turboprop 0 Report post Posted January 13, 2010 It also hurts reading some of the crap we are daily bombarded with in here too... try hurting for a change... you might get the ideaYeah... sorry. I have trouble putting what im thinking into words, especially when Im trying to explain things in a way for other people to understand. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 13, 2010 I have trouble putting what im thinking into words Thats good... at least your thinking... which is a great change to some of the things we have had to put up with on here lately.. its good... and I'm glad to see your positive response Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 13, 2010 I know weve gone completey OT on this... however.. I'm really enjoying this if nobody minds ?? Especially ... there is absolutely no agro Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted January 13, 2010 (edited) Try thinking... hemi head, 4 valves, induction flow, induction speeds.... does that help... I'm not giving the answer... I want it from someone on here... with technical proof Oops and chamber swirl/flow Oh... and think about the path that electricity takes... and why Great Discussion. Hope you dont mind me putting in an attempt at an explanation, I hope to learn somthing. The reason for the 4 electrodes (in my mind) is to aid the burn of fuel in the chamber or more specifically how the flame front proresses through the chamber. The spark is not a momentary flash but has a duration which as it ignites fuel (air/petrol mix) would be disrupted by the incoming charge and exiting burnt fuel as it progresses through the head and in the flame front in the chanber. 4 Electrodes provides greater chance of complete ignition (the spark always takes the path of least resistance) at the required moment in a way which the flame front can progress in a predictable most efficient manor. This is my thoughts. Is that a reasonable explanation? Edited January 13, 2010 by MLM Quote Share this post Link to post Share on other sites
bekker 7 Report post Posted January 13, 2010 (edited) Great Discussion. Hope you dont mind me putting in an attempt at an explanation, I hope to learn somthing. The reason for the 4 electrodes (in my mind) is to aid the burn of fuel in the chamber or more specifically how the flame front proresses through the chamber. The spark is not a momentary flash but has a duration which as it ignites fuel (air/petrol mix) would be disrupted by the incoming charge and exiting burnt fuel as it progresses through the head and in the flame front in the chanber. 4 Electrodes provides greater chance of complete ignition (the spark always takes the path of least resistance) at the required moment in a way which the flame front can progress in a predictable most efficient manor. This is my thoughts. Is that a reasonable explanation? +1. My understanding is that it provides 4 alternate spark points so the plug actually 'chooses' the best path depending on engine loading. Or something like that. You can also get plugs with two or three electrodes. I have the Bosch plus 4 ones. Hope I'm not being too serious! Edited January 13, 2010 by bekker Quote Share this post Link to post Share on other sites
mark247 43 Report post Posted January 13, 2010 Great Discussion. Hope you dont mind me putting in an attempt at an explanation, I hope to learn somthing. The reason for the 4 electrodes (in my mind) is to aid the burn of fuel in the chamber or more specifically how the flame front proresses through the chamber. The spark is not a momentary flash but has a duration which as it ignites fuel (air/petrol mix) would be disrupted by the incoming charge and exiting burnt fuel as it progresses through the head and in the flame front in the chanber. 4 Electrodes provides greater chance of complete ignition (the spark always takes the path of least resistance) at the required moment in a way which the flame front can progress in a predictable most efficient manor. This is my thoughts. Is that a reasonable explanation? That actually makes sence! Very interesting.. Quote Share this post Link to post Share on other sites
