Captain K 0 Report post Posted November 13, 2011 We are selling the engine that Andre used for the last few years. The TradeMe advert reads - "This engine has won the BMW open class championship twice, the NZGT's once, and broken track records for the BMW series. It is a 3.2L S50B32 from an E36 M3. It comes with dual VANOS, alternator, inlet plenum and boot, ARP head and big end bolts, multilayer steel head gasket, MoTeC engine map (no MoTeC electronics), blanked off idle adjuster, electrical plugs (but no wiring loom), multi-throttle bodies, two oxygen sensors, extrators, and all pulleys. It does not have a power steering pump, starter motor, flywheel (needs a race flywheel) or air filter. It was running perfectly when removed from the car. Advice can be given for tuning. It most recently made 200 kW at the rear wheels at HiVelocity (dyno sheet available)." Give me a call on 021 879 761 if interested, Brett Quote Share this post Link to post Share on other sites
Beeker2 70 Report post Posted November 14, 2011 Captain K said: We are selling the engine that Andre used for the last few years. The TradeMe advert reads - "This engine has won the BMW open class championship twice, the NZGT's once, and broken track records for the BMW series. It is a 3.2L S50B32 from an E36 M3. It comes with dual VANOS, alternator, inlet plenum and boot, ARP head and big end bolts, multilayer steel head gasket, MoTeC engine map (no MoTeC electronics), blanked off idle adjuster, electrical plugs (but no wiring loom), multi-throttle bodies, two oxygen sensors, extrators, and all pulleys. It does not have a power steering pump, starter motor, flywheel (needs a race flywheel) or air filter. It was running perfectly when removed from the car. Advice can be given for tuning. It most recently made 200 kW at the rear wheels at HiVelocity (dyno sheet available)." Give me a call on 021 879 761 if interested, Brett Correct me if i'm wrong, but 200wkw doent sound like anything more than std ?? Or is it just that, a standard engine? Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted November 14, 2011 Beeker2 said: Correct me if i'm wrong, but 200wkw doent sound like anything more than std ?? Or is it just that, a standard engine? My standard 3.2 dyno's at 184.8 Kw, hope you dont mind me butting in BrettMark Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted November 14, 2011 yea thats plenty , my 4.4L v8 manual tuned did 190rwkw and a std 3l m3 does about 160-165rwkw all on the same dyno Quote Share this post Link to post Share on other sites
beemn 50 Report post Posted November 14, 2011 Should remember, only ever driven on the weekends! Quote Share this post Link to post Share on other sites
moe 31 Report post Posted November 14, 2011 motec with a good tune adds a few kw Quote Share this post Link to post Share on other sites
Captain K 0 Report post Posted November 14, 2011 Although we have changed bits and pieces on the engine (ARP bolts etc), we kept the core engine standard for reliability. Gavin Bellars said it was the most power he had seen out of one of these - I am not sure if it is the MoTeC tuning or some other magic we might be able to bottle and sell. I can confirm that the last owner only drove it short distances on six weekends each year. Quote Share this post Link to post Share on other sites
Beeker2 70 Report post Posted November 14, 2011 (edited) Captain K said: I can confirm that the last owner only drove it short distances on six weekends each year. To church and back? Or perhaps some other form of more expensive religion! PS, Anyway know how the HiVelocity dyno reads relative to the Torque Performance Dyno? Edited November 14, 2011 by Beeker2 Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted November 14, 2011 Beeker2 said: PS, Anyway know how the HiVelocity dyno reads relative to the Torque Performance Dyno? From my experience Gavins dyno reads slightly lower but if you tell him that he responds with saying his one "reads right" Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted November 14, 2011 200kw is pretty impressive from the s50b32 .... especially considering that the s65b40 is about 218kw at the wheels on torque performance dyno. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted November 14, 2011 M3_Power said: 200kw is pretty impressive from the s50b32 .... especially considering that the s65b40 is about 218kw at the wheels on torque performance dyno. Gavin managed to get 200kw out of my S50b32 to, must be his special mapping skills. Quote Share this post Link to post Share on other sites
