Jeddy
WTB: e30 Aftermarket Shocks
I'm after a set of replacement shocks for the e30 as i have a set of new H&R's and want to replace them both at the same time. I'm looking for something that will complement the H&R's and is stiffer than the factory MS shocks.
I was thinking a set of 2nd hand Koni's or Bilsteins as new is more than what i want to spend. I'm not too clued up on prices but if you have something that may be of interest let me know.
Cheers
The shocks on the m325i from factory were Bilsteins or Boge turbos. Why don't you have them rebuilt and revalved for the H&R's? Will cost you less than new shocks, but will be better than new as they will be valved for your setup.
Oh really? I was not aware of that. Its for a 318is and i was under the impression the two shared the same suspension setup am i correct in this?
I can't answer that sorry. Someone else will know.
They're not really going to be stiffer than his current shocks though.
For interests sake and to inquire about replacing the bushes i headed into Autolign thisafternoon for some prices. Thought id post them up incase someone was interested. Also if anyone knows where these can be had cheaper please let me know.
Bilstein Shocks:
Front: $430.54ea
Rears: $286.76ea
Bushes(Nothalane):
Front Control Arm Inner Bush: $235.35 pair
Front Sway Bar Mount 21mm: $45.42 Pair
Rear Control Arm (lower inner and outer): $283.21 pair
Rear Sway Bar Mount 14.5mm: $32.74 pair
Rear Trailing Arm Lower Front: $155.88 Pair
email dynamicraceparts@xtra.co.nz
They are nz distributors for Powerflex urethane bushes which are excellent quality.
Prices a year ago were:
PFF5-301 Front Control Arm bushes ( 2 per car ) $48.00 + GST each x 2 = $96.00 + GST = $108.00
PFF5-302-19 Front sway bar bushes ( 2 per car ) $39.00 + GST each x 2 = $78.00 + GST = $87.75
PFR5-305 Rear subframe (2 per car ) $81.00 + GST each x 2 = $162.00 + GST = $182.25
PFR5-306 Rear Control Arm ( 4 per car- 2 x inner 2 x outer) $57.00 + GST each x 4 = $228.00 + GST = $256.50
PFR5-308-12 Rear sway bar ( 2 per car ) $39.00 + GST each x 2 = $78.00 + GST = $87.50
PFR5-300 Diff ( 1 per car ) $60.00 + GST = $67.50
So a bit of a mixed bag there as to who is cheapest.
i have koni shocks for the front. good cond. am using the rears sorry.
Price?
errr does no one have any rears or sets they want to sell?
Price?
idno what a good price will be? $200? you live in chch and im in akl.. so if you endup buying them theyl have to be posted.
Bump...
Anyone got any sets for sale?
I'll get back to you if i can't find any sets
Re. bushes
Talk to paul @ interpart his bimmersport id is '#14'
He will be able to help you with bushes and any other suspension components. He has sorted 99% of my bushes and my shocks for me.
Good luck with them.
Bilstein Shocks:
Front: $430.54ea
Rears: $286.76ea
Bushes(Nothalane):
Wow im sure i got my lower control arm bushes (m3 nolathane) for 80 bux for a pair!!!
Where from?
I got it done through Glenn, but i think it was BM Warehouse in hamilton
Bilstein Shocks:
Front: $430.54ea
Rears: $286.76ea
Bushes(Nothalane):
Interesting prices :o I can quote you Koni/Superpro ex stock ChCh If you would like.
paul@interpart.co.nz
Bump
In urgent need of some front's.
Tossing up between Bilsteins and Koni Adj's(same as race series)
If anyone has any that hasn't been in contact could you let me know please.
Cheers
Edited by jeddy
I still have my Bilsteins available. $150 plus postage. I'd plan to have them rebuilt at some stage, but will be fine for a start to get you going. They work and no leaks, just should be firmer IMO.
I would of been all other them except for the fact i don't really want to have to do a re-build of them even if it would be cheaper as it means time without car + more expenses. Thanks you tho.
Thanks everyone.
Have sorted some shocks thru Paul.
Cheers
Jed
Awesome work, Paul is a legend with sorting that stuff.
You end up going Konis on the front?
Yea he is. Yep, and hopefully soon for the rear also.
