thorburn
boring m50b20
M50b20's are boring.
Is the block the same as the m50b25 just with a smaller bore?
Would it be suitable for boring to 84mm? I've been assuming it'll be fine. Thought I should check
This is to put m54b30 gear into.
i really dont know anything about this sort of thing, but i would have thought using an M52 block would be better as its much lighter?? just a thought if it works
Unfortunately boring out an alloy block is a bit more involved as you need to fit new sleeves.
I'd like to add some forced induction to it as well.
I see! added to knowledge bank haha
have a mate with M50b25 vanos engine block ,
with possible head gasget fail or cracked head ,
was still running ok just pressuizing the coolant system a bit ,
i think he wants $400ono
call me 021433600
Cheers. I've got an m50b25 block all ready. The bores are borderline ok for the pistons I currently have.
I have a M50B25 block (non vanos), you're welcome to measure it to see if it would suit your pistons.
