kiwi535 538 Report post Posted December 20, 2010 it turns out i have a detachable tow bar on the 120,which is handy for the occasional trip to the dump and or cycle carrying.However.......the tow ball is 50mm which is not compatible with 100 percent of the hire trailers round here.I was told that you can have either,and i thought that 50mm is the NEW std.....whats the go?I dont want to buy a trailer for the 1x in 5yrs that i will need it Quote Share this post Link to post Share on other sites
leithcm 0 Report post Posted December 20, 2010 You could go out and buy a nice, new, chromed 1 7/8"" ball - the old standard size - and fit that to the removable tongue instead. I think you may find that most trailer tow hitches are so worn the 50 mm new standard will fit. After all, there is only 2 mm between the two sizes! Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted December 20, 2010 I've been told that there are 2 standard sizes. Most trailers you hire from the petrol station etc are the smaller sized ones. But on my parents car has a larger tow ball, heavier duty for their boat and car trailers, which both have larger tow hooks, weird I know! I only found this out when I tried fitting a hired trailer on Smaller size would be the way to go unless your hauling an XL trailer around. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 21, 2010 (edited) You could go out and buy a nice, new, chromed 1 7/8"" ball - the old standard size - and fit that to the removable tongue instead. I think you may find that most trailer tow hitches are so worn the 50 mm new standard will fit. After all, there is only 2 mm between the two sizes! cant change the ball the arm and ball are all one peice...what i want to know is..will the 50mm coupling become more common? its similar to this Edited December 21, 2010 by kiwi535 Quote Share this post Link to post Share on other sites
OP6 27 Report post Posted December 21, 2010 its similar to this You can get that towbar machined down to the 1 and 7/8th size. Last time I heard it was $120 here in Chch. Chapman engineering in Maryland Place Christchurch if you cannot find anyone in Wellington. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted December 21, 2010 you can machine them down to 1 7/8's ... makes it incompatible with 50mm however. Basically, you need two or pick a hire company that hires 50mm Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 21, 2010 you can machine them down to 1 7/8's ... makes it incompatible with 50mm however. Basically, you need two or pick a hire company that hires 50mm but is 50mm to be the new std?? Quote Share this post Link to post Share on other sites
Braeden320 0 Report post Posted December 21, 2010 http://www.nzta.govt.nz/resources/glovebox...ing-towing.html Looking here you would think so, but will probably take along time to become the more common option. I would go 1 7/8, your local hire company are unlikely to change anytime soon, and if they do will not doubt keep some older style trailers as allot will still have 1 7/8 Quote Share this post Link to post Share on other sites
Driftit 2222 Report post Posted December 21, 2010 Most trailers these days are both. Unless they are very old. Lift the handle and turn it 180deg. All the trailers at my local gas stations are both sizes. They need to be these days. Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted December 22, 2010 I've got a multi-fit on the X5 so within seconds I can change from 1"7'8ths to 50mm, 1"7'8th's is the standard for most trailers/boats e.t.c under 2 ton. If you have the standard donkey cock you can take this in to be machined down to the size you need. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 22, 2010 Most trailers these days are both. Unless they are very old. Lift the handle and turn it 180deg. All the trailers at my local gas stations are both sizes. They need to be these days.Well i went to every gas station from central wellington to Johnsonville,including karori,and every single one was the 1 7/8 coupling.Are the duals marked 1 7/8 one side and 50mm the other?Most of the "service" station attendants(when i did ask) had no idea what i was talkin about. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 22, 2010 I've got a multi-fit on the X5 so within seconds I can change from 1"7'8ths to 50mm, 1"7'8th's is the standard for most trailers/boats e.t.c under 2 ton. If you have the standard donkey cock you can take this in to be machined down to the size you need. that sounds like what i will do I have thought about getting the "donkey cock" machined to allow the fitment of the convertable balls,but not sure it is possible Quote Share this post Link to post Share on other sites
westy 614 Report post Posted December 22, 2010 I have a fancy Canadian thing on mine with 3 different sized balls! Those Canadians got balls allright, Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 22, 2010 We went metric in 1972 isn't about time some people accepted this?? The most stupid one is Sports commentator describing a player as 6 foot 3 and 81kg WTF ? 1-7/8 is 48 mm not 50 mm exactly,a 50mm coupling will go on a 1 7/8 ball but a 1 7/8 coupling will not go on a 50mm ball. i still think fuel consumption in mpg Quote Share this post Link to post Share on other sites
Driftit 2222 Report post Posted December 23, 2010 Well i went to every gas station from central wellington to Johnsonville,including karori,and every single one was the 1 7/8 coupling.Are the duals marked 1 7/8 one side and 50mm the other?Most of the "service" station attendants(when i did ask) had no idea what i was talkin about. Yeah most will say which side is what size. My car trailer has one of these. You just pull the handle up and turn it to the other side. Most rentals I have encounted are the same. But on my E30 I had two Donkey cocks. Just bunged in what ever one fitted. See if you can locate the other size. http://www.trojan.co.nz/index.asp?PageID=2145834345 Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 23, 2010 Yeah most will say which side is what size. My car trailer has one of these. You just pull the handle up and turn it to the other side. Most rentals I have encounted are the same. But on my E30 I had two Donkey cocks. Just bunged in what ever one fitted. See if you can locate the other size. http://www.trojan.co.nz/index.asp?PageID=2145834345 But Dan - you are talking brake couplings - arent you? I have not seen a standard coupling as dual fit - not that I remember anyway Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 23, 2010 Yeah most will say which side is what size. My car trailer has one of these. You just pull the handle up and turn it to the other side. Most rentals I have encounted are the same. But on my E30 I had two Donkey cocks. Just bunged in what ever one fitted. See if you can locate the other size. http://www.trojan.co.nz/index.asp?PageID=2145834345 might look again tomorrow Quote Share this post Link to post Share on other sites
Driftit 2222 Report post Posted December 23, 2010 They have them at some of the local gas stations around where I live. And the Hirepool ones I have hired have both and they were also un-braked. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 23, 2010 They have them at some of the local gas stations around where I live. And the Hirepool ones I have hired have both and they were also un-braked. only looking to hire a little trailer,not a car trailer. Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 24, 2010 confirmed.ALL the the hire trailers from gas staions around here are 1 7/8 only.hire quip have one tandem axle trailer(braked) with a multifit coupling.All the furniture trailers and the car trailers are 50mm only(hirequip) I note that trojan(make trailer bits)have a multifit non braked coupling.hopless,most of the service stations i went to didnt even know what i was asking! Quote Share this post Link to post Share on other sites
Driftit 2222 Report post Posted December 24, 2010 only looking to hire a little trailer,not a car trailer. Yeah thats what I am talking about. Own my own car trailer so don't hire them. Spose it depends on when the hire trailers were made. Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted December 24, 2010 (edited) exactly,a 50mm coupling will go on a 1 7/8 ball but a 1 7/8 coupling will not go on a 50mm ball. i still think fuel consumption in mpg If it's a 120d mate, I can't see you towing more than 1500kg - normally 50mm ball's are 2500kg + say. I have two interchangeable balls. Edited December 24, 2010 by The Diesel Guy Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 24, 2010 If it's a 120d mate, I can't see you towing more than 1500kg - normally 50mm ball's are 2500kg + say. I have two interchangeable balls. i dont want to tow 2500 but the tow bar/ball thing that came with the car IS 50mm,and being able to take a trailer every now and then is bloody handy,but its very frustrating to find that i cant use it! Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted December 24, 2010 i dont want to tow 2500 but the tow bar/ball thing that came with the car IS 50mm,and being able to take a trailer every now and then is bloody handy,but its very frustrating to find that i cant use it!Definitely not, I'd say the 1 series would have a tow rating of 1200-1500kg? Quote Share this post Link to post Share on other sites
