Carl 3 Report post Posted May 5, 2005 My car starts perfectly when cold but when it's warm it doesn't start as quick. Sometimes it won't even start at all on the first attempt but if I wait a few seconds and try again it's fine. It only does this after i've been driving it around and the engine is nice and hot, always starts instantly when cold Ideas anyone??? Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted May 5, 2005 I have 100% exactly the same thing with my car. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted May 5, 2005 The car still works doesnt it? So whats the prob? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted May 5, 2005 The problem is that it's f'ing annoying, especially when i've pulled up to a service station on a long trip and after filling up she won't start...it's ebarrassing My only concern is that it may be indicative of something serious, perhaps a fuel pressure regulator or something remote like that, just curious. Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted May 5, 2005 (edited) I noticed my car idling like it was getting low on fuel just after I started it this afternoon (I filled it up this morning). I think it may be soemthing to do with the fuel just isnt getting in fast enough. Edited May 5, 2005 by E30stz Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted May 5, 2005 (edited) tried turning key on, waiting a few seconds then try???? I've had a couple cars that were like that, nothing wrong, they often have a small delay when hot for like a check sequence or something..... s4 rx7s do it, volvo and scania trucks blah blha blah..... just an ecu self check, might not happen on urs but then again..... dount it with dirty old motronic ewwness...... bah, I'm rambling seems kinda weird, any BMW I've ever been near was terrible on cold start.... stalling and sh*t.... Edited May 5, 2005 by CaM Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted May 5, 2005 I noticed my car idling like it was getting low on fuel just after I started it this afternoon (I filled it up this morning). I think it may be soemthing to do with the fuel just isnt getting in fast enough. maybe ICV???? sparkle's changes notably when you unplug it whilst it's running....... Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted May 5, 2005 sorry and hte ICV is .. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted May 5, 2005 Idle Control Valve If the valve is on it's way out then you'll get a revy idle, ie, the revs will go up and down like a yoyo. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted May 5, 2005 seems kinda weird, any BMW I've ever been near was terrible on cold start.... stalling and sh*t.... You must have bad luck, i've yet to see one that didn't start well in the cold, even Tim's car somehow manages to start perfectly in the cold!!! Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted May 5, 2005 yeah but just comparing them with their hot start.... sparkle's was gay for a while, sounded like a mad vt@k bridgeport 13b yo!! but 'tis sweet now..... also starts better hot with new headgasket.... his also runs quite smooth with the icv unplugged, maybe something to do with the ecu overcompensating with the fairly rough idle since his porting job. New ICV as well... No vaccuum leaks carl?? Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted May 5, 2005 replaced your fuel filter lately? Cheers Grant Quote Share this post Link to post Share on other sites
E30stz 0 Report post Posted May 5, 2005 mine had full service @ BMWorkshop last week. I would have thought they pick up on it if it could have been fixed. Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted May 5, 2005 it's a fuel problem, might be the relay coil getting too hot! Quote Share this post Link to post Share on other sites
*RJ* 0 Report post Posted May 5, 2005 it's a fuel problem, might be the relay coil getting too hot! Very very common in early 90's Hondas so could be that.Whenever I fill my car up (it's usually warm) and I re-start it, it pulses a few times before going back to a normal idle. Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted May 5, 2005 Injectors poked perhaps. My car did this till I got different injectors. They stay open when its hot and flood the motor - it would always start if you cranked it and then just stopped cranking it - would sputter into life. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted May 5, 2005 Injectors poked perhaps. My car did this till I got different injectors. They stay open when its hot and flood the motor - it would always start if you cranked it and then just stopped cranking it - would sputter into life. Yes, it does that sometimes, keep cranking it then stop and give it a little gas and she splutters into life...So injectors you wrcekon, they're bloody expensive aren't they. I'm guessing then that this could be the result of my exhaust gasket not having the heatshielding, I have some new gaskets with the shields waiting to go on, perhaps that'll fix it... Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted May 5, 2005 get them cleaned (properly.. not with tank additive) Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted May 5, 2005 get them cleaned (properly.. not with tank additive) If they weren't clean wouldn't get bad perfromance/economy? I'm averaging 33 mpg as it is... Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted May 5, 2005 (edited) yeah but they moight not be closing perfectly and dripping when sitting or something...... 15 or so years of gum and varnish from sh*t nz fuel = gay diesel & turbo in petone will probably be able to check them out, and supply you with new o-rings and what have you to get them all chur.... I guess in the interim Ian would have some spares to keep you mobile Are they rattly as a mofo??? might be a good thing getting rid of that shizzle as well :pimp: Edited May 5, 2005 by CaM Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted May 5, 2005 Another possibility, could my temperature sensor be a little whack, the blue one??? Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted May 6, 2005 Another possibility, could my temperature sensor be a little whack, the blue one??? no - it will be the injectors. Cam is right they are sticking open. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted May 6, 2005 I will look into getting them cleaned, as I can't afford $600 for a new set of injectors!!! And no my injectors aren't rattly Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted May 6, 2005 its ya injectors mate i know i had same prob too. Quote Share this post Link to post Share on other sites
CaM 0 Report post Posted May 6, 2005 I will look into getting them cleaned, as I can't afford $600 for a new set of injectors!!! And no my injectors aren't rattly apparently (may be an m30 mod though) late model mutang injectors are the bizzo, once the plugs aree changed.... mega potential performance mod apparently hahaha using u.s car parts = :thumbsdown: :gay: :puke: pwn Ian's spares off that car he was wrecking.... they might be fine Quote Share this post Link to post Share on other sites
