ecko_complex 4 Report post Posted August 7, 2008 (edited) Following on from my previous thread, my car is in the process of getting a full replacement ECU and proper tuning. So this will be the tuning thread . Since my car was completed mechanically, it went into storage for 4 months while I went on a rather large holiday to Bangkok. Since I got back I've been collecting my 10c pieces in a jar so that I can make some serious power out of the setup. Since tuning is the "secret" to BMW FI I took it to the masters of tuning; NZEFI. It has been in their shop for about 2.5 weeks now and they've got the car up and running on the new ECU. For the ECU I managed to source a Link G4 before it even came out. Most importantly it does the VANOS too. The ECU mostly installed: Ignitior: Boost controller: Engine bay - intake manifold: The car has been up and running, but once there was a pressure test done there was a (slight!) leak discovered in some hose that goes from the intake manifold to the sump (don't quote me on that): As for fueling, the injectors/pump are being flow tested and will be upgraded if need be. It hits the Dyno next week for tuning, so expect an update with videos and Dyno print outs . Edited August 8, 2008 by ecko_complex Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted August 7, 2008 Link G4!?? you lucky fokker you. Was is given to you for final testing or something? Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted August 7, 2008 (edited) That box is probably an ignitor. I am interested to hear the feedback from the NZEFI guys on whether the G4 is a good product. I email Link last week and the G4 is what is now on offer. Edited August 7, 2008 by CamB Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted August 8, 2008 Also very interested, This will most likely be powering the s50b32 in the e30. Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted August 8, 2008 fantastic,glad your spending the $$ to do it properly.look forward to the numbers Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted August 8, 2008 Cant wait to see the numbers compared to mine, my car was done by NZEFI as well Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted August 8, 2008 That box is probably an ignitor. I am interested to hear the feedback from the NZEFI guys on whether the G4 is a good product. I email Link last week and the G4 is what is now on offer. Ah that's right, it is. The BMW ecu has one built in, which apparently is quite rare.I got the call today, I'm up for 6 new injectors and a fuel pump (plus rewiring the fuel pump). Apparently the 6 injectors already in the motor were barely enough for it's stock power . I think 470cc injectors are going in, no idea on the fuel pump though. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted August 8, 2008 Ah that's right, it is. The BMW ecu has one built in, which apparently is quite rare. I got the call today, I'm up for 6 new injectors and a fuel pump (plus rewiring the fuel pump). Apparently the 6 injectors already in the motor were barely enough for it's stock power . I think 470cc injectors are going in, no idea on the fuel pump though. Not uncommon for NA motor's to be running near the max efficiency/duty cycle of their injectors. 470cc isn't overly big for a 3.0L turbo motor, stock turbo 7M's & 2JZ's run 440's. One would think going as big as sensibly (tunability) possible would be the most cost effective. Especially when the bug bites you real hard and you want more power, more $$ again for injectors. Eagerly waiting to see the dyno results. Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted August 8, 2008 (edited) Not uncommon for NA motor's to be running near the max efficiency/duty cycle of their injectors. 470cc isn't overly big for a 3.0L turbo motor, stock turbo 7M's & 2JZ's run 440's. One would think going as big as sensibly (tunability) possible would be the most cost effective. Especially when the bug bites you real hard and you want more power, more $$ again for injectors. Eagerly waiting to see the dyno results. That's what I said to them, but seeing as that bug means: new turbo, external waste gate + fabrication and a thick head gasket (or better) things are going to get exponentially more expensive from here. So I think I'll be forced to leave it as is after this. Biggest problem is that I'm not a mechanic so I can't DIY (70% of the cost has been labor so far). Not to mention things in the engine bay are already tight as a nun, I've had to loose fog lights and AC... Nice car by the way . Edited August 8, 2008 by ecko_complex Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted August 21, 2008 (edited) Well here's what you've all been waiting for! A picture of the M3 on the dyno I may as well post the dyno sheet: 400RWHP and 1360 torques (what ever they may be) , and it's only limited by the clutch and turbo size. And the boost graph: NZEFI have done a ****ing brilliant job on this! Edited August 21, 2008 by ecko_complex Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted August 21, 2008 (edited) Bloody oath. That's mean. I believe a standard one only gets 260-270hp (an Evo - is yours an Evo?). Far out that must be fast. (edit - I see it's not an Evo. Awesome - more than 50% up on stock). Edited August 21, 2008 by CamB Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted August 21, 2008 Here's a little video of it doing a Dyno pull: M3_Turbo_Dyno.wmv New injectors (bright green wooo): Engine: The blue hose is the sump breather pipe that breathes air/oil into the intake naturally, but because its FI it will put pressurized air into the sump which isn't good! So it's being re-routed else where... Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted August 21, 2008 Bloody oath. That's mean. I believe a standard one only gets 260-270hp (an Evo - is yours an Evo?). Far out that must be fast. (edit - I see it's not. Awesome - more than 50% up on stock). Nah it's not an EVO unfortunatley . That's 400hp at the wheels btw, which is about 460 at the flywheel , so about 200hp more Quote Share this post Link to post Share on other sites
steve R 0 Report post Posted August 21, 2008 (edited) mmmmm Makes me wanna take the plunge! awsome work buddy Edited August 21, 2008 by 328imobbin Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted August 21, 2008 mmmmm Makes me wanna take the plunge! awsome work buddy Do it! After having to walk everywhere, having to use public transport and living on Pak'n'Save noodles I've realized it's all worth it . Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted August 21, 2008 Nah it's not an EVO unfortunatley . That's 400hp at the wheels btw, which is about 460 at the flywheel , so about 200hp more Yep! I don't think you need to worry its not an Evo. I think you've got enough powa. Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted August 21, 2008 Next problem, how well can it put it all to the ground? Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted August 21, 2008 Next problem, how well can it put it all to the ground?I put some pretty wide wheels on the back, so the car shouldn't meet a tree too soon. Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted August 21, 2008 I put some pretty wide wheels on the back, so the car shouldn't meet a tree too soon. Much traction loss in 1st or second in the dry hoofing it? Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted August 21, 2008 Much traction loss in 1st or second in the dry hoofing it?I know it's different, but it wasn't an issue before the tune (100rwhp less). Now - not sure yet, I don't get the car back for a few days. There's still a bit of tidying up to do. Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted August 21, 2008 I know it's different, but it wasn't an issue before the tune (100rwhp less). Now - not sure yet, I don't get the car back for a few days. There's still a bit of tidying up to do. I see, well good job. Awesome work you've done. Quote Share this post Link to post Share on other sites
ecko_complex 4 Report post Posted August 21, 2008 I see, well good job. Awesome work you've done.Thanks . Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 21, 2008 Great HP gains Looking good Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted August 21, 2008 Pshhh sif turbo, I'll still line you up ! So keen to see it, good effort Matt. p.s. I thought the 3.0 model came standard with 286hp? Quote Share this post Link to post Share on other sites
westy 614 Report post Posted August 22, 2008 Blimey!! Quote Share this post Link to post Share on other sites
