dloubser 0 Report post Posted July 19, 2009 Hi Guys New to the group. Got a 1990 320i, a really sweet motor, but have a problem, the head is cracked, and will go pretty soon. My mackie has advised that the cheapest option is an engine replacement, what I want to know is can I put a 323i engine in the car, I can get a reconned 323i pretty cheap. My mackie thinks there is a different engine management system in the 323 which could make it a pricy option. Your thoughts and advice would be great Dave Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted July 20, 2009 Go for a 325i engine as it will most likely have the same management/plugs, cost is anywhere from $500-$1500 Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 20, 2009 What year is it? Could get a m20b20 easy enough, PM Mike (323e30), he may have one. Or Ray. Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted July 20, 2009 If ya got the money and the know-how just get an M50 and be done with it =P Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted July 20, 2009 If it is a F/L E30, Should have no probz dropping in an m20b25 with the ECU etc, Can be had pretty cheap.. And then you don't tell anyone about it and you won't need a cert lol.. I had a m20 2.7l stroker in my 320i and never certd it, no body can tell the difference cos they all look the same Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted July 20, 2009 Easy to say go 2.5 but if you don’t have mechanical knowhow, the facilities or the time it’s still going to run you 1,500-2k depending on how cheap you can get the 2.5 and ass parts. You will need to swap the air flow meter and intake pipe so if you’re looking for an engine make sure it comes with these, the ECU is easy to swap. If you can get a very cheap 2.3 do it, all you will need to swap the AFM and ECU easy peasy. Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted July 20, 2009 If it is a F/L E30, Should have no probz dropping in an m20b25 with the ECU etc, Can be had pretty cheap.. And then you don't tell anyone about it and you won't need a cert lol.. I had a m20 2.7l stroker in my 320i and never certd it, no body can tell the difference cos they all look the same Do you need to cert a 2.5? They are hardly powerful. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted July 20, 2009 (edited) I talked to a certifier about my car and they said don't bother as the b20 and b25 are of the same engine design, also both consist of original parts from the same time era and were used in the same design of chassis, a.k.a if I modify the engine with parts that were not released with the chassis design, I will need a cert. Edited July 20, 2009 by Jamez Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted July 20, 2009 Oh I always thought there was somthing about the increase in displacement, and more than a 15% power increase ? or was it 25%? meh I dunno. Quote Share this post Link to post Share on other sites
APT 205 Report post Posted July 20, 2009 ^^ Yeah im pretty sure it was +15% ?? owell they all look pretty much the same Quote Share this post Link to post Share on other sites
