Five Star 0 Report post Posted June 8, 2008 Hi, I need to find a socket to tighten up the headbolts on my m20b20. Any ideas where to find one? Repco said they wanted $80 for a set which it was in, but I'm a poor student... Cheers, Tom Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted June 8, 2008 What kind of head is on the headbolts on an m20? Are they not just simply hex? Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted June 8, 2008 Well you know what REPCO stands for? Go to anywhere else that sells individual sockets - BNT, AutoOne, or any tool specialist. Expect to pay $20 plus though unless you're able to get a cheaper brand like powerbuilt. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted June 8, 2008 Put your location in. Someone will surely loan u a wrench and socket Quote Share this post Link to post Share on other sites
Five Star 0 Report post Posted June 8, 2008 That's weird, I used to have my location in... I'll be working on in the car in hawkes bay from the 20th onwards, but I live in dunedin. I'll have access to a torque wrench. Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted June 8, 2008 10mm torx socket, most likely will need a reducer from your torque wrench down to torx socket. Quote Share this post Link to post Share on other sites
Five Star 0 Report post Posted June 9, 2008 Does anyone know of a place in the Hawkes Bay that will stock the socket? Repco, supercheap and partmaster didn't stock the 10mm torx socket when I was last up. A 12mm hex worked to get the bolts off, but I won't dare use that for putting them on... Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted June 9, 2008 Does anyone know of a place in the Hawkes Bay that will stock the socket? Repco, supercheap and partmaster didn't stock the 10mm torx socket when I was last up. A 12mm hex worked to get the bolts off, but I won't dare use that for putting them on... http://tradezone.co.nz/nzmap.asp www.sulco.co.nz (they'll courier it for sure). I'm pretty sure the M20 head bolts are a single use stretch bolt, so you need to buy new ones. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted June 9, 2008 For what it is worth I got a 3/8 drive 40 and 50 Torx sockets from the Levin Branch of Repco last Friday night about $12 dollars each. Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted June 9, 2008 yes you MUST use new head bolts and a new head gasket. REPCO, SUPERCHEAP, TRADEPARTS, ETC should all stock torx socket sets - yellow pages will list other local tool stores. don't forget to buy a 1/2" to 3/8" reducer so you can use your 1/2" torque wrench with the 3/8" torx socket. read the manual properly, from memory you torque them up (in the correct order) then you do a half turn, then leave it for an hour (or some period of time) and then another half turn to finish them off. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted June 9, 2008 I got a Torx set from Ripco for ~$50 on a sale, probably still expensive. Only used one socket once in 8 months You could've borrowed them if you were closer. Quote Share this post Link to post Share on other sites
