bekker 7 Report post Posted July 16, 2009 (edited) Hi guys, I'm going to be painting my new calipers once I've finished stripping them back. There is a certain amount of surface rust which I will get rid of (as much as I can anyway). Does anyone know of a rust treatment or primer that would be suitable for the kind of temperatures the calipers see. I can't find any, seems most people simply paint straight onto the metal. Cheers. Edited July 20, 2009 by bekker Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted July 16, 2009 (edited) I painted all 4 of mine, didnt remove them I just painted them on the car, paint just eventually burnt off the rotors when I used the brakes and painted them black. I bought a paint especially made for directly put on metal as it has Primer in the paint like a 2 in 1. Painted them with about 3 coats so is very thick. has no shown any evidence of wearing off or melting. I forgot what its called, but Repco/SCA and most paint specialists sell them. Prices are about $10-$20 a can depending where you go. I paid $20at a paint shop and a BIG can, 3 coats per caliper (x4) and had heaps left! Dries fast too. EDIT:- Has been well over a month now since I painted them, and still looks nice n fresh whenever I remove my wheels and wash the calipers. Looks shiny as. Edited July 16, 2009 by Shady Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 16, 2009 ^^Wattyl S.P.E.E will do that. Quote Share this post Link to post Share on other sites
briancol 3 Report post Posted July 16, 2009 I painted mine about two years ago. I cleaned them well first, then sprayed them with a heat resistant primer, then three coats of heat resistant red. They still look as good as the day they were painted. Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted July 16, 2009 Yep, it’s all about the preparation, allow for a few hours to do the job properly. I used the paint brush stuff last time and it was a much better job than spraying them. Use two or more coats of paint. Just use a wire brush to clean them up, nothing works better than a wire brush. Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted July 16, 2009 I painted mine about two years ago. I cleaned them well first, then sprayed them with a heat resistant primer, then three coats of heat resistant red. They still look as good as the day they were painted. Where did you get the heat resistant primer? I can't find any!I'm stripping them back really well - wire brush thingy on my power drill. It's just that there are nooks and craneys (spelling?) which are difficult to reach with the brush. I'm then using a dremmel head as best I can. I'd like to use a primer but if I can't find anything to handle the heat I guess I'll just go straight on with the paint. Quote Share this post Link to post Share on other sites
briancol 3 Report post Posted July 16, 2009 Where did you get the heat resistant primer? I can't find any! I'm stripping them back really well - wire brush thingy on my power drill. It's just that there are nooks and craneys (spelling?) which are difficult to reach with the brush. I'm then using a dremmel head as best I can. I'd like to use a primer but if I can't find anything to handle the heat I guess I'll just go straight on with the paint. I brought it in spray cans from Supercheap. Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted July 17, 2009 (edited) Just go for the paint that can be sprayed straight on baremetal. I never used primer and its still mint as. I dont think the calipers get as hot as we all think they do - when I roll around, I go out for a few hours and use my brakes alot (of course) so would heat up a bit I'd say, and no sign of wear or peel at all... Edited July 17, 2009 by Shady Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 19, 2009 Plasticote do a heat proof primer. Mitre ten WILL have it and so should placemakers. If you still can't find any I can send you a can. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted July 19, 2009 , and still looks nice n fresh whenever I remove my wheels and wash the calipers. Looks shiny as. Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted July 19, 2009 Hahah whats that look for? I dont do that every week. Only when I can be bothered...like once or twice a month. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted July 19, 2009 i like to have mycar clean,but the only time the wheels come off is for punctures or tyre replacement :bowdown: Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted July 19, 2009 i like to have mycar clean,but the only time the wheels come off is for punctures or tyre replacement :bowdown: I take my wheels off about every 2nd time I clean my car and give the mags a good clean, inside & out Quote Share this post Link to post Share on other sites
320guy 0 Report post Posted July 20, 2009 Just go for the paint that can be sprayed straight on baremetal. I never used primer and its still mint as. I dont think the calipers get as hot as we all think they do - when I roll around, I go out for a few hours and use my brakes alot (of course) so would heat up a bit I'd say, and no sign of wear or peel at all... I reckon they probally get pretty hot, ive had mine hot enough that the pads were actually smoking, and I couldnt even touch the wheel because the wheel was so hot. Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted July 20, 2009 I reckon they probally get pretty hot, ive had mine hot enough that the pads were actually smoking, and I couldnt even touch the wheel because the wheel was so hot. He's right. I once thought my front brakes were on fire there was so much smoke. Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted July 20, 2009 Plasticote do a heat proof primer. Mitre ten WILL have it and so should placemakers. If you still can't find any I can send you a can.Cheers, Ill check them out tomorrow. Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted July 31, 2009 Just thought I'd give a word of warning on the caliper paint available from Supercheap. Apparently many people have had good experience with it. Not me. After many days of hard work and preparation I discovered that it simply dissolves and drips away when it comes into contact with brake cleaner. Supercheap were very surprised and at first didn't believe me and wouldn't give me a refund until I actually demonstrated it for them. They said they would take it up with their parts people but I've ordered some VHT instead. I think this may be one of those times when 'ya gets what ya pays for'. And in case anyone asks... parts thoroughly prep'd, degreased, cleaned, painted, cured for 4 days yada yada yada. In other words I carefully followed the instructions. Hoping for better luck with the VHT! Quote Share this post Link to post Share on other sites
