Andre3000 55 Report post Posted January 27, 2012 I'm installing a hydraulic handbrake into my e30, am wondering which way would be the most durable/effective. It will be in the same place/configuration as original handbrake lever. Either the "in-line' way which intercepts the line from brake MC, tapping it through the handbrake and back to the rear brakes. Or, using a handbrake MC with its own reservoir, connected to the rear lines through a T fitting before the branch to separate rear brakes. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 27, 2012 It won't be cert or WOF legal. Handbrakes must be mechanical & not rely on hydraulics which can leak pressure Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted January 27, 2012 It won't be cert or WOF legal. Handbrakes must be mechanical & not rely on hydraulics which can leak pressure What if i get a clubsport licence & logbook? Then apply for authority card/lvv cert? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 27, 2012 (edited) What if i get a clubsport licence & logbook? Then apply for authority card/lvv cert? That may be different... I'm not sure on that. I just know its not legal for a normal road vehicle because its prone to fail with pressure loss over a long or short period of time. Delivery vans used to have them years ago and many failed causing serious damage. Edited January 27, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted January 27, 2012 (edited) I run an in-line hydraulic handbrake in the 205. The best way is to run it in-line. It's probably cheaper in the long run also. Getting the master size right is critical otherwise you won't have enough pressure to lock the rears. Brett at Burton Automotive helped a lot with mine and i can't recommend him enough. Tons of information on-line about them and you can buy fully kits with locks from most rally shops. Mines covered under the motorsport authority card. My master has a bled tap on it also, so should there be an airlock in the master for some strange reason we can bleed it. Edited January 27, 2012 by DRTDVL Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 27, 2012 (edited) You would also be using your mechanical handbrake as well though wouldn,t you Heath ?? As I understand it you can have hydraulic for sports use but the vehicle must also retain the mechanical handbrake. Edited January 27, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
slideways 47 Report post Posted January 27, 2012 Running an extra new pair of calipers is the best because if you run the handbrake inline, you aren't able to use your normal brakes/front brakes when you pull your hydraulic handbrake. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 27, 2012 Running an extra new pair of calipers is the best because if you run the handbrake inline, you aren't able to use your normal brakes/front brakes when you pull your hydraulic handbrake. Where the hell do you fit these extra callipers ???? enlighten us all with a link Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted January 27, 2012 (edited) Running an extra new pair of calipers is the best because if you run the handbrake inline, you aren't able to use your normal brakes/front brakes when you pull your hydraulic handbrake. That's not quite right. The brakes as a whole are still fully functional.. You do however feel the hand brake application back through the pedal. The negative of this is it can upset your brake application, although its a bit of a moot point as you're not likely to be threshold braking if you're about to yoink on the handbrake are you!!!! *GLENN * MASSIVE in Canada do extra caliper mounts for E30 & 36 for the drift guyss. Edited January 27, 2012 by E30-323ti Quote Share this post Link to post Share on other sites
slideways 47 Report post Posted January 27, 2012 (edited) Ok maybe its you cant use the hydraulic handbrake when you use the brakes...does that sound right?? Is there no way of mounting a second set of calipers in an e30? I just see another pair of calipers the ultimate way of doing it but the cost wouldnt really be worth it over just running it inline. Edited January 27, 2012 by slideways Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted January 27, 2012 Its ok for a car used on the road which has a motorsport authority card: http://www.motorsport.org.nz/content/lvv-m...authority-cards Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted January 27, 2012 You can still use the hydro handbrake when you have pedal pressure applied, it just adds more pressure. The drift boys seem to be all over these E36 second rear caliper bracket E30 second caliper bracket Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 27, 2012 MASSIVE in Canada do extra caliper mounts for E30 & 36 for the drift guyss. You learn something everyday... I've never followed the drift scene Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 27, 2012 What motor sports are you going to get involved with Andrew ?? Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted January 27, 2012 I run an in-line hydraulic handbrake in the 205. The best way is to run it in-line. It's probably cheaper in the long run also. Getting the master size right is critical otherwise you won't have enough pressure to lock the rears. Brett at Burton Automotive helped a lot with mine and i can't recommend him enough. Tons of information on-line about them and you can buy fully kits with locks from most rally shops. Mines covered under the motorsport authority card. My master has a bled tap on it also, so should there be an airlock in the master for some strange reason we can bleed it. Thanks for that, Can I apply for an authority card before getting the lvv cert? Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted January 27, 2012 What motor sports are you going to get involved with Andrew ?? Not sure as yet, keen to get into some track days/drift days, learn a bit more about vehicle setup and take it from there. Hoping the Open class will change its regulations for non oem turbos. Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted January 28, 2012 Thanks for that, Can I apply for an authority card before getting the lvv cert? I guess you can as they're sort of separate (you don't always need a cert when you might need an authority card, and the cert can't cover the handbrake (I don't think)). Quote Share this post Link to post Share on other sites
JiB 2 Report post Posted January 29, 2012 Thanks for that, Can I apply for an authority card before getting the lvv cert? Yeah, I did with my race car. Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted January 29, 2012 could anyone in the know chime in if these handbrake button's are a WOF issue? (the ones you can set to not lock) http://www.trademe.co.nz/motors/car-parts-...n-443017585.htm Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted January 30, 2012 Common sense says yes it would be a WOF issue. It disables the intended functionality of the handbrake system which comes under modification of one of the cars braking systems. Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted January 30, 2012 cheers for that. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted January 31, 2012 (edited) You would also be using your mechanical handbrake as well though wouldn,t you Heath ?? As I understand it you can have hydraulic for sports use but the vehicle must also retain the mechanical handbrake. Nope i'm actually running front brakes on the rear of the car so they have no cables what so ever. Never had an issue with WOF's for the handbrake (lots for other things tho - generally Racecars and WOF people are like oil and water). A lot of the new hydraulic handbrake mounting kits have locks built into them: You can see the toothed slide and the locking bar that allows the handbrake to be applied for a period of time. It's not recommended for long periods of use as they can loose pressure over time, (i.e. holding a car on a hill) but does "lock on". That's not quite right. The brakes as a whole are still fully functional.. You do however feel the hand brake application back through the pedal. The negative of this is it can upset your brake application, although its a bit of a moot point as you're not likely to be threshold braking if you're about to yoink on the handbrake are you!!!! *GLENN * MASSIVE in Canada do extra caliper mounts for E30 & 36 for the drift guyss. Yup as it's in-line (well my setup) the foot brake acts through the master for the handbrake allowing for normal pedal braking. The master will always be full of fluid so if your on the brakes and then use the handbrake you will still move the fluid in the handbrake master and apply much higher pressure to the rear calipers than the fronts allowing the rears to lock while still on the brakes for the front. I.e. coming into a hairpin - trail braking to the apex, and using the handbrake to help the back end around. Nice little video explaining what i tried in the hairpin example - http://www.youtube.com/watch?v=bQTML5cIfkk Ok maybe its you cant use the hydraulic handbrake when you use the brakes...does that sound right?? Is there no way of mounting a second set of calipers in an e30? I just see another pair of calipers the ultimate way of doing it but the cost wouldnt really be worth it over just running it inline. You typically need to fabricate new mounts / modify the hubs to mount the extra caliper. A lot of guys use these when they don't have the right master/caliper piston setup to get enough pressure at the caliper to lock the wheel on the factory setup easily. Thanks for that, Can I apply for an authority card before getting the lvv cert? The Authority card is an LVV cert it states it on the top of my Authority Card (Again WOF people get baffled by this) Edited January 31, 2012 by DRTDVL Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted January 31, 2012 The Authority card is an LVV cert it states it on the top of my Authority Card (Again WOF people get baffled by this) What am I looking at in terms of pricing for an authority card? And also do I have to join BMWCCNZ to get access to a scrutineer? Thanks for your tonne of info, it helps to wade through all the misguided jibberjabber on the net these days. Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted January 31, 2012 Also would there be any reason why rigid tubing wouldn't be allowed? I want to avoid braided to keep the cost down. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted February 1, 2012 (edited) i wouldn't screw around with brake lines... I've got steel lines to the handbrake master from the pedal master. Factory setup is steel lines. I know some people are using copper lines now also. I would highly HIGHLY recommend not skimping on brake stuff... it's what stops you! You will need flexy lines in some places and again would highly recommend not skimping and doing it properly. say it costs you a grand for all your brake stuff... how much would it cost you if you had a brake failure and crashed... do it once do it properly or you will spend much much more fixing it later once you realize this. What size pistons do you have in the rear of your car? You need to take this into consideration when selecting the master for your handbrake... have a read about master cylinder sizing - the same applies to your handbrake master as it does to your foot pedal master. If your making new lines to your handbrake you might also want to look at removing the factory bias valve and fitting a adjustable bias valve while your at it. You need to have a clubsport lic ($60 per year) and be a member of a MSNZ affiliated club (Auckland Uni is the cheapest at $10 per year) before you can apply for a authority card. The Auth card is a yearly cost - you need to also compete in 2 MSNZ events per year for it to be valid and accepted for the following year. It expires on the same day as your clubsport lic. Edited February 1, 2012 by DRTDVL Quote Share this post Link to post Share on other sites
