camera doctor 25 Report post Posted September 27, 2011 Just had a play with this over the weekend. Purchased on Ebay, came nice and fast, free shipping. Ebay Auction First thing you need to do is do the AV in Mod to your Video Module - Plenty of threads about how to do that on here and other forums. Then the DVB-T box simply plugs into the AV in, there is a IRed remote sensor that you can run to the front of the car, and the two aerials sit by side windows of my Touring, I guess on a Sedan you could put them on the rear Screen or Parcel Shelf. Here is PRIME TV ( if you look close you can see the PRIME Logo ) Program Info ( Moire pattern is from camera, pic is clear in car ) EPG - this is a little hard to see on the 16:9 screen as resolution is not the best on this 10year old LCD Teletext works, if anyone uses that Apparently you can plug a USB pendrive into the unit and use as a PVR too !! It also has 3x Composite Video Outputs, so you could drive the front screen plus 2 headrest LCDs for the back seat passengers. Also has HDMI output if you wanted to put in a bigger or clearer LCD, or if your car does not have the BMW screen. Reception seems not too bad, considering Timaru is not the best yet for DVB-T, I would guess it would work even better in the bigger centres. I am off the CHCH this Saturday, so will see how it goes there. Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted September 27, 2011 i'd be interested to know how it goes.... Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted September 27, 2011 Thanks for posting Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted September 27, 2011 M5V8 said: i'd be interested to know how it goes.... The pics are the unit in my car, so it goes great !! Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted September 28, 2011 Clever little begga aint ya Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted September 28, 2011 the picture quality isn't to do with the lcd resolution , .its to do with the composite input being used , and not a s-video , component or hdmi input being , which your factory screen doesn't have. so all the digital imformation is converted down to a rgb type signal then converted to a s-video type signal then down to composite signal. so its like tring to empty the bath through a plug hole rather than cutting the bottom of the bath out then going back the other way. nice upgrade though when the analog signal gets turned off. would be interesting to see if you can break into the signals from the factory tv tuner and see if there is a rgb or digital signal going to the factory screen Quote Share this post Link to post Share on other sites
Neal 553 Report post Posted September 28, 2011 Nice mod , getting ready for analog switch off plus another video input e39 e46 x5 mk1 video module or bm53/54 tuner module to screen is RGsB. Note sync on green which cuts down choices. Quote Share this post Link to post Share on other sites
nordschleife 0 Report post Posted September 28, 2011 Interesting. What do you mean by AV in mod? Hooking up the Aux in or moding the VM / Radio module to play in stereo? If it's the latter can you please post a link? Quote Share this post Link to post Share on other sites
Crazy Dave 0 Report post Posted September 29, 2011 So Greg, where did it come from and what do they cost? Are you only up in Christchurch for Saturday? It would be good to catch up but I am in Johannesburg and dont get back into ChCh until Sunday afternoon. BTW - South Africa has one of the highest rates of BMW ownership I have ever seen in the world. Must be 1 in 20 vehicles on the road seems to be a BMW. I am putting feelers out to see if the wreckers have parts that I can get shipped to NZ ( like MkIV nav units and ULF modules ) camera doctor said: Just had a play with this over the weekend. .......................................................... Reception seems not too bad, considering Timaru is not the best yet for DVB-T, I would guess it would work even better in the bigger centres. I am off the CHCH this Saturday, so will see how it goes there. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted October 2, 2011 Brent HARTGE535i said: the picture quality isn't to do with the lcd resolution , .its to do with the composite input being used , and not a s-video , component or hdmi input being , which your factory screen doesn't have. so all the digital imformation is converted down to a rgb type signal then converted to a s-video type signal then down to composite signal. so its like tring to empty the bath through a plug hole rather than cutting the bottom of the bath out then going back the other way. nice upgrade though when the analog signal gets turned off. would be interesting to see if you can break into the signals from the factory tv tuner and see if there is a rgb or digital signal going to the factory screen Remember the resolution of the screen: 400x240 So HDMI is simply a waste of time What will improve the signal hugely is if you can feed it RGB, because the native screen has RGB. Remember the native screen also uses sync on green, so an adapter will need to be used. And if you feed it RGB, you loose the nav control over the video: ie: tapping into the RGB lines directly, and the nav won't be able to switch the video from TV to nav to show you the navigation instructions. Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted October 2, 2011 Dave - Sorry was only in CHCH for Saturday, up to see the Motorhome Expo See the Ebay link in my original post for cost and seller. nordschleife - I am using the AV inputs on the Video Module M5V8 - Worked great in CHCH. Used the Auto Tune to tune in CHCH frequencies, and it also picked up a few Radio Stations that do not seem to be available in Timaru Reception was definately better when car stationary, but I may be able to improve this by position of the aerials, and hey, you should only be using while stationary Picture quailty is actually pretty good, it is just the text on the EPG that is hard to see, whihc is as much to do with the small font size, which does not seem to be able to be changed. Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted October 3, 2011 camera doctor said: Reception was definately better when car stationary, but I may be able to improve this by position of the aerials, and hey, you should only be using while stationary Why not use the built in TV antennas? Add a T-piece with a DC-blocker (available from most satellite installers) to the existing TV antennas The DC blocker should be fitted so that the original antenna amplifiers continue to receive their DC power from the video module, and they can deliver the RF signal back to the new DVB-T tuner as well as the old video module The existing on-glass TV antennas, tuned and engineered for best reception, should work better than any stick antenna inside the vehicle Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted October 3, 2011 jochen said: Why not use the built in TV antennas? Add a T-piece with a DC-blocker (available from most satellite installers) to the existing TV antennas The DC blocker should be fitted so that the original antenna amplifiers continue to receive their DC power from the video module, and they can deliver the RF signal back to the new DVB-T tuner as well as the old video module The existing on-glass TV antennas, tuned and engineered for best reception, should work better than any stick antenna inside the vehicle That did cross my mind Where abouts would I connect to the aerials, and can you elaborate on the DC blocker please Thanks Quote Share this post Link to post Share on other sites
Crazy Dave 0 Report post Posted October 4, 2011 The DC blocker is just a capacitor in one leg so that the DC feed from one tuner does not see the DC from the other. Only one of the tuners (original one is probably preferable) needs to feed DC up the coax to the Antenna amplifiers. Running two tuners off a single antenna system will lower the signal into the tuners by 3dB (half signal) but this will hardly be noticible except in weak signal areas. I was thinking about this tuner (or one similar) and was contemplating using the built in antennas. Im also off to China next month so I was going to see if I could find these tuners over there. camera doctor said: That did cross my mind Where abouts would I connect to the aerials, and can you elaborate on the DC blocker please Thanks Quote Share this post Link to post Share on other sites
jochen 4 Report post Posted October 5, 2011 (edited) camera doctor said: That did cross my mind Where abouts would I connect to the aerials, and can you elaborate on the DC blocker please Thanks Example DC blockers: http://www.conrad.de/ce/de/product/940483/SZU-14-DC-BLOCKER Here's one with SMA connectors: http://www.minicircuits.com/pages/dcblk.html You want SMB (same as the TV tuner antenna connectors at the tuner) Here's a local NZ supplier: http://www.supremeantennas.co.nz/view/conn...-dc-blocker.php And another: http://www.tradetech.co.nz/shop/Outdoor+Ae...or+Filters.html The ones with F connectors are cheap at $5 each. Connect to the antennas at the tv tuner. Adapters will likely be required to convert from the native SMB connector to whatever you will use. Edited October 5, 2011 by jochen Quote Share this post Link to post Share on other sites
nickrout 0 Report post Posted October 31, 2011 I love this mod, but what you really want is mythtv in the boot, so you can pause live tv and catch up at the lights Quote Share this post Link to post Share on other sites
Crazy Dave 0 Report post Posted October 31, 2011 nickrout said: I love this mod, but what you really want is mythtv in the boot, so you can pause live tv and catch up at the lights I sent Greg a PM asking if you could record to USB drive, and as an extension to that be able to play back on other devices, put movies on the USB for playback in the car, and pause and catch up live tv on the memory stick. I did not get a reply, but hey, we all get busy. Hint Hint Greg - did you get a chance to play with this. Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted October 31, 2011 Dave, I did reply to your PM, but have not had a chance to test yet - been absolutely swamped at work, starting early, working nights etc I need to do a wee job on the E39 tonight after my Rotary meeting, so I'll try to remember to test for ya Cheers Greg Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted November 6, 2011 OK, Finally got a chance to check this. It seems to save the files with extension .pvr , which does seem to be proprietary ? My Mac will not recognize it, but I have not tested on Windows yet ( have wrong USB key with me today ) However, I did find that the unit will happily play .avi and mp3 and jpegs Will try the .pvr after lunch, it may work on VLC player...... Quote Share this post Link to post Share on other sites
camera doctor 25 Report post Posted November 6, 2011 Ok, Tried on windows, it seems to crash my version of VLC Plays on Media Player Classic ( Not Windows Media Player ) video plays but no sound. Seems to be .elu .idx and .ini files created too, maybe MP Classic is not looking at these correctly. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted November 7, 2011 try installing a codec pac ... not sure whats 'cool' in codec packs these days ... im not down with the kids anymore. Quote Share this post Link to post Share on other sites
tmase 19 Report post Posted November 7, 2011 This link has some information on the .pvr file format, scroll down to the second entry. This converter is rumoured to be able to convert .pvr files. I don't know of anything that is plug and play for that file type or of a codec pack that would help. This may be of some help too. Quote Share this post Link to post Share on other sites
Crazy Dave 0 Report post Posted November 11, 2011 I just happen to be in China at the moment so tried to find these units. They are not for sale on the local market, however I phoned the factory and they shipped me 2 units overnight for $NZ 104.00 each camera doctor said: Ok, Tried on windows, it seems to crash my version of VLC Plays on Media Player Classic ( Not Windows Media Player ) video plays but no sound. Seems to be .elu .idx and .ini files created too, maybe MP Classic is not looking at these correctly. Quote Share this post Link to post Share on other sites
gadgetman 0 Report post Posted December 24, 2011 Worked well for me using VLC on a Win 7 box Quote Share this post Link to post Share on other sites
Crazy Dave 0 Report post Posted December 26, 2011 Crazy Dave said: I just happen to be in China at the moment so tried to find these units. They are not for sale on the local market, however I phoned the factory and they shipped me 2 units overnight for $NZ 104.00 each I fitted one of these units to my E39 touring a couple of days ago. It works really well. I'm using the supplied antennas at the moment until I can get the correct connectors to make adapters for the OEM antennas. I was thinking of putting in an antenna splitter and feeding both tuners, but I cant see that I will be using the Analog tuner much now. The unit plays MP4 videos and MP3 audio. The only problem is that the input to the tuner is mono and so MP3s are naff. Someone mentioned feeding the audio into the amp. Either into the Tape inputs or the CD inputs. Im just wondering where the easiest place is to access these inputs. Quote Share this post Link to post Share on other sites
