Murrayc 1 Report post Posted October 22, 2007 Has anyoneone attempted replacing the rear sub frame bushes that can offer advice. Quote Share this post Link to post Share on other sites
hybrid 1044 Report post Posted October 22, 2007 Basically its a solid weekend and a bit job .. you also need to have the car suspened on the chassis remove the diff / trailing arms / half shafts etc etc.. then remove the subframe ... press out old bushes ... press in new ones .. re-install and done. If you haven't done it before I would get someone to atleast give you a hand on a couple of points (removing the diff etc etc) Chris on this site recently did this on his e30. You'll need good solid axel stands too hook on the chassis and a decent jack. + a couple of sets of sockets. You'll also be draining the brake fluid so youll need a brake bleed kit. it might take a professional with all the gear and hoist a lot less time however. Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted October 22, 2007 You don't need to do that. Unbolt handbrake cables and solid brake lines & exhaust (unless you want to try work round it) Unbolt the subframe and top diff to car bolts. Unbolt driveshaft from diff. Lower whole subframe with diff and everything else still bolted on (45 mins tops) Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted October 22, 2007 it's all pretty straight forward until you actually come to removing the bushes from the subframe and pressing the new ones in! Quote Share this post Link to post Share on other sites
Murrayc 1 Report post Posted October 22, 2007 Thanks for that info. Thought it was a bit of a major. I'm also doing trailing arm bushes, diff, and a set of IE sway bars. Hopefully give me some added performance around the track. Any suggestiosn on how to remove the old sub frame bushes. I understand one method is to melt them out, or would a good press do the job. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted October 23, 2007 it's all pretty straight forward until you actually come to removing the bushes from the subframe and pressing the new ones in! did you not learn your lesson with fire ollie? its easy! Quote Share this post Link to post Share on other sites
Jonty m50e30 0 Report post Posted October 23, 2007 A press is fine if you can get it to your subframe or the other way round I just burnt mine out with a gas torch, if you replace with poly items or similar then you often do not need to press them in I didn't with the powerflex ones, it is a whole lot easier to drop the whole frame diff etc included - it is a good few hours to do the job by yourself with a hoist though, i couldn't get the bloody subframe to drop out took a bit to work it loose. Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted October 23, 2007 Any suggestiosn on how to remove the old sub frame bushes. I understand one method is to melt them out, or would a good press do the job. As gus says - fire is the most fun, most environmentally harming AND best way to get high. Do it that way. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted October 23, 2007 Yup done mine, Fight them with fire. I took the whole rear out and stuck in a new diff, billet sway mounts, adjustable endlinks and some other little bits and peices. Definatly a well worht it upgrade. Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted October 24, 2007 Watch out you might get what youre after cool babies strange but not a stranger i'm an ordinary guy burning down the house hold tight wait till the party's over hold tight we're in for nasty weather there has got to be a way burning down the house here's your ticket pack your back: time for jumpin' overboard the transportations here close enough but not too far, maybe you know where you are fightin' fire with fire all wet hey you might need a raincoat shakedown dreams walking in broad daylight three hun-dred six-ty five de-grees burning down the house it was once upon a place sometimes i listen to myself gonne come in first place people on their way to work baby what did you expect gonna burst into flame my house s'out of the ordinary that's might don't want to hurt nobody something sure can sweep me off my feet burning down the house no visible means of support and you have not seen nothing yet everythings stuck together i don't know what you expect starring into the tv set fighting fire with fire Quote Share this post Link to post Share on other sites
