charles28 140 Report post Posted October 4, 2009 (edited) So now my other E30 has an issue, so I now have 2 broken E30's and no reliable transport to get to work tomorrow. Anyone know if there's a quick fix for this problem showing in my video? I was stuck out at Rolleston today with it like this *happened on the way there*, I drove home with the radiator cap undone to relieve some pressure, however by Templeton the Coolant light was on again and had to fill it up 2 more times to get home to New Brighton. Video shows leak with Radiator cap on tight to show location of the leak, (after engine turned off even) http://www.youtube.com/watch?v=OFjgbWb3LqQ Edited October 4, 2009 by Charles28 Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted October 4, 2009 You could always, as a last resort, cover it in sealant of some sort, would stop or it or atleast reduce it to a weep rather than how it is at the moment, limp it to get it fixed and keep big bottle of water in ya car Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted October 4, 2009 just remove the little plate , get some good sealant and apply and refit . Quote Share this post Link to post Share on other sites
charles28 140 Report post Posted October 4, 2009 just remove the little plate , get some good sealant and apply and refit . Thanks man, I doubt there's anyone open now, but I'll grab some tomorrow and see how it goes. Quote Share this post Link to post Share on other sites
mark247 39 Report post Posted October 4, 2009 Thanks man, I doubt there's anyone open now, but I'll grab some tomorrow and see how it goes. Even a petrol station might have some. Quote Share this post Link to post Share on other sites
oscar90 0 Report post Posted October 4, 2009 Bower Ave BP should have some man, and they're always open lol Quote Share this post Link to post Share on other sites
charles28 140 Report post Posted October 4, 2009 Bower Ave BP should have some man, and they're always open lol Cool, so I got some Selleys Instant gasket, have used it and am putting it back together, however it says that it takes 24hours to cure, doh I'll be off to work in 12 hours lol Quote Share this post Link to post Share on other sites
Guest FrantiC Report post Posted October 4, 2009 Bypass it. You can connect the hose directly from the block to the thermostat housing, by stretching one of those hoses instead of having thermostat housing -> throttlebody. throttlebody -> thermostat housing. It's pointlessly there really... Quote Share this post Link to post Share on other sites
charles28 140 Report post Posted October 11, 2009 Today a cork gasket and metal cover arrived that I ordered from the net. Do I need to use sealant with the cork gasket on this outlet? Cheers. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 11, 2009 Today a cork gasket and metal cover arrived that I ordered from the net. Do I need to use sealant with the cork gasket on this outlet? Cheers. A small amount and dont overtighten it or the cork will split. Make sure both sides of the housings are perfectly cleaned Quote Share this post Link to post Share on other sites
