wolliver 1 Report post Posted March 29, 2009 does any one know if someone has done this before ? i wanna be original. edit: Removed text speak from post, please ref rules on posting. Also moved to F/I forum. Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted March 29, 2009 Do it. I put one in a Hyundai Stellar prima Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted March 29, 2009 i bet it went hard haha Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted March 29, 2009 Seen it done a few times on the net. I'll find the links. Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted March 29, 2009 Sure did, until I let the oil run dry and she blew up on the way to work :'( Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted March 29, 2009 http://www.dentsport.com/gallery/v/dsg/projects/bimmubishi/ http://b18c5.org/eric/bmw/ The two i've seen, Think the first one now has a SR20DET in it. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted March 29, 2009 rofl Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted March 29, 2009 http://www.dentsport.com/gallery/v/dsg/projects/bimmubishi/ http://b18c5.org/eric/bmw/ The two i've seen, Think the first one now has a SR20DET in it. thanks man Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted March 29, 2009 (edited) No problem. Seems alot of work for a little mitsi engine though? Edited March 29, 2009 by E30ONP Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted March 29, 2009 ive got nothing but time Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted March 29, 2009 And money, you'll need lots of money.. Oh and patience!! And beer. Lots of beer Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted March 29, 2009 i always hav a ready supply lol... of beer that is Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted April 8, 2009 just got a starion gearbox... cant wait to get this show on the road! Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted April 8, 2009 Hi Mate i chucked a post about this earlier on heres a great link about RWD conversions for these space wise easy would say that alll that will really cost is the mounting for the engine and some weilding lolz i worked out for 5k could have it certed and in really whatever car i wanted if you have the engine and done a clean up here thes link - if you want a engine could supply as fixing one at the moment http://www.projectzerog.com/ - helped heaps Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted April 9, 2009 thanks man, will have a good read i wanna do everything myself so wont need ur engine unfortunatly haha and wat else u cost heaps it puttin a skyline rear in lol... diff and axle and stuff haha, needs to be able to handle all the POWER!!!!!!! thanks for the link Quote Share this post Link to post Share on other sites
M Badge 0 Report post Posted August 16, 2009 does any one know if someone has done this before ? i wanna be original. edit: Removed text speak from post, please ref rules on posting. Also moved to F/I forum. If Turbo Vehicles can fit a rotary engine in one, I'm sure a little 4G63 motor wont be a problem. I hope you do it. Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted August 17, 2009 thanks man, will have a good read i wanna do everything myself so wont need ur engine unfortunatly haha and wat else u cost heaps it puttin a skyline rear in lol... diff and axle and stuff haha, needs to be able to handle all the POWER!!!!!!! thanks for the link You'll have no problems with a 325i diffrential and half shafts. With smooth power-on delivery of a turbo you aren't going to be near the limits of the running gear, just don't spend all day dropping the clutch in 2nd like a tool. And you want the gear to handle the TORQUE!!!!!11.1.1, power is a maths calculation. Quote Share this post Link to post Share on other sites
User Name 19 Report post Posted August 17, 2009 This will be good, im doing the same thing but will proberly be using it as a swap out engine for the e28 all going well. Hay wolliver - how much did you spend on your gearbox etc, as i still need to get new piston rings for my engine its running low compresion on cylidner 1 but still need all other jim jams for it Good luck will be great to see Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted August 17, 2009 Stock e30 325 half shaft splines / CV's will handle about 300hp before they start becoming a problem. This is all subjective obviously to application of power but will give you a rough idea. EG dont expect it to be a drag car, but it will handle it fine if your streeting it. Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted August 17, 2009 Stock e30 325 half shaft splines / CV's will handle about 300hp before they start becoming a problem. This is all subjective obviously to application of power but will give you a rough idea. EG dont expect it to be a drag car, but it will handle it fine if your streeting it. What would one do once reaching 300hp? is that at the wheels or motor? Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted August 17, 2009 (edited) As explainded on MSN to you Luke, and put here for reference: Just load up the gears by holding the handbrake, and letting the clutch slightly out till it lurches a wee bit, for launches. And nice smooth shifts. Once the drivetrain components are loaded up they can take hundreds and hundreds of newton metres. It's the lash and crashing teeth together that kills it really. Edited August 17, 2009 by Incary Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted August 17, 2009 Awesome bro! Thanks Henry! Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted August 17, 2009 This will be good, im doing the same thing but will proberly be using it as a swap out engine for the e28 all going well. Hay wolliver - how much did you spend on your gearbox etc, as i still need to get new piston rings for my engine its running low compresion on cylidner 1 but still need all other jim jams for it Good luck will be great to see gearbox i got through a mate pretty cheap, only 250, its in really good nick. all i actually hav at the moment is my box, block, head and con rods, as funds are a little bit on the low side. im gonna be using evo 7 pistons (these are probably the best standard mitsi pistons and can handle a lot of boost) and evo blacktop injectors. not to sure what turbo ill be running yet tho, but i do knw that its gonna be top mounted lol Quote Share this post Link to post Share on other sites
|ncary 0 Report post Posted August 17, 2009 Are you planning on running more than 25psi? Quote Share this post Link to post Share on other sites
wolliver 1 Report post Posted August 17, 2009 (edited) not 100% sure yet... we shall see, but id like to have the option to if you know what i mean? Edited for text speak. Edited August 17, 2009 by Mike Quote Share this post Link to post Share on other sites
