Lucan 196 Report post Posted July 16, 2011 Maybe Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted July 16, 2011 Oyea and before anyone asks about the Garrett sticker. All these little side projects are a distraction from a more expensive project slowing moving along... Quote Share this post Link to post Share on other sites
AN E30 Fan 1 Report post Posted July 16, 2011 Yay for Pedo Bear! Glad to see it you are getting the last of your parts, will it be ready for Taupo? Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted July 16, 2011 Probably not I'm considering just waiting until after Taupo to put it all together. Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted July 16, 2011 Specs of turbo How is the megasquirt going? Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted July 16, 2011 (edited) Can't remember trim or inducer/exducer numbers but some sizes off the top of my head.. Compressor 0.70 A/R 4" inlet, outlet 2.5" T3 Exhaust 0.63 A/R 2.5" out Looks like a GT35 series or something similar. Oh and I'm just waiting on an IAT weld in bung as far as parts go..Finished the harness adapter, just need separate wiring going to the coilpack and IAT sensor and she'll be good to go. Edited July 16, 2011 by Blackie Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted July 16, 2011 I love the idea of boost. What is your budget and what power are you after? Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 18, 2011 Woah, very cool bro! Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted July 18, 2011 Love your work Lucan. Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted July 18, 2011 Cheers guys, I love the idea of boost. What is your budget and what power are you after? Budget? mmmmm...whats that? I dream of huge numbers, but I'm going for 'reliability' first and foremost. Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted July 18, 2011 sick dude , you going hard on the 30 nicee! Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted July 19, 2011 (edited) Ha how silly of me to assume you had a budget. I have seen a few turbo e30's in Auck but nothing with huge HP. Would love to see a local m20 pushing more than 400rwhp edit: my spelling is atrocious... Edited July 19, 2011 by DrphTa Quote Share this post Link to post Share on other sites
Sam@TMBMW 0 Report post Posted July 19, 2011 What manifold are you using for the turbo? Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted July 19, 2011 Inspiration in the form of a 10.46 second quarter mile 325 turbo. Quote Share this post Link to post Share on other sites
$toffz 0 Report post Posted July 20, 2011 Link to car spec above? Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted July 20, 2011 Built by: http://www.kilander-racing.se/ I think(?) I can't find actual specs on it, pulled her from this thread: http://www.dtmpower.net/forum/general-disc...le-bimmers.html Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted July 21, 2011 What manifold are you using for the turbo? I'm not sure where it originated, I bought it from an E30tech member in Aus. Has a T3/T4 Flange, need to get a welder/fabricator to mod it for the wastegate. Haven't bolted it up in the engine bay to check steering linkage clearance, which I hope isn't an issue, but it looks good on the spare engine in the garage It doesn't clear the oil filter either but I have a relocating kit, just need to find somewhere else in the engine bay to mount the filter etc... Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted September 12, 2011 I think we need an update Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted September 13, 2011 Nothing much has happened yet, I've been buying parts and stripping back the engine bay. Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted November 3, 2011 Small update Received ARP main studs today, still waiting on Head studs. Bought a whole m20b20 for the rods/manifold/spares etc... Spare b25 block has been stripped right down and will be getting cleaned up & O-Ringed Couple of things welded up Spacer on the m52 crank Quote Share this post Link to post Share on other sites
DrphTa 5 Report post Posted November 3, 2011 Are you using a m52 crank in a m20? Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted November 3, 2011 Yes sir.. 2.8 m20 Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 3, 2011 What pistons and size head gasket do you use? What sort of compression ratio are you aiming for? Is the spacer heat treated? I'll be looking forward to seeing what this turns into Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted November 3, 2011 Im using 2.5 pistons so the comp should be around 9.75:1 Spacer wasnt heat treated AFAIK .. Theres no load on it as its only to fill out the oil seal gap, so does it matter? Stock HG for now. Haha hopefully it ends up running, reliably. Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted November 3, 2011 I actually only asked because it looks like it had a bit of color to it. Cheers for the info. Quote Share this post Link to post Share on other sites
