Andre3000 55 Report post Posted May 14, 2011 Looking for some black silicone joiners for piecing my intercooler piping together. Does anyone know of a good place that doesn't charge through the arse? Also as i have no previous exp at all in this field, is there anything i should or should not do? in terms of clamping/welding? Advice would be appreciated. Cheers guys Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted May 14, 2011 DSR Turbo supplier on trademe's sells em for around $15 a peice? Quote Share this post Link to post Share on other sites
dsrturbo 0 Report post Posted May 14, 2011 (edited) Yup lots of black ones http://www.dsrturbo.com/silicone-joiners/ K&N Motorcycle Oil Filter 4 Harley, Honda, Suzuki! K&N In take kits - Holden Commodore - K&N Air Filters K&N Breather Filter - Crank Case Filter - Engine Filter - 62-1360 Custom In Take Kits - K&N Replacement Air Filters - Custom Assemblies Cleaning Air Filters - K&N Recharge kits - 99-5000 Honda motorcycle air Filters - Yamaha Filter - K&N Performance Gold K&N Oil Filters - Cross Reference Panel Filters - K&N Air in Take Kits - 33-2015 Pod Filters - K&N Air Filters - 3" intake, 4" inlet http://nzairfilter.co.nz/powersport-oil-filter/ K&N Motorcycle Oil Filter 4 Harley, Honda, Suzuki! High flowing K&N Oil Filters for all makes! Motorcycles oil filters from - Aprilia, BMW,Ducati, Kawasaki, Polaris, Triumph, Yamaha http://nzairfilter.co.nz/air-filter-intake-kit/ K&N In take kits - Holden Commodore - K&N Air Filters Cold air in take systems from K&N performance Filters - Visit our Online Store - Choose Payment options Direct Debit or Credit Card - over night delivery http://nzairfilter.co.nz/breather-filter/ K&N Breather Filter - Crank Case Filter - Engine Filter - 62-1360 Engine Filters 62-1330 stop dust & dirt from entering the crank case or throttle body. K&N Air Filters 62-1360 come in sizes from 13mm to eg 38mm http://nzairfilter.co.nz/custom-air-filter/ Custom In Take Kits - K&N Replacement Air Filters - Custom Assemblies K&N Performance Air Filters are a direct replacement air filter for V8 in take, Mazda 12A / 13B Air In takes, Honda S2000, Toyota Surf - 56-1230 http://nzairfilter.co.nz/cleaning-kits/ Cleaning Air Filters - K&N Recharge kits - 99-5000 K&N has a great range of air filter cleaner and Oil filter Oil. NZ Air Filters - Online Store Stock all the products needed to clean your air filter. http://nzairfilter.co.nz/motorcycle-air-filter/ Honda motorcycle air Filters - Yamaha Filter - K&N K&N Air Filters for Honda VFR, Kawasaki, Suzuki, Harley Davidson replacement air filters and custom air Filters - Check us out Online http://nzairfilter.co.nz/oil-filter/ Performance Gold K&N Oil Filters - Cross Reference NZ Air Filters - Stock oil Filters for all Motor Engines - Nissan Oil Filters, Toyota Filters - Cross reference HP-1003 with Ryco Z158 http://nzairfilter.co.nz/panel-filter/ Panel Filters - K&N Ford XR6 Air in Take Kits - 33-2015 Drop in Replacement Air Filters, For XR6 Turbo and XR8 Ford Falcon - Including K&N Air Filters for Suzuki Swift, Toyota Caldina air Filters and more! http://nzairfilter.co.nz/pod-filter/ Pod Filters - K&N Air Filters - 3" intake, 4" inlet Our Online Air Filter Store stock K&N Pod Filters from 18mm inlet through to 2.5", 3", 4" inlet (RU-2520) All filters are in stock - FastContact and delivery! Edited May 12, 2012 by dsrturbo Quote Share this post Link to post Share on other sites
Yankus 0 Report post Posted May 18, 2011 Theres a pipe place in East Tamaki on the corner of east tamaki rd and preston road which sells them in any size/color you want. Not too expensive either. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted May 18, 2011 Theres a pipe place in East Tamaki on the corner of east tamaki rd and preston road which sells them in any size/color you want. Not too expensive either. Do you know what it could be called? will be sorting the piping out next week. Quote Share this post Link to post Share on other sites
Yankus 0 Report post Posted May 18, 2011 Managers name is Derek. Details: Pipeline Hose Shop 285 East Tamaki Road Ph: 2716433 Quote Share this post Link to post Share on other sites
mlracing 0 Report post Posted May 20, 2011 Use big clamps not small ones or they might blow off the piping Quote Share this post Link to post Share on other sites
polley 916 Report post Posted May 20, 2011 Just bead the piping, best way to do it. Quote Share this post Link to post Share on other sites
Yankus 0 Report post Posted May 23, 2011 Place in east tamaki does clamps for them too......BIG clamps, the proper ones not girly little hose clamps. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted May 23, 2011 sweet info guys, thanks a tonne. Will be fabbing it up next week hopefully, and will post some pics up then! another quick question, is there a recommended wall thickness for the aluminium piping? I was hoping to get between 1.7mm and 2.0mm but is 2.0mm unnecessary? Hoping to blow over 20psi through these eventually. Quote Share this post Link to post Share on other sites
Yankus 0 Report post Posted May 25, 2011 Thats alot of boost, hope your not planning on trying to every day drive that thing...... Might need to ring someone who does turbo'ed cars or tuning shops on that one. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted May 25, 2011 A schedule 40 3" PVC pipe has a minimum burst pressure of 840PSI, and maximum working pressure of 158PSI. I think the aluminium will be fine Quote Share this post Link to post Share on other sites
dsrturbo 0 Report post Posted May 27, 2011 (edited) 4mm 3 layer silicone joiners will hold 30 psi. If your worried you can lightly put thin ( 5mm ) hose clamps over the silicone bends. This will help them from not blowing out like a tire. 5mm reducers and straights are a bit of an over kill and not need unless you have a 800+BHP car. Also 5 mm fat straights and reducers look very fat on the alloy piping and not such a good look. 3" inlet and 4" inlet Pod Filters and stock K&N Performance Gold Oil Filters for Nissan Silvia S14-S15 SR20DET 1993 - 2001 ( Ryco Coross reference Z158, Z386 ) at a good price Other links - K&N Motorcycle Oil Filter 4 Harley, Honda, Suzuki! High flowing K&N Oil Filters for all makes! Motorcycles oil filters from - Aprilia, BMW, Ducati, Kawasaki, Polaris, Triumph, Yamaha K&N In take kits - Holden Commodore - K&N Air Filters Cold air in take systems from K&N performance Filters - Visit our Online Store - Choose Payment options Direct Debit or Credit Card - over night delivery K&N Breather Filter - Crank Case Filter - Engine Filter - 62-1360 Engine Filters 62-1330 stop dust & dirt from entering the crank case or throttle body. K&N Air Filters 62-1360 come in sizes from 13mm to eg 38mm Custom In Take Kits - K&N Replacement Air Filters - Custom Assemblies K&N Performance Air Filters are a direct replacement air filter for V8 in take, Mazda 12A / 13B Air In takes, Honda S2000, Toyota Surf - 56-1230 Cleaning Air Filters - K&N Recharge kits - 99-5000 K&N has a great range of air filter cleaner and Oil filter Oil. NZ Air Filters - Online Store Stock all the products needed to clean your air filter. Honda motorcycle air Filters - Yamaha Filter - K&N K&N Air Filters for Honda VFR, Kawasaki, Suzuki, Harley Davidson replacement air filters and custom air Filters - Check us out Online Performance Gold K&N Oil Filters - Cross Reference NZ Air Filters - Stock oil Filters for all Motor Engines - Nissan Oil Filters, Toyota Filters - Cross reference HP-1003 with Ryco Z158 Panel Filters - K&N Air in Take Kits - 33-2015 Drop in Replacement Air Filters, For XR6 Turbo and XR8 Ford Falcon - Including K&N Air Filters for Suzuki Swift, Toyota Caldina air Filters and more! Pod Filters - K&N Air Filters - 3" intake, 4" inlet Our Online Air Filter Store stock K&N Pod Filters from 18mm inlet through to 2.5", 3", 4" inlet (RU-2520) All filters are in stock - FastContact and delivery! Edited May 8, 2012 by dsrturbo Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 29, 2011 Use 5 ply joiners for higher boost turbo applications. Quote Share this post Link to post Share on other sites
