byza213 1 Report post Posted May 26, 2011 got my car back from panel shop and they noticed exhaust leak ,because one of the bolts on the manifold at the head is missing , i hope its just missing. car sounds look crap at the moment where to source these bolts? Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted May 26, 2011 You can use bolts instead of studs which is OEM. M8x1.25 30mm Give EDL a call they should be able to help you out. Something like this: Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted May 26, 2011 sweet bro cheers for that! Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 26, 2011 You might also find that it has a broken stud in the head (a common E30 problem) which will require removing the exhaust manifold to repair. Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted May 26, 2011 if its stuck head will need to be removed ? correct me if im wrong i will get it checked out and go from there. Quote Share this post Link to post Share on other sites
tire 10 Report post Posted May 26, 2011 Byron, FYI I never touched the exhaust manifold when I had it. Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted May 26, 2011 no worries Max guess these things happen changed flanged gasket about 3 months ago was a leak there , put exhaust tip on also cant wait to get this sorted , i havent driven it in a while! hope its just a case of changing bolts Quote Share this post Link to post Share on other sites
polley 916 Report post Posted May 26, 2011 if its stuck head will need to be removed ? correct me if im wrong i will get it checked out and go from there. They can be removed with the head in place. You need to drill down the center of the stud then use an EZ out to remove it. It is easy to f**k up and if you snap the EZ out then the head defiantly will need to be removed. It would be best to take it to someone who has done it before, at least if they f**k it up it's their problem Quote Share this post Link to post Share on other sites
