3.25 and the best ratio for a 2.8L or a 2.5L is 3.46. 3.25 differentials can be found in E28 525e 535I E24 635. 3.46s can be found in same cars but are more rare. The output shafts and the rear cover have to be swapped to make the differentials work in E30. You can also get a rear cover out of an M Coupe. The M Coupe covers lower the differential oil temperatures and look very cool behind your E30. Exhaust: Exhaust is truly something that should be left to a professional unless you are an experienced welder. You can use the stock E36 cats out of a 92-95 325 or M3 but the right side pipe will need to be modified to clear the control arm bushing mount. As you can see the right side exhaust pipe is still very close to the control arm bushing bracket. In this case there is only about 5mm of clearance. The O2 sensor mounting port interferes with the frame reinforcement behind the transmission mount. You can cut a chunk out of the brace to make the O2 sensor fit and reinforce the brace by welding it to the transmission mount with a couple of pipes. 96+ exhaust pipes are larger in diameter then 92-95 and pose some clearance issues. 96+ exhaust pipes are bigger in diameter on the outside but they are double walled so in reality they don’t flow more then 92-95. OEM pipes are stainless steel and a very hard to weld unless you are equipped to weld stainless steel. Stock cast iron headers from 92-95 can be used. You will need to make some 5 mm spacers for the engine mounts to raise the engine so the pipes clear the sub frame. It is also a good idea to remove the studs out of the headers and use the bolts to mount your exhaust, makes it way easier to get the pipes in there. The left exhaust pipe will need to be flattened out to clear the sway bar. You can also use stainless steel headers from 96+ E36; they look way better then the rusty cast iron headers. To use the 96+ headers buy two O2 sensor plugs from your BMW Dealer (originally install on a 98 323IS) and weld up the air injection ports. The muffler is up to you but the pipes to it will have to be custom made. Steering: When you get your engine try to get the power steering pump and hoses with it. It is a good idea to replace your rack when you are swapping the engine. The rack in an M50 powered car is almost impossible to replace without considerably lifting up an engine or dropping the sub frame, the oil pan sits very close to the steering rack. Suspension: Nothing needs to be done to suspension unless you want to improve the handling of your E30. M50 engine is slightly heavier then M20 (around 60lbs heavier). Although 60lbs doesn’t sound like much you will be able to feel it. Thicker sway bars do wonders on M50 E30s. Wiring and Electrical: The best wiring harness to use is out of a manual 93-94 325I due to its simplicity, although it is not that hard to modify a wiring harness from an automatic car or a car with traction control and EWS. The process is as simple as laying the harness out on a table with a diagram in front of you and eliminating anything that is not necessary. If you ended up with a harness out of an automatic car simply cut all of the wires out of the engine harness that belong to the automatic transmission computer. Automatic transmission computer is wired directly to the engine computer harness; the only wire that needs to be modified is a “brown/black wire pin 26 transmission ECU†need to be connected to any “red/white wire on the main relayâ€. ECU has to be out of a 93-94 325I with the Bosch part number ending in 413. You can use an ECU out of a 95 325I or a 95 M3 but you will need a special chip that eliminates EWS. To make the E36 harness plug in to your E30 you will need to make an adapter. To make an adapter you will need to get a wiring harness connector off the E36 (body side) and an engine harness connector off an E30 (engine side). See the excel spreadsheet for pin assignments. The coolant temp sensor for the ECU has to be out of an E36 and the coolant sensor for the temp gage has to be out of E30 (single pin sensor brown). Alternator has to be out of any 6-cyl E36, I prefer to use 80AMP alternators but if you have a powerful stereo you might consider using a 140AMP alternator (it will suck up more engine power though). Starter has to be out of any E36, Z3, E46 323 328, E34 E39 or E30 318is. Don’t forget to the engine ground strap, with M50 engine it mounts on the passenger side of the car. E30 Wiring harness connector Color 91 318is Color 325I IS E36 Wiring Harness Connector Color (body side) (engine side) Pin 1 (alternator charge) blue blue Pin 25 blue Pin 4 (coolant tem) red/white brn/violet Pin 12 green/gray Pin 5 (oil pressure) brn/green brn/grn Pin 23 green Pin 6 (Diagnostic Connector) grn/wht grn/wht Pin 22 Grn/wht Pin 7 (Ignition switch) green green Pin 21 green Pin 8 (fuel consumption) white wht/black Pin 24 wht/black Pin 9 (engine speed) black black Pin 20 black Pin 12 (check engine light) brown gray Pin 8 gray Pin 13 (fuel pump) grn/violet grn/violet Pin 13 grn/violet Pin 14 (speed signal input) black/wht black/wht Pin 14 black/wht Pin 15 (starter thin wire) black/grn black/grn Pin 15 black/yellow Pin 18 (starter thicker wire) black/yellow black/yellow Pin 18 black/yellow Oil Level Sensor Pin 10 Blue Pin 16 Wht Pin 2 Gray/Grn Note: Wiring colors can vary depending on model and year of your E30 and E36 wiring harness. On 325E the fuel consumption gage signal and the tach signal connectors are in the glove box. Speed signal wire from pin 14 E36 connector has to be connected directly to the green plug on the back of your instrument cluster. Thin (black/yellow pin 15 E36 connector) wire that goes to the starter can be left disconnected. The starter will still work. Edited May 18, 2007 by Bavarian Boy Quote Share this post Link to post Share on other sites
Guest Denny Crane Report post Posted May 18, 2007 Once I get off my ass and collate all the info I have, i'll post it. Quote Share this post Link to post Share on other sites
bimmerbaz 1 Report post Posted May 18, 2007 Interesting, the more stuff i read the more you get confused. As far as i can see the standard m52 is about 141kw . An m20 325 is 110kw so if i tweek the m52 it must be worth it . Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted May 18, 2007 m20 2.5 is 120kw, around 169hp m52 2.8 is 193hp not huge, my m20 is prob around 180-190, but cant hang with 2.8 e36, even in a heavier car m20 - 222nM or so m52 - around 280 nM its all low down in the rev range where e36's pull, when its up high its pretty even m52 in e30 would be super tough with alloy block its not much heavier either, if any Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted May 18, 2007 My m52 2.8 is churning out 168 flywheel kW with NO internal mods, cams and inlet should see 190kW, By the way it is in an E36 chassis which is a MUCH nicer chassis. Can't see the point of dicking around and putting a good engine in an ordinary chassis when you can get a decent E36 for probably less than the sum of the bits and labour true point, but e30s are badass recently heard of a certain members new car, 328i manual, NZ new, around 7k....long way from home though Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted May 20, 2007 What ever badass means in your language my usual translation is "subjective crap". Yes E30's look nice but they were never a good chassis in their day except the M3. The E36 on the other hand is a very good chassis that can be worked even firther into a great chassis - get a decent amount of power into one these and they are serious fun. ASK the guys in Clubsport Commodores that get passed or Flash Falcons that fall off the road trying to get away from a standard looking sedan. is that why both myself and a manual e36 2.8 are doing exactly the same times around taupo track? im hardly highly modified, running on 205 street rubber. not knocking e36s they are good cars, but not really that masty worthy in terms of being a great chassis Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 20, 2007 What do Commies and Falcons have to do with anything? E36 is not a great chassis...e46 is. M52 into e30 is a good idea its a good strong engine in a light chassis, wheres the down side? fwiw according to what I have m10-83 kg m40 83 kg m42 100 kg m20 117 kg m50 136 kg m52 118 kg m54 126 kg s50 152 kg Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 20, 2007 Bare in mind at all times while reading US forums that they are left hand drive and their s50 is more than likely to be the s50b30US .. which is and entirely different engine to the s50b30. It can get really confusing sometimes what information your actually reading. Quote Share this post Link to post Share on other sites
m325i 724 Report post Posted May 20, 2007 I reckon! Whats the difference between a e30 m3 chasis and normal m3? E36 chasis is nothing to spank over. While e30 chasis may have some weak points, whats the problem with it? e30 > e36, everyone knows this Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 20, 2007 (edited) Figures for euro s50 not s52 Josh.s50US=m50, s52 = m52 (US iron block). E30 isnt better than e36 just not as bad as some think. E46 is a much better balanced car.E90 probably even better again. Just too many interfering electronics with post e36. Edited May 20, 2007 by westy Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted May 20, 2007 badass .... someone or something who is so cool that their very presence is radiating with awesomeness. Awesome to an extreme level, thereby leveraging unquestionable authority. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 20, 2007 Figures for euro s50 not s52 Josh.s50US=m50, s52 = m52 (US iron block). E30 isnt better than e36 just not as bad as some think. E46 is a much better balanced car.E90 probably even better again. Just too many interfering electronics with post e36. sweet .. just warning folks when reading US forums things dont always apply to us. Quote Share this post Link to post Share on other sites
Guest Denny Crane Report post Posted May 21, 2007 What ever badass means in your language my usual translation is "subjective crap". Yes E30's look nice but they were never a good chassis in their day except the M3. The E36 on the other hand is a very good chassis that can be worked even firther into a great chassis - get a decent amount of power into one these and they are serious fun. ASK the guys in Clubsport Commodores that get passed or Flash Falcons that fall off the road trying to get away from a standard looking sedan. Oh goody, i've been looking to call you a wanker for a very long time. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 21, 2007 Like masturbating with a cheese grater.... slightly amusing but mostly painfull Quote Share this post Link to post Share on other sites
Jonty m50e30 0 Report post Posted May 21, 2007 In my opinion, The m52 conversion would be a very nice transplant for an e30, the m52b28 is 193bhp and about 20kgs lighter than the 192bhp m50b25, the 52 however is vanos equipt which improves the torque curve quite dramatically providing better power delivery, there is some debate however in high reving situations such as a race car that the cast block of the M50 is more durable and vanos is a problem you don't need. Of course an s50/52 would be a better swap as suggested in the article but firstly find one in NZ and then pay for it, the M52 is a much more feesable swap. As for the chassis the e30 can be made to be a sensationally handling little car likewise the 36 I am not sure why we would be debating this? At the end of the day an e30 can be modified to handle pretty much anything most drivers are capable of on public roads, to really discover any shortcommings in the e30 chassis I would imagine that the race track would be where this is apparent, and then of course you have to remember that the car and design is at least 16 years old (mine is 24 years old). I am happy to help with any info on the m52 swap as the same principles apply to the m50 it would be great to see this conversion done. I also have a M52b28 in an e46 and am pretty satisfied with the performance in a heavy car. Oh and as the article says don't expect a fast car with a 2.5 conversion, I'll have to disagree with this, mine is fast enough to scare the shite out of me sometimes - or is that the poor driving - i'm not sure. Quote Share this post Link to post Share on other sites
