Ben 0 Report post Posted October 24, 2010 Im after the following parts for a single mass conversion on my E36 M20 Flywheel M20B25 clutch M20 Starter Motor Preferably in wellington region Cheers Quote Share this post Link to post Share on other sites
Jono51 60 Report post Posted October 24, 2010 Im after the following parts for a single mass conversion on my E36 M20 Flywheel M20B25 clutch M20 Starter Motor Preferably in wellington region Cheers flywheel needs to be machined to fit best you get a new clutch, and make sure you use the facelift starter that is smaller, you will need to modify the slave cylinder rod length just a heads up, before you start buying parts Jon Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted October 24, 2010 (edited) if you use a early m20 flywheel you dont need to machine any meat off the back , like a early e30 , e21 320i 323i 325i e28 520i 525e etc. also you can use a E21 throw out bearing so you get the correct clutch height etc. Edited October 24, 2010 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted October 24, 2010 if you use a early m20 flywheel you dont need to machine any meat off the back , like a early 320i 325i etc. also you can use a E21 throw out bearing so you get the correct clutch height etc. Good info. Needed to know that too for when I do my conversion. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted October 24, 2010 is this when using an E36 transmission? i better keep an eye on this thread for info too, good to know for when i upgrade if i need to! Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted October 24, 2010 Thanks for the info guys Is it possible to use the E36 pressure plate on M20 flywheel but with M20 clutch disc? Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted October 24, 2010 is this when using an E36 transmission? i better keep an eye on this thread for info too, good to know for when i upgrade if i need to! Pretty sure it works with E36 and E30 trans Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted October 24, 2010 (edited) Thanks for the info guys Is it possible to use the E36 pressure plate on M20 flywheel but with M20 clutch disc? no use a m20 clutch with m20 flywheel . you can get them beefed up to suit the extra torque etc . had auto clutch in morning side do my one . work s fine with 328i coupe , found a 6.5KG flywheel from a very early eta engine (325e, 525e) Edited October 24, 2010 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted October 24, 2010 Those light flywheels also come on some of the early 323's. Quote Share this post Link to post Share on other sites
Jacko 2237 Report post Posted October 24, 2010 (edited) Any more details on the longer throw out bearings? Ive stumbled across it before, but assumed it had something to do with M42's with E36 boxes in E30's, using M20 single mass flywheels. Edited October 24, 2010 by Jacko Quote Share this post Link to post Share on other sites
