$toffz 0 Report post Posted October 19, 2007 Hi Folks, Trawling through the threads the other day and I saw a post by someone in regards to being stopped at the lights and leaving the car in D while just putting your foot on the brake and that this is totally bad for the torque converter? If so whats the right way to stay at the lights for a prolonged period of time? Put into Park? Neutral? Cheers Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 19, 2007 (edited) Not "bad" just increases heat and wear on components and fluid life. Neutral and park are fine. Edited October 19, 2007 by bravo Quote Share this post Link to post Share on other sites
Yuen 16 Report post Posted October 19, 2007 I am not sure how true this is but I have heard that constantly changing gears from D to N will also wear out some other bits in the gearbox. IMO the car would have been designed from the factory to run in D for short stops so I wouldn't worry but no doubt that it will be easier on the engine and gearbox if put into N. Should save some petrol but should be negligible. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted October 19, 2007 I am not sure how true this is but I have heard that constantly changing gears from D to N will also wear out some other bits in the gearbox. IMO the car would have been designed from the factory to run in D for short stops so I wouldn't worry but no doubt that it will be easier on the engine and gearbox if put into N. Should save some petrol but should be negligible.well put Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted October 19, 2007 Lies - it is better for the car in D Quote Share this post Link to post Share on other sites
nath 183 Report post Posted October 19, 2007 Lies - it is better for the car in D Thankyou andrew- auto gearboxes are best left in D. it is recommended that autos arent run in neutral or park for very long at all. fact of life Quote Share this post Link to post Share on other sites
