jager 0 Report post Posted September 5, 2010 Hey guys, I have a mighty 316i and just over 2 years ago the radiator split right down the side tank. We had it replaced at the cost of $1000 and all was well in the world. I had it on the hoist last week for a pre wof check and noticed coolant on the guard underneath. I had seen this before but thought I'd check back at a later date. Then this morning I went outside and noticed a little damp spot on the drive way right under where I had discovered the coolant leak. So looks like I'm in for another new Radiator. So what are my options? I want an after market one due to the issue with BMW ones. I know my car is only a 316i and I don't work it very hard but is there a alloy version or something to that degree? It's getting higher up in the Km's but we have owned it for 8 years and I can't see selling it in the near future. I was how ever considering a turbo swap, so would like some future proofing. Cheers Andrew Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted September 5, 2010 sometimes you can reclamp the tags with some pliers or use a screwdriver and hammer . they dont seam to use much clamping pressure when they make these radiators , i got a new one for amy e28 m5 engine and had to go back 3 times for replacements under warranty , the next time it started to leak i just reclamped it and no problems since then Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted September 5, 2010 I've got the same problem. But for a 328. I think they both share the same radiator http://www.bimmersport.co.nz/forums/index....showtopic=31193 I still haven't made a decision Quote Share this post Link to post Share on other sites
fuzyfrog 0 Report post Posted September 6, 2010 Me too Quote Share this post Link to post Share on other sites
jom 98 Report post Posted September 6, 2010 I've got the same problem. But for a 328. I think they both share the same radiator http://www.bimmersport.co.nz/forums/index....showtopic=31193 I still haven't made a decision I got a new, assembled rad from Abel Smith Radiators in Wellington for about $380. It works. Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted September 6, 2010 I got a new, assembled rad from Abel Smith Radiators in Wellington for about $380. It works.So no plastic end tanks? Would you be able to get me the dimensions of the core Quote Share this post Link to post Share on other sites
jom 98 Report post Posted September 8, 2010 So no plastic end tanks? Would you be able to get me the dimensions of the core It has plastic end tanks. Identical to the original, made up by assembling pattern end tanks to a pattern core. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted September 8, 2010 Silverdale radiators. Round 3hundy. Check Trade me. Quote Share this post Link to post Share on other sites
