topcat
e28 tuning finished
finally got the time to take the car for a finer tune this morning.
nice numbers;
fun to drive
pain in the ass uploads;
nevermind it probably me
enjoy
**hybrid edit: fixed
Nice Work!! ~280rwkw
I figure that is 14lbs of boost that is being logged on the bottom graph & AFR??
On a stock M30 bottom end??
What gear was that pull in? 4th?? Reving it to??
yeah that's the boost and the blue line is the AFR.stock
quite a nice boost curve,wasnt expecting that.bit rich still though,safety factor i'm thinking
4th gear,6200 rpm. 3rd gear pull netted 1000+ nm.seems alittle OTT :unsure:
Guest Rick James
badass....i look forward to turbo races!
Dude you're as as bad as beau dropping hints that you have an iS
uh..no ^^
i have the iS power
haha im not that bad.
am i? oh dear. awfully sorry chaps
yes , nice results , when do get to drive it .
ian reckons he going to have to buy a plane now to keep up ( i said make it a jet )
watch out i might do this soon
or this
this is you to a tee in your red wagon
those air horns must be at least 30kW of the 280 at the wheels
The M30 suits fi, those figures for a quick tune are fantastic.
Intercooler must work, pity the project didn't suit/or work out.
Are you building a replacement Topcat??
in a short answer;YES
3.8L,lightened crank,bigger valves,forged bits,etc,etc.
should up these numbers to shame. new under-ware on order
only hold up is $$.selling what i have will help :)
Start up a fund on Bimmersport for the project! "Save the Topcat fund" please donate all loose coin.
Have you seen this dudes cars in the states? E34 turbo + E30 M3 shell Turbo, both M30 engines.
http://www.europeancarweb.com/features/040...uner/index.html
yeah hav had contact with him through verious forums.
interesting setups.big $$'s spent.but apparently very drivable at all speeds.
an awesome effort,we'll see if i can get my e34 to purrrr, this year
Twin Turbo??
Twin Turbo??
Na,too many dramas for me,let alone the cost.
double everything.
No this time spending on tubular manifild,new intake system, gt3582r turbo,forged pistons(custom)
lightened crank,bigger valves,warm cam,methonal injectors, 3.8 block. plus afew other tricks.
could be fun.
Edited by topcat
More useless info, the E34 Alpina Bi Turbo even had gearbox/diff oil coolers mounted in the rear bumper.
Thats quality work.
