OLLIE 27 Report post Posted May 11, 2008 M20, manual. in this drawing number 10 (spacer ring) - what purpose does this serve? Quote Share this post Link to post Share on other sites
allan 295 Report post Posted May 11, 2008 Not totally sure but are we to take it from the picture that it is showing us both the manual gearbox/flywheel set up and autobox set up. If so the spacer would be for the auto set up to obtain the correct distance for the starter pinion to be able to engage the ring gear correctly. Just my thoughts on it. Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted May 11, 2008 just a big washer . Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted May 11, 2008 just a big washer .that was my thought exactly. My car doesn't have one. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted May 11, 2008 i believe its just there to align ring gear to starter and to provide correct spacing for the torque converter but could be wrong Quote Share this post Link to post Share on other sites
BM WORLD 1297 Report post Posted May 11, 2008 i believe its just there to align ring gear to starter and to provide correct spacing for the torque converter but could be wrongonly the manual flywheel uses them .just goes between the bolts and the flywheel as a sinlge washer instead of 6 seperate ones Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 11, 2008 Big washer like Brent says. I got one with the flywheel for the dirtysix. After talking to the flywheel machinist I didnt use it. Threw it away. Quote Share this post Link to post Share on other sites
