E30 325i Rag-Top 3004 Report post Posted March 28, 2012 (edited) Taking a trailer load to the scrappy tomorrow, so the steelies with or without tyres are free if picked up. Also have a M20B23 short block going gash if anyone wants to collect. Will be doing the Palmy to Auckland line haul next week-end so can delivery if you are not too far off the Mainline. Starting to clear out the garage and yard of E30 parts due to the upcoming move of house. NEW STUFF: E46 M-Tech 2 / M3 / M5 Front LHS Fog-light with rippled glass, good used condition including bulb $100 Pair of plastic surrounds for the above fog-lights $5 for the pair. E30 325i Calipers with good pads with lots of meat left - wider to allow you to run vented front discs, bolt on conversion for solid disk cars $20 ea. Set of 4 standard springs $10 set. So far I have found the following to sell: 14" steel rim, no tyre $5 14" steel rim, rough Hankook 185/65 R 14 tyre $10 14" steel rim, good Sava Intensa directional 195/65 R 14 tyre $15 14" bottle cap alloy with rooted tyre $10 E30 Pre-facelift tow bar, bolts up through boot floor. All bolts and mounting plates included, comes with wiring plug as well, $20 E30 Pre-facelift Front Cut $20 -some surface rust as has been stored outside, but solid. Cut through suspension struts to make it better to stitch on once panels have been cut back. Lots of other stuff still to list, coupe doors (both sides), panels, glass, electrics, trim, 45mm struts only 51mm sold, etc. Let me know if there is anything you are after and I will have a look for it! Open to reasonable offers on all items above! Edited April 21, 2012 by E30 325i Rag-Top Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted March 28, 2012 Make sure you don't sell your spares Jon Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 28, 2012 Hey jon, what struts have you got? give me a text or call, may need a few things. Quote Share this post Link to post Share on other sites
nzer 0 Report post Posted March 28, 2012 have you got 51mm front struts for sale? Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3004 Report post Posted March 28, 2012 Yes, I have got both sizes of struts. Oli has first dibs, so I will find out what he wants first, then let you know. PM what you are after and I'll come back to you with a price. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3004 Report post Posted April 1, 2012 Thread updated and extra parts added. BUMPO Quote Share this post Link to post Share on other sites
ping 0 Report post Posted April 1, 2012 Hey John Also after 51mm front stuts, rear trailing arms and poss rear sub frame. email me on [email protected] cheers JT Quote Share this post Link to post Share on other sites
kevinator9 57 Report post Posted April 2, 2012 Might grab that towbar and if you have an electric aerial? Will text you through the week when I get some money. When are you moving? Quote Share this post Link to post Share on other sites
Jamie W 0 Report post Posted April 2, 2012 Going out on a massive stretch here but would you have an e30 manual pedal box lying around? Cheers! Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3004 Report post Posted April 2, 2012 I have 2/3rds of a manual pedal box , but sorry no clutch pedal side which I guess is the important bit. Not moving for a little while Andrew, probably out of the house in June. I think I have an electric aerial somewhere - just need to find it! Quote Share this post Link to post Share on other sites
Kenn527 0 Report post Posted April 4, 2012 Yes I second that request how much of the clutch side of the pedal box is missing as I'm in desperate need of a pedal box? Cheers Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 5, 2012 Yes I second that request how much of the clutch side of the pedal box is missing as I'm in desperate need of a pedal box? Cheers Jon was simply meaning that he has an auto pedal box. Manual/auto are the same but for the auto obviously having no clutch pedal & the pivot bolt is shorter to suit. You can change the auto box to manual by simply adding the clutch pedal & the the longer bolt to accomodate it. Therein still lies the problem - getting hold of a clutch pedal. This is why most sell (as I always have) as a complete conversion - to eliminate this problem. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted April 5, 2012 Jon was simply meaning that he has an auto pedal box. Manual/auto are the same but for the auto obviously having no clutch pedal & the pivot bolt is shorter to suit. You can change the auto box to manual by simply adding the clutch pedal & the the longer bolt to accomodate it. Therein still lies the problem - getting hold of a clutch pedal. This is why most sell (as I always have) as a complete conversion - to eliminate this problem. Also need the manual brake pedal. Is smaller than the auto, the auto being a lot wider foot plate Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 6, 2012 Also need the manual brake pedal. Is smaller than the auto, the auto being a lot wider foot plate Yup - forgot! Duh That said - you could prolly cut the auto one down Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3004 Report post Posted April 6, 2012 Jon was simply meaning that he has an auto pedal box. Manual/auto are the same but for the auto obviously having no clutch pedal & the pivot bolt is shorter to suit.Glad someone gets my odd-ball sense of humour.Sorry, no manual conversion parts left. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3004 Report post Posted April 10, 2012 Original post updated with new stuff, plus a bit of bumpage! Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3004 Report post Posted April 21, 2012 Original post updated - free stuff! Can do deliveries. And a bit of bumpage! Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted May 8, 2012 Have you got a power steering rack and pump spare by any chance? Quote Share this post Link to post Share on other sites
exige92 0 Report post Posted May 8, 2012 Hey keen on the e30 tow bar. I'm in wanganui but away till sunday. Could come over then if its still around. give me a call/text 021 154 3092 also after indicator stem not real issue but would be nice Quote Share this post Link to post Share on other sites
waddic 1 Report post Posted May 10, 2012 Hey keen on the e30 tow bar. I'm in wanganui but away till sunday. Could come over then if its still around. give me a call/text 021 154 3092 also after indicator stem not real issue but would be nice do u have a brake master cyclinder off a e30 325? Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3004 Report post Posted May 10, 2012 Yes I do, off an ABS car not sure if it makes a difference. Quote Share this post Link to post Share on other sites
Etwenty1 45 Report post Posted May 11, 2012 do u have a brake master cyclinder off a e30 325? Hi, I'll give you $20 for the towbar plug if still avail, will need the loom too. Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted May 11, 2012 (edited) Hi, Do you have a front windscreen to fit a 1990 4 door 325i? If so, what condition and how much? Thanks. Edited May 11, 2012 by Kaz Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3004 Report post Posted May 11, 2012 Sorry, no windscreens. If I don't sell the tow bar I'll sort you out with the plug. Quote Share this post Link to post Share on other sites
