camera doctor 25 Report post Posted August 4, 2010 While cleaning my E39 530i Touring I noticed this nasty tire wear and marking : Probably caused by the inner guard - as it seems that at some stage it has come away and been worn thru by the tire - possible sign of a historic frontal crash ? Anyway, while looking at the inner guard, I noticed this sensor floating loose between the front bumper and the inner guard -- Does anybopdy recognise it ? Whereabouts should it be located ? Thanks Quote Share this post Link to post Share on other sites
JaseNZ 53 Report post Posted August 4, 2010 looks like ye old outside temp sensor to me. Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted August 5, 2010 looks like ye old outside temp sensor to me. Cheers, But do you know where it SHOULD be - I am sure it is not supposed to be hanging loose like this ?? Greg Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted August 5, 2010 nah just leave it floating around ... its gangsta. Mines the same normally there is a clip inside the bumper shell which it pushes into. They break from time to time. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 5, 2010 And it also looks like quite a bit is broken in there too Quote Share this post Link to post Share on other sites
nickbawt 0 Report post Posted August 5, 2010 My E34's temp sensor is the same, just hanging down keeping it real. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted August 5, 2010 As stated it is your exterior temp sensor, it is located in a recess in a panel which is connected to the bumper and the splash panel/ engine protector plus attached to the lower wheel arch liner. Have a look on the 540i you have mentioned on your car's listed it should be the same as the touring. The lower wheel arch liner new from a dealer is around the $100.00 mark not sure on the panel that the sensor is housed in. Their could be other panels affected as well it might not be a cheep fix sorry to say. Allan Quote Share this post Link to post Share on other sites
westy 614 Report post Posted August 5, 2010 Pretty sure it goes in there. Also unlikely that the inner guard could do that damage to the tyre. Quote Share this post Link to post Share on other sites
Jono51 59 Report post Posted August 6, 2010 tie it up out of the way with a cable tie, as a temporary measure, until you have ordered the replacement broken parts Quote Share this post Link to post Share on other sites
