pommy 33 Report post Posted April 5, 2009 As you all know there a few brands on the market for brake fluid. was wondering what would be a good brand to use for the e30 thanks. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted April 5, 2009 Motul..expensive but its really good Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted April 5, 2009 If for street duties the Castrol Repsonse stuff from Super Cheap is fine. For track Penrite RBF600 Quote Share this post Link to post Share on other sites
Driftit 2222 Report post Posted April 5, 2009 (edited) Penrite RBF600 Motul RBF600 and RBF660 is only about $25 from BNT for a 1ltr. Should be all you need for a full flush. 2 ltrs just incase. I use this in my series car. And have never had it overheat etc.. Even with shitty pads it was still fine. Motul, Pentrite, Lucas all come from the same factory. Infact I think Castrol is the only one that has their own design at the moment. Many of the series guys also use the castrol stuff. BTW dont go to race brakes. They sell the same RBF600 fluid for double the price of BNT. Good advice. Crazy prices! Edited April 5, 2009 by driftit Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted April 5, 2009 Motul RBF600 and RBF660 is only about $25 from BNT for a 1ltr... Thats damm good... The best i've found was $28 for 500ml (one bottle), you should only need 1 ltr to flush your system... that was from Turbo Vechicals in penrose... Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted April 9, 2009 thanks for your help! I was in supercheap the other day they had nulon performance brake fluid it said it was tested @ high degrees and all the jargan that goes with it!!!!!! whats your guys thoughts ? sounds like maybe motul or castrol cheers again. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted April 9, 2009 I'd go for the castrol, i work at supercheap... the nulon is like our cheap "quality" brand, try and make u think its good and charge u more sort of thing Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted April 9, 2009 (edited) thanks for your help! I was in supercheap the other day they had nulon performance brake fluid it said it was tested @ high degrees and all the jargan that goes with it!!!!!! whats your guys thoughts ? sounds like maybe motul or castrol cheers again. Personaly me = Motul all the way...You want to read the actual boiling point for wet and for dry.... read below Have a read of this site... http://www.stoptech.com/tech_info/tech_white_papers.shtml Particularly: 1) http://www.stoptech.com/tech_info/wp_brakefluid_1a.shtml <--- brake fuild Dot rating explained 2)http://www.stoptech.com/tech_info/wp_howto_bleedbrakes.shtml Edited April 9, 2009 by DRTDVL Quote Share this post Link to post Share on other sites
Hi-Tek 3 Report post Posted April 10, 2009 Motul for me also. Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted April 10, 2009 I'd go for the castrol, i work at supercheap... the nulon is like our cheap "quality" brand, try and make u think its good and charge u more sort of thing Pretty sure Nulon is repackaged Castrol We had a big debate about it when I was working there. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 10, 2009 i use motul; 5.1 around puke lap after lap 200km/h to hair pin speed . no problems Quote Share this post Link to post Share on other sites
pommy 33 Report post Posted April 12, 2009 thanks it sounds like the motul is the way to go !!! as I will be using it for mainly cruising round and I go up north once a month and the bends are fun! also when i do get it on the road it will be good to do a few meets to taupo or even talk myself into takin it on the track? Quote Share this post Link to post Share on other sites
djs325 0 Report post Posted May 1, 2009 I'm using MOTUL RBF660 now, and have noticed a reduction in the amount of bleeding required to keep the braking system performing at its best. Would definitely recommend it. Quote Share this post Link to post Share on other sites
