JaseNZ 53 Report post Posted May 31, 2010 I did a rim clean today (since there was no rain). Getting a bit tired of the black dust accumulating every 3 days or so. I am guessing when the car came over and they did their basic service they threw the cheapest brand on the front they could find. Any suggestions on what to replace them with that will give me little dust. Oem the best option to go for ??, or is there a better aftermarket brand. Don't know if they do ceramic for mine but don't think i would go that route anyway as don't want to change the rotors as well. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 31, 2010 You will either have to machine or replace rotors with a pad change otherwise you run this risk of shimmy under braking. I'd just use genuine pads and teach the missus how to clean E46 wheels Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted May 31, 2010 I'd just use genuine pads and teach the missus how to clean E46 wheels how to win friends and influence people. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 31, 2010 how to win friends and influence people. Do you do the dishes and washing as well Jase ??? Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted May 31, 2010 Do you do the dishes and washing as well Jase ??? Depends on what i am after Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted May 31, 2010 I bought OEM pads from BMW a few months ago for the E36!! And since have noticed that these just create loads of black dust...well loads more than the ones i took off which were higher spec aftermarkets!! Are OEM/BMW ones always the best to go for? Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted May 31, 2010 You will either have to machine or replace rotors with a pad change otherwise you run this risk of shimmy under braking. I'd just use genuine pads and teach the missus how to clean E46 wheels Is that a general rule on all brake pad replacements Glenn? Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted May 31, 2010 I bought OEM pads from BMW a few months ago for the E36!! And since have noticed that these just create loads of black dust...well loads more than the ones i took off which were higher spec aftermarkets!! Are OEM/BMW ones always the best to go for? what are these said brake pads you speak of? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 31, 2010 (edited) Is that a general rule on all brake pad replacements Glenn? With European vehicles... YES You need to measure the rotors and you need .6mm to machine them normally which may take them undersize. Generally speaking most European disc rotors will only machine once. Get into the heavier or performance vehicles most times you have to replace rotors every time you do disc pads. We did a Q7 last week... front & rear was over $2,000. Last month we did the fronts on a Merc S55AMG was $3,000 for fronts only. Edited May 31, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted May 31, 2010 (edited) what are these said brake pads you speak of? The guys at Ripco didn't know what they were but after a little research i found out they are PBR axis pads and are known as close to OEM spec but with less brake dust...i just went the OEM route as price wise was fairly close and had no airfreight to wait for! though not particularly happy with the amount of dark brake dust now! Edit: and looking at service receipts Jeff gray in Welly must have installed them unless they were changed between services...though don't think they would have been! Edited May 31, 2010 by cliffdunedin Quote Share this post Link to post Share on other sites
so54i88 0 Report post Posted June 13, 2010 I was told the genuine BMW ones are the best. I've got aftermarket ones on my from the last onwer. The brake clunks everytime I put my foot on the padel. The dealer said it's becuase the pads are slightly smaller than genuine, so it moves a bit under braking. It's works ok but just very very very annoying! I'm thinking to get it change and thought i'd better wait for them to wear down so i can make the most out of them.......6months on.......still waiting........ Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted June 14, 2010 http://www.cl-brakes.co.uk/carbone-lorrain...brake-pads.html Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 14, 2010 I was told the genuine BMW ones are the best. For a standard road car... you were given the right answer... genuine are the best Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted June 14, 2010 I have to disagree, the OEM ones i have on the 318 creates probably double the amount of dust! Quote Share this post Link to post Share on other sites
vonripsnorter 0 Report post Posted June 14, 2010 OEM & Genuine are one & the same, just come in diffrent box's & depending on where you get them , can be quite a bit cheaper. Most of the genuine pads are textar brand just not in a Textar box Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 14, 2010 I have to disagree, the OEM ones i have on the 318 creates probably double the amount of dust! They work properly... you get dust....clean your wheels more than once a month Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted June 14, 2010 Thats the trouble, I do!! the other non OEM ones on previously (PBR Axis) only needed cleaned because of dust...maybe once a fortnight, compared to the new genuine BMW ones that need cleaned every 2-3 days...In some cases and my opinion, i don't think genuine or OEM ones are always the best option...for me anyway! Quote Share this post Link to post Share on other sites
djs325 0 Report post Posted July 7, 2010 Performance Friction Carbon Metallic or Z-Rated would offer more performance and less dust than OEM. Direct fitment for your E36/E46. Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted July 7, 2010 EBC pads. Had them on my Touring, after two weeks the back wheels will be black and the front still quite clean. They worked well for me. http://www.ebcbrakes.co.nz/ Quote Share this post Link to post Share on other sites
