OLLIE 27 Report post Posted September 20, 2010 Car in question here is my E30 race car. Started fine the other day, but then when I stopped to get McDonalds it randomly decided to not want to start. After several attempts I decided to give up and eat my lunch, after i'd eaten I turned the key and with a small struggle it started. The alternator is charging perfectly okay, and i've charged the battery right up to be sure. So the alternator is out of the equation. The starter motor is turning over, but sounds like it's struggling. When I put a jumper pack on it, I could get it to start okay so.... this led me to believe that my battery was at the end of it's life ... So I bought a new one, charged it up but the same thing is happening. Any Insight would be awesome, need to get it going ASAP Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 20, 2010 (edited) Have you checked all your earth cables Ollie?? Especialy the engine to chassis one by the R/H engine mount Edited September 20, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted September 20, 2010 Have you checked all your earth cables Ollie?? Especialy the engine to chassis one by the R/H engine mount I haven't done a good full earth cable check but I put a jump lead from the battery straight to the motor with no result. Unless ... the earth cable on the starter motor is the one that's causing problems ... Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 21, 2010 It could be an earthing or a positive lead problem... check all your battery, starter, alternator & earth leads and connections Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted September 21, 2010 I'll check them all first thing when I get home. You think it's more likely this than the actual starter motor playing up? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted September 21, 2010 Without being able to check it, its hard to say...could be a starter fault.. do you have a multimeter ? and do you know how to use it ? (no offence intended ) Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted September 21, 2010 I have a multimeter but barely know how to use it Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted September 21, 2010 Check that strap mentioned above. I have another working starter motor otherwise if you want it. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted September 21, 2010 Ollie, Battery, leads, isolator switch, starter 1) Battery has been eliminated 2) Leads/ connections - sounds as if you have eliminated the earth 3) Isolator switch -check voltage in & out - while cranking. Or a good jumper lead from battery positive to starter - bypassing the isolator 4) Starter - if above leads are good - then will be faulty starter. Adding another battery source can mask a starter issue - with the extra current available. Another possibility but unlikely - over advanced ign timing Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted September 22, 2010 Conclusion is that the starter motor is poked .... Putting a replacement in tomorrow, I love leaving things to the last minute. Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted September 22, 2010 Result is a result Get on the end of that spanner there's racin' to be done! Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted September 23, 2010 Huge Thanks to Mike (MK Motorsport in Albany) who worked on the car yesterday to swap the starter motor and get it ready for racing. And of course a huge thanks to Ray for a replacement starter motor at such short notice. It's awesome to help this kind of support !! Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3034 Report post Posted September 24, 2010 Glad you are all fixed up mate! Would have been funny watching Andrew push start you for each session though. .. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted September 24, 2010 Glad you are all fixed up mate! Would have been funny watching Andrew push start you for each session though. .. hahaha great call, too true Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted September 24, 2010 See you tmoro Ollie, had a great day today, wind and rain and dead gazebos and all. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted September 25, 2010 Was the starter I gave you a dud? Quote Share this post Link to post Share on other sites
