tire 10 Report post Posted December 1, 2008 (edited) 1. Whats the (P) light on the dash? 2. Do I need to use any sealant / product to seal the new window seals I put in? 3. anyone got a bonnet badge in good nick they want to hook me up with? $10? See pics below. thnks edit... thats supposed to say couple in the title. editedit: 4. How do you secure the drivers floor mat? It keeps slipping around operating the clutch in so I usually go without it. Edited December 2, 2008 by tastic Quote Share this post Link to post Share on other sites
darkwolf 0 Report post Posted December 2, 2008 (edited) 1. Whats the (P) light on the dash? I'm pretty sure the (P) will be parking brake. Assuming that the (!) is for Traction Control. Otherwise it might be to say you are in Park in the gearbox (assuming you don't have a manual) Edited December 2, 2008 by DarkWolf Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted December 2, 2008 (edited) 1. Whats the (P) light on the dash? Handbrake warning light - if it doesnt work check the wire that attaches to the handbrake under the little cover in the centre console, it will probably have fallen off 2. Do I need to use any sealant / product to seal the new window seals I put in? Dont think so.. but someone else will be able to confirm this 3. anyone got a bonnet badge in good nick they want to hook me up with? $10? Try a wrecker or trade me edit: I have a bentleys manual, will check tonight for you if no one else has answered by then. Edited December 2, 2008 by SIR E30 Quote Share this post Link to post Share on other sites
tire 10 Report post Posted December 2, 2008 I'm pretty sure the (P) will be parking brake. Assuming that the (!) is for Traction Control. Otherwise it might be to say you are in Park in the gearbox (assuming you don't have a manual) I thought it was the park brake too but its on when the park brake is off. (!) is for oil pressure. Its a manual, so cant be P for Park. cheers anyway Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted December 2, 2008 (edited) (P) is to show park brake is engaged Assuming that the (!) is for Traction Control. On an E30??!!! Somehow I don't think so. Edited December 2, 2008 by gannetboy Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted December 2, 2008 (edited) Haha (P) is park brake. (!) is brake hydraulics, should go out when engine is started. If it comes on, check brake fluid. Also, the ( ) between the two is to show brake pads low. Edited December 2, 2008 by Quailboy Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 2, 2008 (edited) (P) - handbrake is on, or wire has come off handbrake light switch on brake lever. (O) Brake pad/lning wear lamp. (i) is brake fluid level (oil can) Oil pressure warning Good luck finding a good condition badge for $10. Edited December 2, 2008 by bravo Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted December 2, 2008 (!) Oil pressure warning Huh????? Quote Share this post Link to post Share on other sites
tire 10 Report post Posted December 2, 2008 The (!) is not the problem! Geez. And I'm pretty sure its oil pressure mr Kale. Must be the handbrake switch then. It doesn't look disconnected but meh I'll have a fiddle. 1 down, 3 to go Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted December 2, 2008 (P) - handbrake is on, or wire has come off handbrake light switch on brake lever. (O) Brake pad/lning wear lamp. (!) Oil pressure warning Good luck finding a good condition badge for $10. The oil can is the light for oil pressure warning, so can't be (!) as well. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted December 2, 2008 (edited) Huh????? Sorry, missed a line with the typing, realised and was editing while you were replying - man can't make a mistake around here or you get pulled up fast!!!! BTW it goes off by itself when engine is started, not when you press the pedal. Edited December 2, 2008 by bravo Quote Share this post Link to post Share on other sites
tire 10 Report post Posted December 3, 2008 So badge and (P) light are sorted... any ideas on floor mat and window seals? thnanjks Quote Share this post Link to post Share on other sites
bmw.maniac 1 Report post Posted December 3, 2008 The factory floor mat has a hole for the turny clip to go into to lock into place. Not trying to be a smartarse, but a tiny bit of thinking outside the square would help if you clip is missing. For example you can buy that non skid stuff that you put under carpets, i'm sure that would help. Quote Share this post Link to post Share on other sites
Eagle 1756 Report post Posted December 3, 2008 I assume they are factory mates?. Mine are stock ones and dont have any slip, my seating position the back on the mat tucks under the seat forward\back adjustment nicely and holds it in easy. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 3, 2008 re the mats max,proper crs have screws which go into the existing carpet,sound deadening and have clips on the top to fit into the eyelets on the mat..... Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted December 3, 2008 i have some of the factory mat screw thingy's Quote Share this post Link to post Share on other sites
