BMS 0 Report post Posted February 6, 2011 Here are some pics of my latest steed in progress, motor has to go down and back 100mm to shut the bonnet but wanted to make sure it fitted in the hole first. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted February 6, 2011 nice. I like how is the clearance between the sump and subframe etc?? what ecu etc are you going to run with? my suggestion is use a e34 /e32 M60B** engine loom etc and use the bosch ecu thats used in the early e34 530i 540i e32 730i 740i etc then you dont have to worry about ews etc also the bosch ecu's are easier to remap etc Quote Share this post Link to post Share on other sites
BMS 0 Report post Posted February 7, 2011 Heaps of room, it needs to back for the front of the sump to clear the sway bar. I'm going to have to move the firewall back a bit and open the tunnel up to fit the bell housing. Then put a Willwood reverse pedal box inside but hey its only cash Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted February 7, 2011 Heaps of room, it needs to back for the front of the sump to clear the sway bar. I'm going to have to move the firewall back a bit and open the tunnel up to fit the bell housing. Then put a Willwood reverse pedal box inside but hey its only cash sounds good .if you need any bits to help you make it work , just sing out Quote Share this post Link to post Share on other sites
twisted 45 Report post Posted February 7, 2011 Mint. What Box are you using? Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted February 7, 2011 Add bonnet bulge for more room and street cred? lol Quote Share this post Link to post Share on other sites
BMS 0 Report post Posted February 7, 2011 Not sure yet, would like a 530 5 speed but pretty hard to find so I kept the auto bell housing and ring gear so maybe graft something on to that. Toyota box???? Quote Share this post Link to post Share on other sites
BMS 0 Report post Posted February 7, 2011 I want to keep it looking standard from the outside, sleeper style. Quote Share this post Link to post Share on other sites
Gotheschu 1 Report post Posted February 7, 2011 hahha holy ****. gonna be awesome Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted February 7, 2011 Das ist fantastische! Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted February 7, 2011 Das ist fantastische!+1 Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted February 7, 2011 Good luck with traction Quote Share this post Link to post Share on other sites
BMS 0 Report post Posted February 8, 2011 Haha that's why i'm building it traction is over rated. The paxton or vortech blower will eliminate any hope of traction. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted February 8, 2011 Want some E21 with that motor? Quote Share this post Link to post Share on other sites
twisted 45 Report post Posted February 9, 2011 (edited) Not sure yet, would like a 530 5 speed but pretty hard to find so I kept the auto bell housing and ring gear so maybe graft something on to that. Toyota box???? Been doing my sums on importing boxes, keeping an eye out etc. Can be done reasonably cheaply if your on to it and bide your time. Thought about a bit of cut and paste with auto bellhousing myself, just not sure how complex it would be? I'll be watching this thread with interest: Blown Manual M62 E21. Awesome! Edited February 9, 2011 by -Alias- Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted February 9, 2011 Haha that's why i'm building it traction is over rated. The paxton or vortech blower will eliminate any hope of traction. Yes please! You might need a diff plan too - small case diffs aren't the strongest. Quote Share this post Link to post Share on other sites
crazyarab 6 Report post Posted February 9, 2011 (edited) Man I want to have a look at this, we should catch up sometime! p.s. how do you plan to get around the EWS? Edited February 9, 2011 by crazyarab Quote Share this post Link to post Share on other sites
BMS 0 Report post Posted February 10, 2011 Hey dude feel free to pop over to my workshop anytime, I'm gonna use an after market ECU. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted February 10, 2011 Hey dude feel free to pop over to my workshop anytime, I'm gonna use an after market ECU.give me a call if you like 021433600i used a 4L ecu and loom etc , save yourself lots of $$$$ and got good results. see here for some details http://www.bimmersport.co.nz/forums/index....15&start=15 Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted February 10, 2011 EWS isnt too difficult to get around, Just gotta have a EWS module/key and any old antenna loop and find someone with GT1. Quote Share this post Link to post Share on other sites
gmblk 0 Report post Posted August 27, 2013 has this project been finished? i`m starting the same swap any info would be appreciated) Quote Share this post Link to post Share on other sites
