Linden 0 Report post Posted September 17, 2010 Hey guys where's the cheapest place to get a set of locknuts for a E30 (bolt kind) I also need to get some longer wheel lugs to run with slip on spacers, I mag and turbo have some for $2-$3 each is there anywhere to get a set from? Cheers Linden Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 17, 2010 I think you might be stuck with getting them from M&T or try Tardme Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted September 17, 2010 or convert to wheel studs Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 17, 2010 dont piss around .. use McGard http://www.mcgard.com/Applications/Automot...44K1gwvBg%3d%3d Quote Share this post Link to post Share on other sites
Linden 0 Report post Posted September 17, 2010 how much are they? Jono do you have any stock yet? cause i know when i got my rims you guys were all out.. Quote Share this post Link to post Share on other sites
Hi-Tek 3 Report post Posted September 21, 2010 Are you concerned Mag and Turbo are too expensive? $2-3 each is very cheap??? I had to import mine from the U.S unfortunately 32mm fronts and 42mm rears. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted September 21, 2010 Get them from M&T for that price, ones i can supply start at $3.50 each. Quote Share this post Link to post Share on other sites
brad91 0 Report post Posted September 23, 2010 can you convert e30 to wheel studs??? Im chasing some longer bolts if they make them so i can run about a 20mm spacer lol Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted September 28, 2010 Yeah ive got wheel studs in my e30. Its piss easy, makes for easier changing wheel, lets you use normal locknuts, and you can get any length, so you can get them to suit spacers. I got mine off a member here, but irc this guy here sold some for e30's a while back too, hit him up if you're keen Quote Share this post Link to post Share on other sites
