hybrid 1045 Report post Posted July 20, 2007 e30's and stretched tires. Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted July 20, 2007 I would of done it if i could of found some super deep dish bbs 16s, and the price Quote Share this post Link to post Share on other sites
Mavrick 0 Report post Posted July 20, 2007 What width would their rims be at the rear? Why does no-one do this over here? Is it because NZ regulations stop us? And final questions does alot of work go into fitting them uder the guards? Cheers, Mavrick Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted July 20, 2007 Because its soooooooo expensive! they are most likely 10inch on the rear with 205 or 195 tires. Also NZ regulations say we cant have the wheels or tires over the edge of the factory guards. Alot of fender rolling, hard suspention etc. Makes for bad handling but looks awesome! Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted July 20, 2007 haha awesome, im due for new tyres too!! Getting stretched 195s and 20mm spacers .. hopefully will look better than the 205s.. not that stretched though Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted July 20, 2007 yeah its fairly easy to do ... The e30 is running 18x8.5 with 225's on it .. a mild stretch .. 195's would give the same effect as above. The 2nd set of LMs I just took receivership of are 18x8.5 front and 18x9.5 rears (will run 245 instead of 265) should be enough rubber .. (yeah right ) video of how its done or how the n00bs do it Quote Share this post Link to post Share on other sites
nz320i 0 Report post Posted July 20, 2007 Haha both ways look pretty half ass.. I guess its the only way- pretty extreme stretching going on.. ahh wish my rs's were 8.5 or something Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 20, 2007 Chris (the Muss) has pimp stretch. Love the n00b stretch way haha Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted July 20, 2007 meh, not a fan. more rubber is good if needed Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted July 20, 2007 (edited) N00b method looks hella more fun although that high-pressure gun job looks like a pretty badass toy aswell. Edited July 20, 2007 by bravo Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted July 20, 2007 (edited) 195 tire on a 9" rim ...why ? I would like 345 rubber on a 10.5 rim My Z31 comes with 225 rubber on a 6.5 rim as factory For skinny rims the tires look nice and fat ! Is there some reason for stretching tires ? I hear bits about autocross drivers do it for handling reasons for less give in their tires and more control or something .... Edited July 20, 2007 by Jimmy Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted July 20, 2007 Aesthetics. That is all. And it looks hot. Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted July 20, 2007 (edited) And it looks hot. nah. (There are exceptions though) Edited July 20, 2007 by Mike Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted July 20, 2007 Aesthetics. That is all. And it looks hot.My understanding was that it started in Germany because there was a restriction on the size of the tyre you could run on a car, but not the size of the alloy. Quote Share this post Link to post Share on other sites
Dnz 0 Report post Posted July 22, 2007 Aesthetics only if it doesnt affect handling negatively. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted July 22, 2007 Only if you care about handling. I do, but as we know, the majority appear not to (eg cars with no springs etc) Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted July 22, 2007 both of those cars have serious camber problems....serious wear on the innside..gosh i thought 235 on 8.5 was a bit too small Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted July 22, 2007 I have 205/40/16's on 16x9, Looks all good but no good for the rims or tyres for that matter, especially on the rear, camber + stretch = owned sidewalls. Im getting new tyres in a month or so once my H&R's go in, will be running 205/50/16 Direzza's still stretched but with more suspension travel, and the handiness of my camber adjusters I shouldn't have any issues with abnormal tyre wear Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted July 22, 2007 The other thing about the spring change, Chris, is depending on your current springs, the H&R's should be harder. This means you won't hit the bumpstops except in rare cases. With my old springs hitting the bumpstops was a daily occurence - that much suspension travel at speed = even more severe tyre wear. There's a really good article somewhere where a guy goes through all the calcs step by step for e30 trailing arm suspension with graphs showing how ride height affects camber and toe. Basically 1deg of rotation of the trailing arm equals for all intents and purposes 1 deg of camber Toe increases as the trailing arm swings both upward and downward of neutral. A 20mm increase in ride height will equate to almost 1 deg reduction in neg camber from memory. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted July 22, 2007 That is what im hoping for. At the moment with the camber adjusters on no adjustment there is around 4.5deg negative camber. I can take it in to 2.5deg negative camber with the adjusters at full tit. Raising the car 20mm will hopefully reduce this to 1.5 deg which is about right. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted July 22, 2007 ....serious camber problems.... ..gosh i thought 235 on 8.5 was a bit too small heheh wash your mouth out! ... but yeah they are running race car type camber and eventual tire wear would be a problem. 235 is the perfect size for 8.5 215 is starting to stretch on 8.5 the e30 is running 225 on 8.5 with no issue. All this depends on the tire manufacture, EG a 235 continetial sport is different from a 235 dunlop derezza tread / sidewall wise, by about 1 inch. Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted July 22, 2007 fugly Quote Share this post Link to post Share on other sites
Driftit 2173 Report post Posted July 24, 2007 The Japs have been doing this for many a year in the drift scene. The main reason is to make the tyre sidewall extreamly hard. So there is no tyre roll at all. It has nothing to do with looks. Looks are the last thing a drifter gives a crap about. Most of the guys you see driving around on the road in NZ that have stretched tyres however are doing it just to get that drift look. And sometimes to actually get the tyres under the gaurd due to the low or negative offsets on their wheels. The Japs will laugh at anything under 9 wide. And big fat ugly tyres look sh*t on narrow rims. Quite often I walk past a car with "Massive" 8 inch wide wheels with horrible looking 255/45's. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted July 24, 2007 hence my problem with old man tyres.. their shape is out dated Quote Share this post Link to post Share on other sites
