brockie123 31 Report post Posted October 28, 2011 hey, could anyone in chch help me out in a big way. i'm after a input shaft from a old getrag 240 or 260 to line my clutch up so i can get this motor in hopfully this weekend. if you can help flick me a text 027 289 7856 thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 28, 2011 Do it by eye..its not that hard. Line it up centering the splines relative to the spigot bearing with a screw driver. Just put the pressure plate in place and do the bolts up finger tight so you can align it before tightening up the bolts. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 28, 2011 If you know someone in the area with a lathe...get a piece of dowel or broom handle and machine it to suit the spigot bearing center and clutch plate.. use this Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 28, 2011 You can also get universal fit ones from repco etc. Quote Share this post Link to post Share on other sites
slowe30 0 Report post Posted October 29, 2011 i use a 10mm drill bit with tape wound around till its a snug fit in the splines. dad made it years ago (before i was born i think) and its never failed Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 29, 2011 +1 for any bit of rod with electrical tape wraped around it Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted October 29, 2011 +1 for any bit of rod with electrical tape wraped around it ^^^ Yep or what Glenn said. I have used eyecrometer many times without issue Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted October 30, 2011 I got that clutch aligning tool if you want to borrow it. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted October 30, 2011 Real men dont need alignment tools. Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted October 30, 2011 I got that clutch aligning tool if you want to borrow it. Gave him mine to borrow. Quote Share this post Link to post Share on other sites
