Gaz 1075 Report post Posted December 22, 2010 Need one ugently as i lost mine over the weekend test fitting my wheels and need to get them off before they do some serious guard damage. I tried my flatmates one but it was too big, had a 14 on it so guess i need a 12??? Any help much appreciated Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted December 22, 2010 i think bmw have more than a thousand different combinations . Quote Share this post Link to post Share on other sites
HELLBM 1674 Report post Posted December 22, 2010 48 combo`s of BMW lock-nut keys. We have about half of them and what we do for the rest is hammer in one that is close. Car needs to come to us unfortunately unless you are nearby. Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted December 22, 2010 It would be a long drive just for a lock key but thanks. Might have to hit up some of the wreckers down here. Cheers Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 22, 2010 When you get one of the lock bolts out, the number for the key will be stamped into the end of the threaded bolt. You can then order a key & new bolt... or buy a new lock nut set for $50 Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted December 23, 2010 Went down go JG this arvo and picked one up for $17. Chur Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted December 24, 2010 When you get one of the lock bolts out, the number for the key will be stamped into the end of the threaded bolt. You can then order a key & new bolt... or buy a new lock nut set for $50 Where does one get a new lock nut set for fitty dollars? Quote Share this post Link to post Share on other sites
