Ben
E36 Gearbox Removal
I need to drop my gear box to change release bearing
and just wondering
Do you have to remove the whole driveshaft or can you just slide the front half
back inside the rear half? (If you know what I mean)
I havent removed the heat shielding to see whats going on around the support bearing
yet but just want to know if I can short cut removing the whole driveshaft
Any insight appreciated
Cheers Ben
Take it out completely.
You can slide it into the rear half at the slip joint, but only as far as you need to, to remove it from the gear box.
It's easy.
I don't think you have the space to slide the box back enough. I'd just remove it.
Top bolts that hold the box to the engine suck. If you can run extensions and universals to the back of the box while someone else holds the torx bit in place it should be easier.
Good luck
Anybody taking gboxes out of these things needs wobble extensions like these.
They are the sh*t, seriously.
unbolt whole exhaust system , undo front part of drive shaft from gearbox, unbolt hanger beraing , push drive shaft out of teh way .
disconect the gear shifter linkage at gearbox end.
unbolt gearbox bolts and rear mount , slide back etc
Thanks for the advice guys
Working under a lowered bmw is officially on my hate list now but I got it done
I felt like an amateur after I removed the heat shielding and saw how simple it was.:rolleyes:
Ended up removing the support bearing and the exhaust mount behind it
then the dshaft pretty much fell out.
