Venatus 2 Report post Posted October 1, 2008 When you try and jack up the rear of the car under the crossmember, if you put the jackstand on the corssmember then let the jack down, the crossmember stays up and the body of the car just comes down while the crossmember rises up into the underside of the car.... Any idea whats wrong with it? Thanks Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted October 1, 2008 I seriously don't get it - if the weight of the car is on the subframe (via the jack), and you put jack stands under the subframe as well, nothing should change (unless the subframe is broken). The only thing I can think of is if you jack under the diff, and your diff bushing is good, then the car would jack up fine. If your subframe bushings at either end were bad, then jackstands under the subframe and releasing the jack under the diff might do what you say, but only a little bit. Can you take pics? Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted October 1, 2008 Sure you aren't putting the axle stands and the half shafts? Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 1, 2008 bet he's got them under the trailing arms? Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted October 1, 2008 (edited) hey, Im not retarded haha. Ill take photos maybe friday, im busy all day tomorrow, so there probably wont be any light, but well see... Its been like it for ages, I havent bothered asking about it though, it did make replacing the external fuel pump rather difficult with nowhere to really jackstand it at the back... It used to be fine, but i noticed it wasnt about a week after the guy at mag and tire diff jacked it to replace the back tires Edited October 1, 2008 by Ven Quote Share this post Link to post Share on other sites
ED1RTY 2 Report post Posted October 1, 2008 wierd. maybe failed subframe bushings? will need pics to understand what you mean though Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted October 1, 2008 I always put my jack stands under the subframe mounts, not the subframe itself. That way there's no weight on th ebushes, and you shouldn't experience your problem. Quote Share this post Link to post Share on other sites
