Andre3000 55 Report post Posted March 2, 2009 Im wanting to use a cassette adapter in my e30 but the head unit keeps flipping sides automatically? Is there anyway i can stop this? The head unit is the stock BMW audio system thingymabob. Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted March 2, 2009 An FM transmitter on your ipod would be easier to use than trying to mod your headunit. (And most likely better quality as well) Quote Share this post Link to post Share on other sites
antony 0 Report post Posted March 2, 2009 (edited) Same thing happened with mine, fixed it by putting the tape in the other way around. The tape had a bit in it to run the cord down to. Hope this makes sense and helps. E: they are so much better than fooling around with fm transmitters, so hope you get this sorted. Edited March 2, 2009 by antony Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted March 2, 2009 _Mark_ said: An FM transmitter on your ipod would be easier to use than trying to mod your headunit. (And most likely better quality as well) I have used both before and admit that the sound quality is not perfect but it beats all the hassle you go through changing station all the time etc, and i think the cassettes are alot cleaner looking. Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted March 2, 2009 What happens when the head unit 'flips'? I wouldve thought the adapter could play your ipod music regardless of which side was playing. Does it stop playing altogether ? FM transmitters are horrible things. Ive yet to meet one that gave anywhere near acceptable quality unfortunately. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted March 2, 2009 antony said: Same thing happened with mine, fixed it by putting the tape in the other way around. The tape had a bit in it to run the cord down to. Hope this makes sense and helps. E: they are so much better than fooling around with fm transmitters, so hope you get this sorted. You had the same head unit as me? Also wat brand cassette adapter did you use? Cheers Quote Share this post Link to post Share on other sites
antony 0 Report post Posted March 2, 2009 André3000 said: You had the same head unit as me? Also wat brand cassette adapter did you use? Cheers No, mines a Sony one, but wouldn't be much newer. My adapter was from smiths city, came in a yellow packet (sorry, that's all I can remember).I have no idea why it worked on one side and not the other, but when it was on the other side it didn't play any music at all. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted March 2, 2009 Penry said: What happens when the head unit 'flips'? Yeah it works on both sides but the sound jerks on and off as it switches sides. You get about half a second of music then a second of silence then another half a second of music etc Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted March 2, 2009 André3000 said: Yeah it works on both sides but the sound jerks on and off as it switches sides. You get about half a second of music then a second of silence then another half a second of music etcTried a cassette adaptor but the sound quality was so s**t it drove me crazy.Loaded all my i-pod music onto cds--not perfect but I'm now a happy man!!. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 2, 2009 (edited) Some cassette players used to sense if only one of the spindles was turning (ie if the trailing spindle wasn't turning) so used to flip the other way in case the tape was being stretched, or had broken or to help wind up any slack evenly without chewing your tape. The little adapters you are using only spin the powered spindle causing the problem you experience. There's no way around it AFAIK. What the hell are you using a cassette deck for anyway? Surely by now that is obsolete technology. There are plenty of factory-looking cd players that fit the e30 and you could pick one up for $30-40 odd. Also, how can a plug-in I trip with no cables be messier than a cable sticking out the front of your cassette deck? Edited March 2, 2009 by bravo Quote Share this post Link to post Share on other sites
Mike 1 Report post Posted March 2, 2009 pull the head unit apart and cut the wire that flips the head? Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted March 2, 2009 I have to agree about the FM Transmitters and even the I-Trip, Got one for dad too use in his car and the sound quality was not up to scratch at all... Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 2, 2009 The one I have works fine? Upgrade the car aerial? Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted March 2, 2009 some adaptors dont have wheels inside to trick the tape deck to think its actually playing tape . so it thinks its at the end because the wheels dont move . try another one . or how about making a adaptor cable to go into the multi cd changer input socket in the back . will sound heaps better . easy enough to do . notice the button cd/aux input???? i also have heaps of bmw/sony decks etc . which could be moded to except ipod in directly . 021433600 Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted March 2, 2009 Brent HARTGE535i said: some adaptors dont have wheels inside to trick the tape deck to think its actually playing tape . so it thinks its at the end because the wheels dont move . try another one . or how about making a adaptor cable to go into the multi cd changer input socket in the back . will sound heaps better . easy enough to do . notice the button cd/aux input???? i also have heaps of bmw/sony decks etc . which could be moded to except ipod in directly . 021433600 This sounds like a good option - I wouldn't be too concerned about modifying a used stereo, but I wouldn't want to tear into a brand new one. The iTrips I have used have been OK, but not as good as real radio let alone a CD. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted March 2, 2009 bravo said: Some cassette players used to sense if only one of the spindles was turning (ie if the trailing spindle wasn't turning) so used to flip the other way in case the tape was being stretched, or had broken or to help wind up any slack evenly without chewing your tape. The little adapters you are using only spin the powered spindle causing the problem you experience. There's no way around it AFAIK. What the hell are you using a cassette deck for anyway? Surely by now that is obsolete technology. There are plenty of factory-looking cd players that fit the e30 and you could pick one up for $30-40 odd. Also, how can a plug-in I trip with no cables be messier than a cable sticking out the front of your cassette deck? The itrip supports itself on the cig lighter and its not very stable, and every time i go round a corner to the right i hit it with my knee which turns it off!! Its messy cos its huge and white and sticks out like a sore thumb. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted March 2, 2009 Brent HARTGE535i said: some adaptors dont have wheels inside to trick the tape deck to think its actually playing tape . so it thinks its at the end because the wheels dont move . try another one . or how about making a adaptor cable to go into the multi cd changer input socket in the back . will sound heaps better . easy enough to do . notice the button cd/aux input???? i also have heaps of bmw/sony decks etc . which could be moded to except ipod in directly . 021433600 How would i go about connecting a cable to the cd changer input? Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted March 2, 2009 André3000 said: How would i go about connecting a cable to the cd changer input?need to buy a multi pin plug and figuire out which is the audio wires and which is the remote turn on wire if it need it .bring you car aroud some time if you like. 021433600. might have something here . pull the stereo out and get a photo of the socket in the back Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted March 3, 2009 Brent HARTGE535i said: need to buy a multi pin plug and figuire out which is the audio wires and which is the remote turn on wire if it need it . bring you car aroud some time if you like. 021433600. might have something here . pull the stereo out and get a photo of the socket in the back Sweet il do that 2nite. Quote Share this post Link to post Share on other sites
