BLACK DORIS 9 Report post Posted December 7, 2008 Ok, so now I'm sorted on the man vs auto -thanks again. i have one last question(s) What's the major pro's n con's for the 318i and 320i e30's of the 80's/early 90's? - Manuals,. So far I've been informed: 1. There's little difference in acceleration between both models? - Not that this is a major issue. Wanting more of a daily cruiser. 2. The 320 is a thirsty model due to it's heavier 6 cylinder engine and associated gear/parts. Smoother drive. - Economy would be a factor, as it would be town driving mainly. Smoother ride could be good, though not essential. Guess the big question is - is the difference in fuel consumption great enough to pass on a 320 for the 318? Would also be interested in any other serious reason to consider the 318i over the 320i Cheers again! Rio Quote Share this post Link to post Share on other sites
antony 0 Report post Posted December 7, 2008 318's are more balanced, due to less weight up front, meaning they handle better. Apparently. Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted December 7, 2008 320i - 127hp - 1283kg - 0.099hp/kg 318i - 113hp - 1116kg - 0.101hp/kg And yes, 318s are closer to 50/50 weight distrubtion than the 320s so they probably have better handling. I'm not 100% on those figures above but the 318 seems to have more power per weight unit, I remember the 318 and 320 having similiar performance figures but the 320s torque is probably its saving grace in keeping it that bit quicker than the 318. The M20 sounds so much better than the l4 M40 also. Quote Share this post Link to post Share on other sites
323e30 0 Report post Posted December 7, 2008 get a 325i (if you dont plan to build a race series car) you will be far happier with it in the long run. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted December 7, 2008 get a 316i Quote Share this post Link to post Share on other sites
greenday-rulz21 6 Report post Posted December 7, 2008 get a 316i lol! good one! Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted December 7, 2008 320s have the performance of a 318 and the fuel consumption of a 325. Any 325/327 I have driven is not only a better drive, has bucket loads more torque and power, and almost all of them were a lot better on gas! Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted December 8, 2008 After the conversion, the 2.0 has NOTHING on a 2.5, My brother's facelift 1.8 went quicker than my 2.0 Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted December 8, 2008 Get a 325i. Youll never look back! You may spend a bit more time looking for a good one, but it will be worth the wait. Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted December 8, 2008 Manual for manual I would still take the 2.0 over a 1.8, the 2.0 is 100% smoother, pulls better at higher speed and sounds a lot better. Comes down to what you want, I believe a NZ 320i will be slightly better specked all round also. Quote Share this post Link to post Share on other sites
BLACK DORIS 9 Report post Posted December 8, 2008 Thanks for everyones thoughts/suggestions. 318 sounding like a good entry level model. -Well for now anyway! Off topic - Just started looking at the 520/523?/525's etc and yep they do look nice but can't understand how the bigger engines would be more economical for round town use? I know gas is cheap at the mo but how long will that last really? Considering the recession around the corner and talk of peak oil around the globe... Maybe I could slap a diesil motor in a 525 and run it on veg oil... p.s. apologies in advance if that last comment was offensive! Quote Share this post Link to post Share on other sites
isis 16 Report post Posted December 8, 2008 (edited) if you're looking at e30s then i presume you'll looking at e34. The early models have the same engine as the e30s - 520i & 525i. No 523i in the e34 shape. If you want an e34 - go for a post 94 model Edited December 8, 2008 by isis Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted December 8, 2008 the 5 series would use more gas as they are heavier. the 320i is just thirsty, probably due to the fact you have to drive it harder than a 325 to go anywhere. I'd go 325i if you could, good one is hard to find though. otherwise 318i is what you want. Quote Share this post Link to post Share on other sites
mops 4 Report post Posted December 12, 2008 1.8 is as good as 2.0, but you need to get the modern 16 valve m42 engine, not the m10. m10 is good for abuse with a turbo. m20b25 has some nice poke in a light chasis m20b27 is getting really fun to drive. you can cruise in low speed zone at 1300rpm making it very fuel efficient. m20b27 turbo... this is teh shizzle my nizzle so i went to get some new tires today. i managed to find 205/60/14's, looking very good, thinking, oh yea, that will hold the power... 2nd gear, step on it (outside tire shop) and i see two smoking black strips in rear view mirror.... if that doesnt work then i'll have to go wider and stickier rubber, but i suspect nothing will hold 14 psi raging turbo m20 stroker... Quote Share this post Link to post Share on other sites
Cale 36 Report post Posted December 12, 2008 1.8 is as good as 2.0, but you need to get the modern 16 valve m42 engine, not the m10. m10 is good for abuse with a turbo. To get a M42, you'd have to get a 318iS, which is around $5-6k. Awesome car and engine. The facelift 318s had the M40, single cam which is 113hp. Crappy hydraulic lifter FTL though. The pre facelift 318s had the said M10, 89hp but bulletproof. Quote Share this post Link to post Share on other sites
mtech1e30 0 Report post Posted December 12, 2008 The pre facelift 318s had the said M10, 89hp but bulletproof.Until the head gasket blows Quote Share this post Link to post Share on other sites
