tibbs.james 1 Report post Posted March 31, 2008 (edited) Once Again Im at the suspension renewal thing... I have Rear shock mounts & Subframe bushings & Control Arm Bushings to istall. The shock Mounts wont be that tough. Control arms will be cake once the subframe is out of the car. But I have numerous questions about the subframe removal/refitting 1. How do i have the car on stands ? ( I normally put axle stands under the crossmember ) 2. Does the diff need to be removed or can it stay on there while the subframe is lowered down ? 3.Should i remove the control arms before or after i lower the subframe off the car ? 4. I can see to remove the subframe there will be some brake lines/fitting that need to be undone along the way, how do you keep these plugged up/not leaking all over the place while they are apart ? If you have done this please comment on ways how you did it and what worked for you i am keen to hear as i would like to do the whole job in one weekend as i need my car to get to CPIT on Mon/Tue/Weds I have acess to all tools / stands / nice big jack & decent garage. But if you feel like helping out for a box of your favourite beer that would be cool too. Any help appreciated. Regards James Edited March 31, 2008 by Jimmy Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted April 1, 2008 you can use the very rear of the chassis rails or the jacking points to hold it up. Remove the rear struts and springs unbolt the driveshaft from the diff and the circular rubber diff mount bolt. Unbolt the subframe bolts under the rear seat and the plates from the rear of the sill. You can drop the entire rear assembly at once including subframe with diff and trailing arms attached. You will need to take the drive shaft out if it's a pre facelift because as you lower the subframe it will catch on the drive shaft and the drive shaft will catch on the fuel tank pipe. Remove the Trailing arms after the subframe assembly is out. You will need to get all of the old bushes burnt or pressed out and the new ones pressed in. Brake lines - completely drain the system first, and give it a full bleed upon reassembly a good excuse to fully refresh your brake fluid. Don't forget to unbolt the handbrake lines from the handbrake lever before you drop the subframe. Assembly is the opposite to removal. When bolting the half shafts up to the diff make sure that they are f**king tight and check the rubber boots for splits, it's also a great time to drain and renew your diff oil. Other things to check whilst subframe is out is bearings, rear disc thickness and wear, handbrake shoes, brake lines and pads. Hope that helps Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted April 1, 2008 Thanks heaps Ollie I think you just saved me a whole weekend worth of swearing and frustration. Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted April 1, 2008 I need to do this once Ive got me a bit of money, got a bit of a clunk in the rear end and its probably easier to just replace all the rubber etc back there at once Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted April 1, 2008 (edited) You'll still have most of a weekend of swearing and frsutration, LOL. I reckon you should undo the bolts on the half-shafts while the subframe is on the car, so you can use the handbrake to hold them still. Don't forget to undo the speed sensor wire from the diff. And it's worthwhile getting PB Blaster or equivalent and spraying it on everything you want to remove a day or so before you attack it with the tools. Edited April 1, 2008 by CamB Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted April 1, 2008 (edited) I removed the whole assembley as one- subframe, trailing arms, diff, and halfshafts. getting the old subframe bushings out is a pita without a press, hope you've got one. T/A bushes aren't as bad. edit - shoulda said without Edited April 1, 2008 by Mike Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted April 1, 2008 getting the old subframe bushings out is a pita with a press, hope you've got one. T/A bushes aren't as bad. yeah the sub-frame bushes are a MEGA PITA. I took my sub-frame in to a suspension shop to remove the old and fit the new bushes - they said even with a hydraulic press they had a nightmare and had to use heat Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted April 1, 2008 Yeah - I have access to an engineering shop with a Gas axe and a hydraulic press Same guy that did my front ball joints. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted April 7, 2008 I'm Just about to start, have car up on stands ect, have spayed CRC Penetrate everywhere. I'm at the remove shocks and springs stage- how do i get to the shock mounts as i have no idea how the rear parcel tray comes apart. I have broken far too many pieces of trim on other cars removeing stuff that i really don't want to bugger it up. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 7, 2008 (edited) Open the boot and remove the side covers, right in front of you, 2 x 13mm nuts each side. I've done three rear subframe rebushes now and have found it relatively easy to press the bushes out in a small hydraulic press. Trick is not to rush it, let the press push the rubber out slowly, stops you from ripping the centre of the bush out. Edited April 7, 2008 by Silver Fox Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted April 8, 2008 Help !!!! How in the heck do i remove this handbrake cable so i can remove the subframe ? I removed the rear brake shoes & undone the 2 bolts that hold the bracket for where the handbrake cable enters into the wheel hub area. But after looking at the lever arm there is no way to remove the arm to push the cable back out the other end so it wont catch when i drop the subframe . So im frustration i unbolted exhaust headsheild to reveal the driveshaft thinking i could undo it a bit futher back but i can't see a way to do that either ! again im totally lost here so advice is well appreciated. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 8, 2008 get in the car and remove the handbrake surround, then undo the 2 x 10mm nuts that hold the cables in the handbrake, one each side, and pull thru from under the car. They stay with the subframe. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted April 8, 2008 Thanks David, didn't realise it would be so simple. on every other set of rear brake shoes I have ever seen you can unclip the inner cable and just push it & the outer away from the wheel hub area and bobs your uncle, Only I guess bmw had to make it difficult thanks for that, sounds easy enough. Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 8, 2008 Very easy Jimmy, they just slide in and out. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted April 8, 2008 I took a rear subframe assembly out in 15 minutes the other day - I'm proud. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted April 9, 2008 Getting the bushes out is the hard bit, I burnt mine out with a heat gun. Getting the s/f out is a POP. Getting it back up in one piece can be a PITA Cant seem to find my post on how I did it. Its there somewhere. Was ~10 months ago I found removing the T/A bushes the hardest part of all of it. Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted April 9, 2008 I have mine all out and apart now - has taken me like 5 hours all up to get this far. Yeah i was taking it easy & lastnights effort was frustrating with next to no light in the garage. I have done a Write up of all the steps i took incase somebody wants me to post that up. T o fully remove and dismantle a subframe assembly in 10-15 mins seems impossible to me ! Its all gone well just have to bolt it back up once i get the urethane pressed in. Cheers for the help Its great having some guideance from other members who have done similar. Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted April 9, 2008 One small thing though, You should have SOOO done I.E camber/toe adjusters!! Quote Share this post Link to post Share on other sites
tibbs.james 1 Report post Posted April 10, 2008 I don't exactly have traction or alignment problems, Rear camber is minimal even with the lowering, Uneven tire wear isn't really an issue when the current tires have lasted over 12 months and are only just showing tiny signs of uneven wear on the inside edge. It would have been worthwhile if i had bad traction/tire wear problems. I might need to do it once i do a 2.5 swap or if i had gone any lower. But money is better put towards some nice Bilsteins at the moment ED1TRY what do you drive and have you done the mod and or noticed much difference ? Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted April 10, 2008 (edited) Have a E30, Its damn low. Suspension: Boge Turbo Shortened Shocks Whiteline Super Low Springs Rear E36 billet Shock Mounts Nolathane Control Arm Bushes Urethane Rear Subframe Bushes Urethane Rear Trailing Arm Bushes Adjustable Rear Camber Setup Front and Rear Billet Sway Bars Mounts and re-enforcements Front and Rear Nolathane Sway Bar Bushes Those are my suspension mods, I had C3 coilovers with Koni Adjustables but used them as part trade on my new RS Sierra Cossy Sapphire And yes there was a HUGE improvement on handling. (considering my front sway bar bushes were melted to nothing after a certain BS cruise down Helensville Highway) Edited April 10, 2008 by ED1RTY Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 17, 2008 And yes there was a HUGE improvement on handling. (considering my front sway bar bushes were melted to nothing after a certain BS cruise down Helensville Highway) badass Quote Share this post Link to post Share on other sites
bwh1 0 Report post Posted April 23, 2008 I have mine all out and apart now - has taken me like 5 hours all up to get this far. Yeah i was taking it easy & lastnights effort was frustrating with next to no light in the garage. I have done a Write up of all the steps i took incase somebody wants me to post that up. T o fully remove and dismantle a subframe assembly in 10-15 mins seems impossible to me ! Its all gone well just have to bolt it back up once i get the urethane pressed in. Cheers for the help Its great having some guideance from other members who have done similar. Hey there Jimmy. About to do a removal and quite interested in your findings. Please flick me a run down. [email protected] Quote Share this post Link to post Share on other sites
