Tristan
2001 530i Motorsport
yeah probably dont need to say, but you can remove the butterface tag from it now.
good sh*t.
dont ussually like white beemers but this is coming along nicely...i would lose the M badge altogether
Mag and turbo have reps, $1800 19x8.5 19x9.5
Are these the Beyern ones or something else that actually look like LM's? Very keen on some.
Looks way better man! Weird if they dont aim in the right place. I might go get mine checked tommorow otherwise WOF's will be mega gross
Don't know how long they're staying apparently unwarrantable. Can't drive it at night (forbidden by parents) All good though, means I get Dad's car to take to work!
Where'd u get them from?
eBay shiped from Hong Kong - They said they are universal fit. f**king scammers! Refund.
What brand are they?
The Depo ones I have for my E36 have a switch inside the housing which flips the beam scatter from LHD to RHD.
(That means they're 'universal')
So can go from:
__/ __/
To:
\__ \__
Hopefully yours are the same??
It's a metal pin you can flip up/down inside by the projector part. It's beside the bulb housing. There was also a sticker on the headlight explaining it.
What brand are yours?
You should take a photo of the headlight beam (like by parking the car a few metres from a wall or garage door)
Good luck!
Edit: Read this about OEM headlights
http://www.m5board.com/vbulletin/e39-m5-e5...-lhd-roads.html
Edited by brunch
or if they're missing the switch .. you always just open them up and swap the sidewalk flare mask from light to the other.. you may need to shape them to fit the oppersite headlight but i did my e46 ones with a jar/tin car to bend them. (thats if theyre the curved type mask) If its a flat mask even better! :)
Just be very careful when openening up the lights as the plastic stalks and locators can break .. no biggie tho.
Mine are DEPO.
Edit:
Dashing to the supermarket. Will take photos afterwards, there seems to be a lot of adjustment there so I'll have a play this afternoon. Unfortunately my only wall is down a driveway which is incredibly difficult to get back up as the wheels spin haha but I'll sort it!
Anyone got link to NZTA regulations for beam scatter? And where its meant to be aimed etc?
Edited by Tristan
The easiest thing to do will be get one off your car.
There should be a metal lever inside the housing next to the bulb holder..... (if they're adjustable)
Mine are DEPO.
Edit:
I took photos but had to go to work before I could upload. I'm at work now. f**king bored as working the till on a Sunday evening.
PLEASE be adjustable. My car actually looks like a BMW now ^_^
I know that they are highly unlike to be the same as the hella ones and that you probably would have noticed this ...but just in case ... on mine there is a black cap on the top of them (looking down on them when they are installed in car) under the black cap is a little metal adjustment lever. Hopefully those ones have something similar.
There is something but im not sure if it's a cap. Like this?
My camera is out of battery so can't put pics up but I drew sorta what it looks like.
In any case, the lights still illuminate the road better than the last set but with them being "unwarrantable" and a warning about it from a lighting specialist it's an out for insurance companies.
Edited by Tristan
yup exactly like that ... twist it (like when u take bulbs out) and it should come off (if its like mine then it is just a cover) you should then see a little lever directly inside (again if its the same as mine).
To be honest i have no idea how much adjustment or what kind of adjustment this makes so use with care, noticed it the other day and actually says on the cap of mine "adjustment".
I'll have a looksie tomorrow morning, I saw it earlier and tried to take it off but it didn't come easily and I was scared I was breaking something haha.
Hate to say it but I dont think depo have the same option as OEM lights to switch over ... youll need most likely open them up as I was saying before and switch the masks inside the projector globe from left to right and right to left and modify them.
Let me know if you need help, happy to lend a hand if needed.
That'd be great if you could. I'm in Orakei - what area are you in?
After my headlight problems I bit the bullet and bought OEM Hella clears for $1200.00
Getting a refund from the eBay seller for unit cost but they can't refund the installation cost which was a bit but oh well. Trying to get the importer to sort something out because the car shouldn't have passed compliance with the lights it came in with.
Looks better though :)
Wheels are coming soon.
19"s and will be something different. Think Pjay..
