kerry 10 Report post Posted November 4, 2011 (edited) very fun car, Full engine rebuild including ring's, bearing's,big end and main bolts,full gasket set,balanced and full service including gear box clutch diff and brake fluids.... spec's bellow. EXTERIOR Gloss black with blue pearl. 16x7 and 16x8 custom 3 peice arrow wheels kumho tires 195/45/16 front 205/45/16 rear GENUINE M-tech 2 body kit cross hair high beam lamps 35% tints sunroof INTERIOR motorsport recaro front seats rear center arm rest UN-cracked dash Dash mat delrin gear shift white gauge cluster E36 window switch upgrade SUSPENSION AND STEERING E30 51mm struts E30 20mm front swaybar with noltech bushes Koni adjustable shocks front and rear Off set cab's Custom air bag install, 3/8 line, 2 3 gallon chrome tanks , 2 viair chrome compressors, SMC water traps, re5 slam bags in rear universal air front strut bags, custom center 10 switch panel. custom pillow ball front top hats. manual steering rack ENGINE AND DRIVE LINE N/A BMW M52tu 2.8l out of a 2000 e46 328i vanos delete with m50 cams, ported and planed head. M3 throttle bodies Custom intake runners sebring rear muffler with cat delete. E39 523i Manual gear box 1-1 5th. 5 speed E30 organic clutch and HD pressure plate E30 LSD 3.64 E30 325i axles G4 extreme link ecu and map sensor Upgraded fuel pump STEREO Pioneer prs head unit ampsx2 and 10 inch sub enclosed in a custom glass boot install done by intrinsic customs. WOF, REGO, CERT. also has some work equip 03 reps 15X8 et20 021 165 4038 Edited June 22, 2012 by kerry Quote Share this post Link to post Share on other sites
BMWTouring 20 Report post Posted November 5, 2011 What the??? Didn't see this coming! Was the test drive to temp me!!! Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 5, 2011 What the??? Didn't see this coming! Was the test drive to temp me!!! So what did the test drive make you think of it? Would be a great race car too Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted November 5, 2011 No way. You're selling this beauty? You'd regret it?! Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted November 5, 2011 Very nice! GLWS Quote Share this post Link to post Share on other sites
jwde30 81 Report post Posted November 6, 2011 Wow! this was un-expected. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 7, 2011 i may even consider pulling the air set up out and replacing with coil overs and put a cage in it if any one wants a good race car.... Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted November 7, 2011 Way too good to be a racecar. So wishing I sold my cars and have spare 20K. I only dream of mine being this clean. Quote Share this post Link to post Share on other sites
jwde30 81 Report post Posted November 7, 2011 i may even consider pulling the air set up out and replacing with coil overs and put a cage in it if any one wants a good race car.... I enjoy this idea! Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 7, 2011 I enjoy this idea! to be negotioated Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 7, 2011 (edited) Way too good to be a racecar. would be one of the tidy ones.... Edited November 7, 2011 by kerry Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 7, 2011 its going on the hoist tomorrow for a rebuild. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 8, 2011 motor is out and at reconditioners.. cleaned up auxiliary's etc Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 9, 2011 replaced gear box oil and lsd oil today. should be running early next week. some one must want it ............................................................ Quote Share this post Link to post Share on other sites
sascha 17 Report post Posted November 10, 2011 some one must want it ............................................................ Well yes I do want it but I don't have 20k Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 14, 2011 removed cleaned and fitted carpet today... came up really nice. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 14, 2011 got one of these coming from the states. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 22, 2011 got engine back today, new bearings, rings, big end and main and head bolts, full gasket set, dialed the cams in and managed to fit it in the car also, re wire and start tomorrow then off to the tuners on monday then its ready to go.. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 23, 2011 (edited) its in it runs and its mint, so stocked i dont no weather i want to sell it now! Edited November 23, 2011 by kerry Quote Share this post Link to post Share on other sites
polley 916 Report post Posted November 23, 2011 good sh*t. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 23, 2011 small video of it running Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted November 23, 2011 good stuff, bring it to the Jan - Show and Shine / Festival. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted November 23, 2011 yep i will, might see if i can leave it in andy's shop. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted December 1, 2011 cheers for the photo's brook Quote Share this post Link to post Share on other sites
E36 M 9 Report post Posted December 1, 2011 Swaps for an 04 e46 wagon....... Quote Share this post Link to post Share on other sites
