JaseNZ 53 Report post Posted November 8, 2009 (edited) Was browsing around the net today and found out a couple of things i did not know that were available on my e36, Tried them out and blow me down they work. First one is, After you park the car you can switch on the parking lights on one side of the car only. To do this, just switch the car off and push the indicator stalk all the way up or down. The right or the left parking light will turn on. Second one i came across was if you have any of the windows down when you lock the car they will auto close, I knew that if i kept the key turned to the left while locking they would close (closes the sun roof as well), But just locking the car will close the windows but leave the sun roof open. third one was and this is something that happens on mine but did not really occur to me is the speed sensitive wipers, When i am stopped they stop and as i start to speed up, there's about 3 settings before they run at normal speed. last one was the secret function on the digital climate control. The display mode is called up by pressing the "AUTO" and "REAR DEFOGGER" buttons simultaneously. 12 displays are available and you can toggle through them by pressing the fan rocker switch. Test number Function Test 1 Interior Temp Sensor Test 2 Exterior Temp sensor Test 3 Left Heater Core Sensor Test 4 Right Heater Core Sensor Test 5 Evaporator Temp Sensor Test 6 Engine Speed Input Test 7 Road Speed Input Test 8 "Y" Factor Value . . . Anyone knows what is this? Test 9 Fresh Air Flap Position in % (99.5% Max.) Test 10 AUC Sensor Voltage (if equipped) Test 11 Battery Voltage Test 12 Software Version The sensor display functions are exited by pressing "RECIRC" and "AUTO" buttons simultaneously and also by turning the ignition off. The decimal point is not shown therefore 66.5% would show as 665 All temp displays are in degrees centigrade. Negative values are indicated with minus sign... Anybody got any else they can add. Edited November 8, 2009 by M-Spec Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted November 8, 2009 i have an mr2 and when i turn the ignition key all the way on the car starts lol when i had the 750 i did notice that when you came to a stop the wipers went from constant to intermittent also the obc can be used with secret functions cant remember how but you can get readouts such as liters of petrol left etc also on a 750 if you put the right pedal all the way down things start going past faster.....much faster Quote Share this post Link to post Share on other sites
Mikal 4 Report post Posted November 8, 2009 Wow that is awesome. Knew about the wipers but not any of the others... Will try them first thing tomorrow. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 8, 2009 i have an mr2 and when i turn the ignition key all the way on the car starts lol when i had the 750 i did notice that when you came to a stop the wipers went from constant to intermittent also the obc can be used with secret functions cant remember how but you can get readouts such as liters of petrol left etc also on a 750 if you put the right pedal all the way down things start going past faster.....much faster this fast Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted November 8, 2009 You need some gas. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted November 8, 2009 You need some gas. Also an ABS repair and thermostat Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted November 8, 2009 And to take the car off the axle stands Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted November 8, 2009 and look it gets 55mpg at that speed Quote Share this post Link to post Share on other sites
Driftit 2239 Report post Posted November 8, 2009 Yeah on the E39's you can hold down the two stalks on the dash cluster to have it turn to diagnostics mode. Then one of the tests will turn everything on and do full sweeps like what Brent is doing. Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted November 8, 2009 Wow I didnt know any of that. I wanna try them when I get home Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted November 9, 2009 Anyone know what model cars that the OBC secret functions work for? They don't seem to work on mine (it DOES have the digital air con unit). Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted November 9, 2009 you prolly notice this but dont take any notice if you know what i mean....On my e 34 if you have been driving with the lights on and you arrive at your destination and turn the key off....internal lights come on instantly.... Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted November 9, 2009 Anyone know what model cars that the OBC secret functions work for? They don't seem to work on mine (it DOES have the digital air con unit). Pretty sure its the 18 button one it does not work on the 11 button one, If you push the buttons they say it comes up with funkion or something like that. But the secret function on the digital air con works great i put mine on 7 and you have the digital spedo lol. Quote Share this post Link to post Share on other sites
darkwolf 0 Report post Posted November 9, 2009 That's how I got my avatar I also like the code immobilizer. I'm not 100% sure what will happen if you enter the code wrong though... Anyone? Quote Share this post Link to post Share on other sites
Allah 0 Report post Posted November 9, 2009 It wont start. For e36's you can turn the key and push the button to reset the odometer and the gauges will do a full sweep. Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted November 9, 2009 Pretty sure its the 18 button one it does not work on the 11 button one, If you push the buttons they say it comes up with funkion or something like that. But the secret function on the digital air con works great i put mine on 7 and you have the digital spedo lol. I was really looking forwards to using the 7th function! Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted November 9, 2009 I was really looking forwards to using the 7th function! If you have the digital aircon then you should be able to access this function, If i can on mine i cannot see why you can't on yours. Quote Share this post Link to post Share on other sites
