Matty104 0 Report post Posted June 16, 2010 (edited) Hey guys, This is doing my head in. I have been searching and searching for days trying to figure this out and bs is my last port of call before the auto sparkys can take over. So im hooking up an aux fan into the e30 to clear room for the s/c pully and john (e30ftw) has kindly given me this wiring diagram to work off, This is also the way that kerrys fan runs but mine will not seem to switch on. The only thing i can see i have done different is the two + wires are not fused. Pin 86 on the relay is connected directly to t2( low temp) on the radiator thermo switch and the rest is hooked up exactly the same as the diagram, and i can switch the fan on by jumping pin 87 and 30 ( constant power) so what am i doing wrong? I have changed the thermo switch and the relay today to no avail, Many thanks Edited June 16, 2010 by Matty104 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted June 16, 2010 (edited) what happens when you connect 86 to earth? edit: oh and get fuses in there man! they are there to protect the relay and/or motor! Edited June 16, 2010 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 16, 2010 here is how it should look... if you bridge 87 and 30 and it goes that means the trigger side of its not working... check that you have wired up 86 and 85 properly, also check the grounds. does the temp sensor earth through the motor or a seperate earth? just check where you have power up to. Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted June 16, 2010 Nothings happens when i connect 86 to earth, And yea i plan on doing the fuses but just wanted to get it going and the fuses will go in when i have the fan wiring worked out as ill go back through and hide the wires Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 16, 2010 (edited) well then there is either no power to the relay or the relay is faulty.. check for power at 85... the way i did mine was just ran a jumper wire from 30 to 85 and you will probs want about a 15a fuse, and 15a wiring too. Edited June 16, 2010 by DRTE30 Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted June 16, 2010 cheers oli, ill hook it up to your setup now and warm it up and let you know the results Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted June 16, 2010 85 and 86 are opposite ways round on those two diagrams.. it should make any difference which way around they are though correct? Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 16, 2010 it doesnt matter which way round they are. as long as the high and low side are seperate... you shouldnt need to warm it up, just ground the wire on the temp sensor. Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted June 16, 2010 (edited) I have power at 85 with oli's diagram, and when you say jumper do you mean as a test method or actually wire it in. I should add that wiring is my worst nightmare Edit : when i ground the wire on the temp sensor the relay clicks over, butthe fan doesnt go Edited June 16, 2010 by Matty104 Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 16, 2010 (edited) really?? wiring is my fav.. well on mine there is one power wire going to 87 and then back out of 87 into 86. so now that you have power at 85 is there power at 86? if so does it get to the temp sensor? if so does it get to ground? just read ur edit... if the realay is clicking then the low side is all good... check that there is power on the high side now.. check power at 87 and 30... whichever is ur power input... also check fan earth and fan power when temp sensor is grounded. pm me ur number if you want. i will call you.. much easier. Edited June 16, 2010 by DRTE30 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted June 16, 2010 Edit : when i ground the wire on the temp sensor the relay clicks over, butthe fan doesnt go either fan motor is f**ked (to test put a terminal directly on each pole of the battery to see if it works), or the relay is (to test connect 85 and 86 to each terminal on the battery, and check for zero resistance between 87 and 30) Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted June 16, 2010 cheers for the help guys, i tried testing all those and am getting power in the right places, been through 3 different relays and the fan defenently goes, so i'm at a loss, does anyone in hamilton want to do it for me and ill pay them? or ill book it in for next week and have the auto sparkeys do it. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 16, 2010 pm me ur number il sort it 4 u Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 16, 2010 http://jaycar.co.nz/productView.asp?ID=SY4...mp;form=KEYWORD I prefer this type of relay. Much easier to use I do enjoy me some wires. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted June 16, 2010 Works for me aye, not sure what's gone wrong with your setup. I used a relay from the fusebox, had spares. You should use T1 as it's the lower temp too. Which wire on the temp sensor are you grounding? Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted June 17, 2010 Pretty interested in doing this to get rid of my buggered fan clutch, car overheats in auckland traffic, but never in palmy traffic, so not too much of a worry for me, but would be nice when i am in auckland for it to not overheat. On m10, is it just using the temp sensor thats jammed in the water piping at the front of the block? and what sorta fan is it? just an el cheapo supercheap one/pickapart fan or what? Easy to mount to back/front of rad? Cheers Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted June 17, 2010 He's using a 7 series fan I think, But it's pretty much the same for any electric fan. Joining them is easy you can put large screws into the radiators fins and it will hold there fine. Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted June 17, 2010 He's using a 7 series fan I think, But it's pretty much the same for any electric fan. Joining them is easy you can put large screws into the radiators fins and it will hold there fine. Sweet, will just have to find some fins to screw it to then...my radiators seen better days haha. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 17, 2010 the aircon fan also works in the e30s, it fits in just infront of the rad, just behind the kidney. it usually bolts to the car as opposed to the rad.. may be a better option for you. Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted June 17, 2010 Cheers guys, managed to sort it now after talking to john, Turns out i have no idea how to read wiring diagrams, and i had power going to t1 and 0 going to earth rather than power going to 0 and t1 to earth. Big noob mistake. Thanks for all your help fellas Matt Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted June 17, 2010 Cheers guys, managed to sort it now after talking to john, Turns out i have no idea how to read wiring diagrams, and i had power going to t1 and 0 going to earth rather than power going to 0 and t1 to earth. Big noob mistake. Thanks for all your help fellas Matt noob Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted June 17, 2010 atleast he did his own haha Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted June 17, 2010 Ohhhhh , Mark , do you need a ride to the Burns unit? Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted June 17, 2010 atleast he did his own haha Ohhhhh , Mark , do you need a ride to the Burns unit? I know i didn't do it. If I cant do it i dont have a problem admitting it =P I just dont even try haha Quote Share this post Link to post Share on other sites
Venatus 2 Report post Posted June 22, 2010 Ok, Ive sorted myself out a fan now, its a two speed one, with two wires obviously for each speed. Now, from what I understand of the fuse box, the fuse terminals are prewired, and they all go to their corresponding relay sockets and these are also prewired, so if i run the wires back to the outer fuse blade sockets, and jam some fuses and relays where the low and high speed relays/fuses should be, all will be well and work? or am I wrong completely? Cheers, Bradd Quote Share this post Link to post Share on other sites
