Eddie 66 Report post Posted December 13, 2011 This car may be about to get a 6 speed gearbox, I should know within a week Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted December 17, 2011 the 6 speed is here Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted December 17, 2011 thats one lucky ti. What and where is the 6 speed from Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted December 17, 2011 Looks like an AZ6 from a Toyota (J160) Also found on S15 Sylvia, S2000 and MX-5's (all with different front/bell housings). Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted December 17, 2011 Looks like an AZ6 from a Toyota (J160) Also found on S15 Sylvia, S2000 and MX-5's (all with different front/bell housings). Yes Toyota box. 3sge flywheel fits to bmw crank with very little mod. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted December 17, 2011 Yes Toyota box. 3sge flywheel fits to bmw crank with very little mod. Nice!! The wife has one in the RS200. What are you plans for attaching to the BMW motor? Cut'n'Shut the mounting flange or a plate adaptor? Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted December 18, 2011 (edited) At this point it looks like I will make an adapter plate and use the toyota starter motor. I have started to make up some templates of both bell housings. Failing that I will get a BMW flywheel and then cut both bell housing and welded the bmw to the toyota. These are cheap gearboxes. Its a mates deal but he said that he sold the last two- flywheel to drive shaft for $600 This box is off a 1g which puts the starter on the same side as the bmw Edited December 18, 2011 by rot62 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted December 19, 2011 new bumper Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 19, 2011 seems to me like E36 compacts are the next big thing Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 19, 2011 seems to me like E36 compacts are the next big thing Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted December 19, 2011 After some more measuring the adapter plate idea is out. I'm going to cut the bellhousing. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted December 24, 2011 The car got a new bumper the old the new Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted December 24, 2011 (edited) Also I now a have 6 speed box waiting to be installed 1- cut up the bell housings with your angle grinder 2- machine them true 3- weld them together A manual box for the Ti awaits Edited December 24, 2011 by rot62 Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted December 24, 2011 Looks good! Nice bumper and that Gearbox will be awesome Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 24, 2011 seems to me like E36 compacts are the next big thing They always have been ..not many in this country as quick as mine Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted December 24, 2011 (edited) They always have been ..not many in this country as quick as mine This one will be quicker The cost for this gearbox with 6 cylinder fly wheel, starter motor, 6 speed toyota gearbox, bmw bell housing, welding supplies, support bearing, toyota clutch plate, manual pedal box. ( not including time and drive shaft still to be made) $780.00 Edit- I would have sent close to 10hrs making this work Edited December 24, 2011 by rot62 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 24, 2011 This one will be quicker Will be a few more with a bit more balls than a standard m52 might be time to spercharge to stay in the game Glenn! Quote Share this post Link to post Share on other sites
Jono51 61 Report post Posted December 24, 2011 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted February 2, 2012 Tonight I started playing around with the old Willwood 6pot calipers I took off my race car and found that if I use a rotor around the 295mm mark I might be able get them to fit inside a 15" wheel Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted February 2, 2012 impressive! .. I like the wheel/brake setup. Cheap slicks! Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted February 2, 2012 I'm trying to make it fit a 15" so we can it on gravel as well Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 16, 2012 (edited) In prep for some up and coming NA battles I ran the car up on the Dyno 80hp at the rears @5000 The car just lost power after that last night I removed the auto box. This morning I machined the flywheel to take the thinner Toyota clutch plate. Edited March 20, 2012 by rot62 Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 19, 2012 surfacing the flywheel the 6 speed gearbox is in and working Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted March 19, 2012 Now that is a cool mod! This is going to be cool Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted March 20, 2012 I played with the car on the dyno tonight. The Manual box gave the car an extra 8hp at the wheels @5000 After messing with the AFM and the tps I got afr to 13.2 from 14.3 on wot. Now the car makes just on 100hp @5800 Quote Share this post Link to post Share on other sites
